Badcaps.net Forum
Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > Power Supply Design and Troubleshooting
Register FAQ Members List Social Groups Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 05-03-2012, 05:28 AM   #1
klkmalik
seeking Tips
City & State: Dubai
My Country: UAE
Line Voltage: LINE VOLTAGE 220 AC 50HZ
I'm a: Professional Tech
Send a message via Yahoo to klkmalik Send a message via Skype™ to klkmalik
Default Dell server powersupply n730 ab a
Hi i got dell server powerwsupply nps 730 ab a , not working .but I didt found any badcaps short components , I need power supply pinout and diagram.
anyone have exp. soultion please post here. thanks advance.
klkmalik is offline   Reply With Quote
Old 05-03-2012, 12:05 PM   #2
dmill89
City & State: Harrisburg, PA
My Country: USA
Line Voltage: 120VAC 60Hz
Default Re: Dell server powersupply n730 ab a
Are you using this PSU in a Dell server or are you attempting to use it on another (non-Dell) system? Dell server PSUs use a 3.3VSB rather than the standard 5VSB effectively making them proprietary. If you are using this PSU with a non-Dell (or even a Dell that isn't a server) it isn't producing enough voltage on the standby rail to be able to start on a standard motherboard.
dmill89 is offline   Reply With Quote
Old 05-03-2012, 01:45 PM   #3
klkmalik
seeking Tips
City & State: Dubai
My Country: UAE
THANKS for post, I want to repair original server power supply. i measuring voltage main caps about 320 volt dc, ofter no switching . there is fet it was ok. also no indication there three LED not working. I want to know without load it will work or not work?
Old 05-03-2012, 04:04 PM   #4
dmill89
My Country: USA
Quote:
That I honestly don't know. I'm fairly experienced with PSUs but virtually everything I have worked on was standard ATX or similar(non-standard cases and connectors but similar in basic design to ATX). I'm not all that knowledgeable about proprietary, hot-swap, rack mount PSUs like the one you have. I also haven't been able to find much on it from web searches (apart from specs and standard stuff, no in-depth technical information) Hopefully there is someone else on here will have more knowledge/experience in this area.
Old 05-03-2012, 10:14 PM   #5
PeteS in CA
PeteS in CA's Avatar
City & State: San Jose, CA
My Country: USA, Unsure of Planet
Line Voltage: 120VAC, 60Hz & 115VAC, 400Hz
Not sure how much help this will be, but that P/S was made by Delta Products (Newton Power). The nearest Delta division to the UAE is Delta Products India. Maybe you could get some information (or a referral to some one who could help) from their tech support.
__________________
PeteS in CA
Republican Operative discussion forums
Where might is right
There is no right.
- Sophocles in "Antigone"
All that is gold does not glitter,
Not all those who wander are lost;
- J.R.R. Tolkien, The Fellowship of the Ring
PeteS in CA is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2013
Powered by vBulletin ®
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
