For OCZ PSU
    For OCZ PSU
    which one should I get for OCZ psu?
    this
    http://canada.newark.com/panasonic/e...0uf/dp/17T5078
    or
    this one is on sale for $0.265
    http://canada.newark.com/rubycon/16y...pular Products
    Re: For OCZ PSU
    you don't get capacitors for a particular brand of power supply.
    It varies from model to model of power supply and who makes the power supply and what capacitors they used that week.
    In general, both capacitor series you linked are good, but not really suitable for power supplies, they're a bit on the low side of the specs.
      Re: For OCZ PSU
      16V 1000uF Rubycon "YXF" 10x20mm 1050 0.078 26 cents
      16V 1000uF Panasonic "FC" 10x20mm 1220 0.052 92 cents
      --OR--
      16V 1000uF UCC "KZE" 10x20mm 1820 0.023 25 cents
      If you use this cap in a pi filter, make sure the input cap/s' ESR matches that of the output. For this reason, I wouldn't recommend the Nichicon HM 16V 1000 which are only like 18 cents for some reason, but have a ripple rating of 2550.
      "We have offered them (the Arabs) a sensible way for so many years. But no, they wanted to fight. Fine! We gave them technology, the latest, the kind even Vietnam didn't have. They had double superiority in tanks and aircraft, triple in artillery, and in air defense and anti-tank weapons they had absolute supremacy. And what? Once again they were beaten. Once again they scrammed [sic]. Once again they screamed for us to come save them. Sadat woke me up in the middle of the night twice over the phone, 'Save me!' He demanded to send Soviet troops, and immediately! No! We are not going to fight for them."
      -Leonid Brezhnev (On the Yom Kippur War)
        Re: For OCZ PSU
        thanks mariushm,
        there are about five swallon 1000uF 16v 105°C 20x10mm on the psu board.
        Thinking to have them replace, but there are lots on selection.
        When you say they are on the low side, do you mean the Ripple
        Current?
          Re: For OCZ PSU
          hi mockingbird, so in that case for my psu. Is it better to use a higher amp ripple current of lower?
          Thanks,
          belippy
            Re: For OCZ PSU
            how about this one:.
            http://canada.newark.com/panasonic/e...pular Products
            16V 1000uF Panasonic "FR" 10x20mm 2108 0.020 67 cents
              Re: For OCZ PSU
              The ESR value is low for YXF, it's not a series designed for very low esr. 0.07 is relatively much.
              Ok, knowing the diameter helps, I was concerned you might have 8mm capacitors which are hard to find.
              You need capacitors with high ripple and low esr/impedance.
              These will do (the list is more or less from best to less good, but all better than what you initially selected) :
              Rubycon ZLJ 1000uF @ 25v 10mmx20mm 2500mA ripple, 0.028 ohm http://canada.newark.com/rubycon/25z...0uf/dp/84R1034
              Panasonic FR 1000uF @ 25v 10mm x 25mm : 2470mA ripple, 0.018 ohm impedance http://canada.newark.com/panasonic/e...r%20Capacitors
              Rubycon ZLH 1000uF @ 25v 10mm x 23mm : 2250mA ripple 0.018 ohm http://canada.newark.com/rubycon/25z...25v/dp/39T8696
              Using capacitors rated for higher voltage is safe, no worries about it. The ones rated for higher voltage are usually also larger in diameter, but in this case there are plenty of capacitors with 10mm diameter and 25v rating which have great specs for you, so if you can fit slightly taller ones these above are great. The Panasonic FRs are only 5mm taller, the ZLH are only 3 mm taller, which I'm almost sure you won't have any problems with.
              Panasonic FM 1000uF @ 16v 10x20 2180mA 0.019 ohm http://canada.newark.com/panasonic/e...16v/dp/04M9010
              These will also work and have higher ripple/esr than what you selected, but I don't have time to look up the ripple and impedance in the datasheet for each of these:
              panasonic fr 1000@25v 10x20 (smaller than the one above, slightly lower specs than that one) http://canada.newark.com/panasonic/e...0uf/dp/58T1750
              rubycon flj 1000@16v 10x16 (like above, but smaller height) : http://canada.newark.com/rubycon/16z...0uf/dp/84R0897
              panasonic fr 1000@16v 10x16 http://canada.newark.com/panasonic/e...16v/dp/74R3415
              from this point, ripple is a bit low for psu capacitors but esr is still very good
              rubycon zlh 1000@16v 8x20 http://canada.newark.com/rubycon/16z...16v/dp/39K1347
              fr 1000@16 8x20 http://canada.newark.com/panasonic/e...16v/dp/74R3416
              rubycon zlh 1000@16v 10x16 http://canada.newark.com/rubycon/16z...16v/dp/39T8572
                Re: For OCZ PSU
                Belippy - You mentioned you're in Canada.. Their shipping is $8 + tax, just so you know... I only order from them $100 at a time, to offset the shipping.
                Now regarding what to replace them with... If you want to be safe, post the cap brand and series and then we know what to replace them with.
                Watch out for some of the Rubycons... Most of the time, Newark will only sell you 1000 at a time.
                Thanks,
                belippy
                  Re: For OCZ PSU
                  The brand is CapXon the top one is 2200uF 6.3v lower one is 1000uF 16v
                    Re: For OCZ PSU
                    the 1000uF selection i made remains valid.
                    for 2200uF 6.3v you have this
                    if the capxon is 8mm diameter:
                    http://canada.newark.com/nichicon/uh...-3v/dp/70R1131
                    for 10mm diameter:
                    http://canada.newark.com/nichicon/uh...-3v/dp/65R2144
                    http://canada.newark.com/panasonic/e...-3v/dp/04M8998
                    http://canada.newark.com/panasonic/e...10v/dp/74R3407
                    http://canada.newark.com/nichicon/uh...-3v/dp/70R1129
                      Re: For OCZ PSU
                      --anything-- posted here is better than Capxon KF series... Low on ripple, borderline low-esr caps.
                        Re: For OCZ PSU
                        thank you guys, I'm
