Badcaps.net Forum
Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > Audio Equipment Discussion
Register FAQ Members List Social Groups Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 10-27-2010, 03:37 PM   #1
testas86
Default Sony STR-K740P protect mode
Hi i have a sony STR-K740P that once i turn it on it goes in to protect mode. Ive done some research and sony says it could be caused by speakers being plugged in incorrectly. Ive removed the speakers completely and tried to turn it on with nothing plugged in just power and it still gives me the same message. is there anything i can look for on the logic boards?
testas86 is offline   Reply With Quote
Old 11-22-2010, 10:45 PM   #2
cadiman
City & State: chesterland Ohio
Default Re: Sony STR-K740P protect mode
I have had these give me logic trouble not sure about yours. I would check output ics for shorts. If you run 4 ohm speakers on these outputs that is a slow death for them. I don`t know how old yours is, but they don`t make them the way they did years ago. If you are running normal 8 ohm loads and had trouble then also check solder joints and plug connections. Make sure output connections are free of loose/frayed wires (seen that alot).
If it is logic then most likley needs some board re soldering.
Good luck
cadiman is offline   Reply With Quote
Old 11-22-2010, 10:50 PM   #3
Toasty
Toasty's Avatar
City & State: East Coast, USA
Line Voltage: 220-221
I'm a: Professional Tech
Send a message via Yahoo to Toasty
Outputs and/or drivers.
Photos of that area?
Service manual: http://elektrotanya.com/sony_str-k74.../download.html
Toasty is offline   Reply With Quote
Old 12-07-2010, 04:14 PM   #4
testas86
this happens with nothing plugged in to the speakers area and it still does it. i have it taken apart and ill be uploading picks shortly
Old 12-08-2010, 12:17 PM   #5
testas86
ok so while i was taking it apart i resoldered all the joints on the back of the logic board and put it all back together just to see if that would help and when i turned it on it worked but i also noticed that i didnt plug in the stk pwb 1-687-113-11 and when i plugged that back in i got the protect mode again. any ideas? also does anyone know what the stk pwb is or does
Old 12-08-2010, 01:48 PM   #6
Toasty
Toasty's Avatar
Did you get the service manual? It will tell you in there.
Toast
Old 12-15-2010, 11:35 AM   #7
testas86
so it turns out that the stk350-030's on the stk pwb are what went bad once they come in and i replace them it should be good as new
Old 12-15-2010, 01:57 PM   #8
Th3_uN1Qu3
On my level
Th3_uN1Qu3's Avatar
City & State: Bucharest
My Country: Romania
Line Voltage: 230VAC 50Hz
I'm a: Student Tech
Send a message via Yahoo to Th3_uN1Qu3
That's good. The STKs are the power amplifiers, and they generally don't like 4 ohm loads.
__________________
Quote:
Originally Posted by PeteS in CA View Post
A working TV? How boring!
Th3_uN1Qu3 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2013
Powered by vBulletin ®
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
