Thread Tools | Display Modes |
#1 |
City & State: East London
My Country: UK
Line Voltage: 230VAC 50Hz
I'm a: Professional Tech
I found these couplers on eBay a few weeks ago. I was wondering what possible use they could be put to?
http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT
__________________
________________________________________________ Invisible airwaves crackle with life Bright antennae bristle with the energy ________________________________________________
#2 |
Those are BNC couplers. Looks like they are for European television cable wire. Old ethernet couplers would have fasteners.
__________________
...Their plight, in fact is even worse, they don't realize that they're cantonists, they think they're free men. What a slavery that is - to confuse slavery for light, and bitter darkness for bright light. -Rabbi Menachem Mendel Schneersohn |
#3 |
City & State: Cambridge, UK
I was going to say 'those couplers are useful because', but now I can't understand what the point is either. You're just going male > female > male
#4 |
Fuhjyyu Killer
City & State: Behind a soldering iron
My Country: New Zealand
Line Voltage: 230V AC 50Hz
Only if you used both at the same time!
But I think they just took the photo that way so you know what each end looks like. |
#5 |
Not BNC. BNC has pins on the outside on the female connector, and a slotted rotating sleeve on the male.
>>Looks like they are for European television cable wire.<< Yes. PAL (Belling Lee) connectors. Looks like it's used to extend the connector from the back of a TV or to fit a threaded connector (the side with the splits). From pictures of the TV's the connector on the back looks to be recessed. If your cable has a large insulator blob at the end, it might not fit into the TV properly. http://en.wikipedia.org/wiki/TV_aerial_plug These look similar to an RCA connector in size, but RCA has a long male pin and conversely the female side would need to be as deep. Toast Last edited by Toasty; 12-14-2010 at 04:22 PM.. |
#6 | |
My Country: UK
Quote:
Sorry everyone else, I should have made it clearer in my first post. They are used for TV aerial connections in the UK, but all they will do is extend the plug on the end of your aerial coax lead by about half an inch. What's the point of that? Unless, as Toasty pointed out, you have a recessed socket on your TV and a non standard sized plug on the end of your aerial lead, but I have never come across that before. Someone, somewhere must have a use for them though, as he has sold 2 packs. |
#7 |
Fuhjyyu Killer
I just realized you are right - these things make no sense. Only sensible reason would be as you say, a recessed socket.
#8 |
Grumpy Old Fart
City & State: Phoenix, AZ
My Country: USA
Line Voltage: 120V 60Hz
As Toasty said:
""... used to extend the connector from the back of a TV or to fit a threaded connector (the side with the splits)."" It converts to a slip-fit. The splits let it slip over threads. Cheap dollar store cables for TV-to-VCR or whatever sold here do the same trick at the back of the TV end. [Or both ends.] No threads and a split outer ring. .
__________________
Mann-Made Global Warming. - We should be more concerned about the Intellectual Climate. - Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind. - Dr Seuss - You can teach a man to fish and feed him for life, but if he can't handle sushi you must also teach him to cook. - |
#9 |
Fuhjyyu Killer
Aah.. Guess I can't read then. ha ha
#10 | |
My Country: UK
Quote:
#11 | |
Grumpy Old Fart
My Country: USA
Quote:
. ~ Ahem... . |
#12 |
My Country: UK
But you cannot convert a threaded plug to a Belling Lee plug, if a threaded plug doesn't exist which can be converted. There isn't a threaded plug with the same pin dimensions or outside diameter dimensions which the Belling Lee socket could fit over.
#13 |
Grumpy Old Fart
My Country: USA
Coax comes with all kinds of threaded plugs.
They just aren't Belling Lee. . Things get interesting when people need adapters for things from across the big pond that are standard on one side but not the other. . And as image of a different adapter shows, there is a threaded plug with the same dimensions as Belling Lee. . Last edited by PCBONEZ; 12-16-2010 at 06:01 PM.. |
#14 |
Is there a shot of the threaded side of that? It looks like an 'F' to B-L adapter, which would have a very small receptacle on the threaded side. If it has the B-L size hole there, then I think we found a match.
I have come across many "wacky" connectors and adapters in my travels. I put nothing out of the realm of possibilities. I've even made a few myself. Toast |
#15 | ||
Grumpy Old Fart
My Country: USA
Quote:
Quote:
I've already seen lots of things that 'don't' or 'shouldn't' exist that have some peculiar purpose unfathomable to anyone outside of some specialty so I don't really question if a purpose exists for something just because I can't think of one. If the part in question had a hole through the tip [for soldering the center wire] I'd say it's simply a crimp-on PAL [aka Belling Lee] connector for the end of a cable. . |
#16 | ||
My Country: UK
Quote:
Quote:
It is a B-L plug to F socket, as shown below (as Toasty suspected). There is no way you could force a Belling Lee socket into an F socket without the aid of a big hammer . Of course, I agree that there are many weird & wonderfull plugs & sockets out there that I have never come across, and possible at some time a threaded plug with similar dimensions to a B-L may have been made for a specific application. I still think that it's pretty unlikely that the 2 buyers of those adapters bought them for that purpose though. I bet they bought them by mistake, thinking they were male - male, or female - female adapters. I notice that no feedback was given or received for the items. Last edited by Radio Fox; 12-18-2010 at 07:24 AM.. |
#17 |
Grumpy Old Fart
My Country: USA
And you don't know what the dimensions are on the female end in you original post so you don't know if that end is Belling Lee in the first place.
#18 |
Grumpy Old Fart
My Country: USA
You see this guy...
Without that OP connector this might be too f*cking fat to fit into the back of some TV sets. What I would like to know is why you are spending so much time obsessing over a connector you say you don't have a use for. - If you want one just to make your junk box look more full, buy one. . |
#19 |
...and send one to me. I like wacko connectors!
| Thread Tools | |
| Display Modes | |
