Thread Tools | Display Modes |
#1 |
Super Modulator
City & State: Αθήνα
I am using these for replacements in the office. dual rail 12v which is not exactly what i need though Passive pfc Last edited by willawake; 01-12-2007 at 04:57 AM.. |
#2 |
Super Modulator
City & State: Αθήνα
#3 |
Super Modulator
City & State: Αθήνα
#4 |
I see this PS has plenty of Teapo caps and Jamicon 3300u 10V. I would be rather sus of the latter caps. The old trick of using low grade caps uprated from 6.3V to 10V.
__________________
Gigabyte EP45-DS3L Ultra Reliable (Power saver) Intel E8400 (3000Mhz) Bios temps. 4096Mb 800Mhz DDR2 Corsair XMS2 4-4-4-12 160Gb WD SATAII Server grade Nvidia 8500GT 256Mb 160Gb WD eSATAII Server grade for backup. Samsung 18x DVD writer Pioneer 16x DVD writer + 6x Dual layer 33 way card reader Windows XP Pro SP3 Thermaltake Matrix case with 430W Silent Power 17" Benq FP737s LCD monitor HP Officejet Pro K5300 with refillable tanks |
#5 | |
Super Modulator
City & State: Αθήνα
Quote:
#6 |
City & State: Orangevale, CA
If one wanted to measure a PSU suspected of doing this, is it simply a matter of measuring the voltage across the cap in question while power is applied?
Or is there a surge voltage that isn't apparent with this method? |
#7 |
Super Modulator
City & State: Αθήνα
there is 3.3v, 5v and 12v rails, why would you need to measure?
#8 |
To see if a 6.3v good quality cap is sufficient where they are using a cheap 10v cap.
I see many mentions of where caps of higher voltage are used without an underlying requirement. |
#9 |
Mine have OSTs for the big ones and the ball bearing version of the Yate Loon fan (D12BH-12)
#10 |
#11 |
Approved Vendor
willawake,
Would you tell me the value capacitance and diameter of large can input caps(Teapo)? |
#12 |
Super Modulator
City & State: Αθήνα
they are Teapo LXK 820uf 200v.
looking at the spec sheet they would be either 25x30 or 35x30. I will pull the psu to check, when i can. |
#13 | |
Approved Vendor
Quote:
#14 |
City & State: dayton ohio
watch for those 25v caps to be on the -5 and -12.
they are filters before the regulator ic for the 2 lines. since supply has to be well above the target for the common 78xx and 79xx a 16v cap wont do and give any headroom. |
#15 |
City & State: Canada
I am using these power supplies in all my custom built PC's for a long time and never had any problem with them.
#16 |
I have 2 of these PSU laying around with bad caps. One of the 2 CAPs in the middle (Teapo 1000uF 10V) are dead on both.
I wonder if it originates from the capacitor quality or maybe the motherboard what it worked with killed it.. (I found these) I would change them, but I have only 1 such capacitor in my inventory but that has greated diameter, or I have some (a lot) nichicon 1000uF 6.3V caps.. oh and a Jee 1000uF 16V. Jee is low quality as I read, but maybe it is oversized enough not to die? Also would it be enough to change 1 cap on both, or both caps since they are identical, and I guess the other can fail as well? |
#17 | |
City & State: VA
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Student Tech
Quote:
Thus 6.3v and 10v caps are *generally* interchangeable in PSUs. |
#18 |
404 Not Found
City & State: Fairfax, California
My Country: USA
Line Voltage: 120VAC 60Hz
I'm a: Forum Junkie
fsp is a decent psu oem, but the love crap caps!
__________________
Firefox is named after a fox - WRONG! That orange thing is a Red Panda, not a fox!! http://www.youtube.com/watch?v=y6GaPkkGZGw |
#19 |
City & State: San Diego, CA
#20 |
Unknown
City & State: North Coast, NSW
My Country: Australia
Line Voltage: 240V 50Hz
I'm a: Professional Tech
Personally, I'd be replacing all of the secondary caps if I had one of these. Jamicon are pure junk, right down there with Fuhjyyu and Sacon. El-cheapo Teapo are marginally better, but not much. I see lost of PSUs with failed teapos. I wouldn't be too worried about the primaries, though, as they rarely fail in any PSUs.
__________________
I love putting bad caps and flat batteries in fire and watching them explode!! Main PC: Core i5 660 3.33GHz, Gigabyte GA-P55-UD3R, 4GB Kingston DDR3 1333, 750GB WD HDD, Sony Optiarc DVD RW, nVidia GTX295 1760MB, Antec 1200 Case, Delta DPS-750CB 750W PSU, Hauppauge TV Tuner, Windows XP Pro. Main Laptop: Lenovo Thinkpad T60: Core 2 T2500 2GHz, 2GB DDR2, 80GB HDD, DVD RW, Intel Graphics, Windows XP Pro. 2nd Laptop: Toshiba Satellite A200: Core Duo 1.73GHz, 2GB DDR2, 60GB HDD, DVD RW, nVidia GF Go 7300 Graphics, OpenSUSE 12.2, Fan Mod |
| Thread Tools | |
| Display Modes | |
