Thread Tools | Display Modes |
#1 |
City & State: Anchorage, Alaska
My Country: USA
I'm a: Knowledge Seeker
So I see others issues with this tv and no picture, but what about a bad picture?
My picture is dim, fuzzy, has black patchy areas (that change position, not a shattered screen). The sound is perfect. It also flickers bright. When in high power mode, it flickers about once a second. In low power consumption mode, it flickers once every two seconds. These pictures actually look brighter than real life. The picture's pretty dim in real life: ![]() ![]() |
#2 |
My Country: USA
Ok, so I took the back off today. Not a single bad cap from what I see.
But I played around with seeing what unplugging different boards and then powering it on did. I notice that there is a snapping comming from the right-most (from back) board (closeup included). The popping or snapping goes away when the board is off. It seems to be coming from the top half of the board and I thought from the left side (bad solid cap?). I unplugged this board while running and the left picture (from front)dissapeared. The right picture looked pretty good except it pulsed. If I unplugged what I think is the problem board before turning the tv on, I just didn't get any picture at all. Any suggestions for what's next if I want to try pinpointing the component rather than just trying to replace the whole board? ![]() ![]() |
#3 |
City & State: University of Leeds (MEng ElecEng undergrad)
My Country: UK
Line Voltage: 230Vac 50Hz
I'm a: Student Tech
This is a bad Z-sustain - the board on the right, as you have diagnosed.
The problem is with the hybrid module, which is under that large heatsink. Replacing the hybrid module is difficult, but not impossible. It requires good soldering skills because of the awful design LG used with these plasma TVs.
__________________
** Begin Signature ** I fix TVs and electronics as a hobby and to save nice things from the dump. 40 LCD TVs, 4 monitors, 13 plasma TVs, and a 6.1 system! Free service manuals database: http://www.tgohome.com/ServiceManuals - Have a manual? Need a manual? Please PM me. I have successfully fixed (from best --> worst build quality): 3 Panasonic Plasmas, 1 Yamaha HTS, 1 NEC Plasma, 2 Sharp LCDs, 2 Toshiba LCDs, 5 Philips Plasma/LCD, 1 Hitachi Plasma, 5 LG LCD/Plasma, 10 Samsung LCD/Plasma, 1 Thomson Plasma, 1 Atec LCD, 1 Hanspree LCD, 1 Xerox LCD, 1 Harwa LCD, 2 Proview LCD, 2 Hyundai LCD, 1 "Onn" LCD, 1 Dell LCD, 1 iiyama LCD, 1 Logik LCD, 5 Bush LCD, 9 Vestel LCDs [Please do not PM me for help: I am a busy student, and we prefer input from all sides on this forum.] |
#4 |
My Country: USA
Any ideas how to figure out what hybid module I need and are there pictures for what the job will look like anywhere?
I'm a computer tech and I've soldered and unsoldered lots of old school eproms, but I always hated things like soic. This looks like it's full size but that it's a pain because of the fact that you can't remove the heatsink beforehand. Ok so I see these: http://vacation-tripadvisor.com/ebay...9&site=EBAY-US http://www.ebay.com/itm/4921QP1027P-...item19d00e5d59 Is this what I want? It looks like the same part for either side hybrid? Is there any way to improve the design when I'm done to keep this from happening again? |
#5 |
My Country: UK
I'm a: Student Tech
The second eBay link is what you need. (If the pin out and old device are the same - check before buying!) You'll probably also need to replace the fuse for Vs on the board.
Hybrid failure is common on these LG plasmas. I have no idea if LG fixed it with later hybrids. Last edited by tom66; 04-30-2012 at 10:58 AM.. |
| Thread Tools | |
| Display Modes | |
