Thread Tools | Display Modes |
#221 | |||
Slow Learner
City & State: Lancashire UK
Quote:
Quote:
Quote:
#222 |
City & State: QLD
My Country: Australia
I'm a: Knowledge Seeker
Alrighty. I think I've got everything I need to know. Time to make the orders - having to turn to eBay for the resistors but everything else I can get from a few local reputable stores. Hopefully this ends with a working monitor and I can stop taking up a disproportionate amount of space in this thread!
#223 |
City & State: QLD
I must have bought the same component - no markings whatsoever as to what pin is supposed to be pin 1.
#224 |
Slow Learner
#225 |
City & State: QLD
I thought I was clever by doing a search on the forum and finding his post - shame I wasn't resourceful enough to find the followup
#226 |
City & State: QLD
Argh, well this has come to a premature end. When I was removing one of the ICs, I must have yanked out one of the lines onto which the IC solders. Damned if I can find where it comes from.
#227 |
Slow Learner
If you post a good picture of the damage zone we may be able to suggest
a fix. |
#228 |
City & State: QLD
Hopefully this is good enough, then!
I've already tried scratching around to find the trace but haven't tried very hard and didn't want to push it in deeper or make fixing more difficult. |
#229 |
Slow Learner
Looks fixable - I am just going off for a week (very inconvenient!) others should be able to advise. Try and clean the area up with isopropyl alcohol on cottonbud or soft brush
Probably Not all the pins need attachment see if you can find a datasheet for the chip. Last edited by selldoor; 05-03-2012 at 04:10 AM.. |
#230 |
City & State: England
My Country: UK
I agree with selldoor... Very inconvenient that he is having a week off!
Do you have any isopropyl alcohol? dont scratch it anymore just get hold of some of that stuff and it will clear the majority of it up. Then get us another pic and we can help work out what goes where. |
#231 | |
City & State: Beijing
My Country: China
Quote:
Also need help.I smalltao point of view in things, but do not know how to do this? |
#232 |
City & State: QLD
Alright, busy times but got some time to clean up the circuit board and take a photo.
I'm pretty sure I've ruined it! See attached. |
#233 |
City & State: Manchester. U.K
My Country: England
Hi Sabretooth,
Check out this link below, it is for a Polish forum, use google translate, it also has the Diagram for L651, hope that this may help you. Good Luck! http://obrazki.elektroda.pl/1950185900_1304529310.jpg |
#234 | |
Slow Learner
Quote:
I am not so sure-Willtbobz, what was the main link to this. The components we do know are D605 on pin5 (not on pic) A 10k resistor on pin1 (could be on pic but not labelled C613 on pin 6 (not on pic) Similarly we have R617 R627 R622 R609 Q602 not mentioned on pic. perhaps they only have topside components labelled. |
#235 |
Slow Learner
Right - Help required from circuit experts - I attach a pic - I have guessed that the IC in question is a NCP1200A (got confused in the threads) Most of the connections seem obvious but struggling with where pin 8 goes. Sabretooth can you see the hole/pin I have dotted the yellow to - what is on the other side of the board at that point. Can you do a close up of the area.
Team -feel free to comment this is a suggestion only and we dont want to cause further damage. |
#236 |
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
If I am correct, that HV pin is the kick start power input from the main DC supply through a bunch of resistors connected in series to drop the 325 Vdc from the main cap down to about 12~18vdc to start the SMPS, once it started, the power supply circuit inside the SMPS will switch from the HV pin to the VCC pin which is generated by the extra winding off the transformer.
I have the 2407WFPB at home that I need to work on, so which board is this I need to look at?
__________________
Never stop learning or per Greek Pro "when you will update your ID from Knowledge Seeker to a Pro (in 10 years) , then I will take you more seriously, for now you are just a kid playing with it keyboard" Baisc LCD TV and Monitor troubleshooting guides. http://www.badcaps.net/forum/showthr...956#post305956 Voltage Regulator (LDO) testing: http://www.badcaps.net/forum/showthr...999#post300999 Inverter testing using old CFL: http://www.badcaps.net/forum/showthr...er+testing+cfl Tear down pictures : Hit the ">" Show Albums and stories" on the left side http://s807.photobucket.com/user/budm/library/ TV Factory reset codes listing: http://www.badcaps.net/forum/showthread.php?t=24809 Last edited by budm; 05-20-2012 at 02:28 PM.. |
#237 |
Slow Learner
Power supply back – board number is 4H.L2K02.A01 position marked on attached
#238 | |
City & State: Mumbai
My Country: India
Quote:
Without a schematic and test voltages, it's very hard to debug the gate control of the hexfet. So my plan is to install a Murata OKI-T/3-W40P-C POL buck DC/DC converter from the 19V source to the required 5V drain, bypassing the on-board converter completely like I am doing now, but drawing from the 19V rail on the internal SMPS board. BTW, I also added the 27V zener in parallel with a 30V MOV on the 19V rail (after the 5A slow blow fuse) for added safety in future. http://www.murata-ps.com/data/power/oki-t3-w40.pdf ![]() |
#239 | |
My Country: England
Quote:
Pin 8 connects to R603 on other side of board as in the Diagram on the link in my previous response. I have checked this against a power supply board that I have on the bench. Sorry unable to take a decent picture (close up) |
#240 |
Slow Learner
Thats Great Willybobz - I forgot there is a high def pic earlier in the post.
I think we just need sabretooth to test what pads he has got for continuity to the next joint then he can try and fit it. Any without continuity will have to be wired. Perhaps he can put a snipped cap leg into the "through" and a small wire from that to pin 8 rather than just a solder blob. Anyone any other ideas. |
| Thread Tools | |
| Display Modes | |
