Hey all
I've got another 46 inch puzzle here. This one is a Samsung LN-S4692D. I was told that "when you turn it on no picture is visible. The sound is there and you can cycle through the channels but can't see anything".
However when I got it home it had a picture
However it's not perfect, the left side of the screen is darker with a red hue, and has a lag or blur effect. The images seems to stay on the screen longer than they should. Occasionally there a vertical lines on the far right side of the screen, they tend to appear only if there is a ticker bar running along the bottom of the screen. This issue occurs on all of the inputs.
There also appears to be a faint horizontal line running across the middle of the screen.
I took a video of what the TV is doing. You can see it here.
I tested the t-con and it is getting about 5v from the LVDS cable.
Is this typical of a bad t-con or a bad display? Any particular test I can do to determine what the issue is before I spend money on parts for this set?
However it's not perfect, the left side of the screen is darker with a red hue, and has a lag or blur effect. The images seems to stay on the screen longer than they should. Occasionally there a vertical lines on the far right side of the screen, they tend to appear only if there is a ticker bar running along the bottom of the screen. This issue occurs on all of the inputs. There also appears to be a faint horizontal line running across the middle of the screen.
