Thread Tools | Display Modes |
#21 |
City & State: Romania
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
way too much solder, you may be shorting two traces with the solder or have a bad solder connection.
#22 |
How many watts is your solder iron rated for, and how clean is the tip? I think the second photo indicates the iron isn't delivering enough heat to melt the solder to the copper traces of the motherboard. I normally use 40W.
#23 |
Radioactive
City & State: tehas
My Country: US
Line Voltage: 120VAC 60Hz
I'm a: Professional Tech
need flux. badly
#24 |
City & State: Georgia
My Country: USA
I'm a: Knowledge Seeker
I bought a cheap 60 watt iron. It came with a fine point tip which does not seem to hold a lot of heat. I really had to work at getting the solder to melt at times and it would go allover. Should I completely remove solder and start over?
I believe I have read not to remelt solder. |
#25 |
City & State: Prilep
My Country: Macedonia
Line Voltage: 220v AC
You are using way too much solder, try removing some solder from the joints and use some flux to get better joints, although those joints look shiny they might not adhere to the pads on the mobo. Also, any beeps from the mobo?
__________________
Guns don't solve problems. I'll take 12
#26 |
City & State: Springfield, Vermont
My Country: USA
Line Voltage: 122-125V 61-62.5 Hz
And a blonde moment may be the cause. O_O (cracked the core when installing heatsink) (I did that to my T-Bird 1.3 in October, 2002) I got impatient when clamping the socket 462 heatsink.
(Ironically, after just coming back from getting new heatsink paste at RadioShack!) That will cause the nothing-other-than-fans-and-leds syndrome.
__________________
Asus Maximus II Gene Core 2 Duo E8400 @ 3.6 Ghz 2 GB A-Data PC2-6400 DDR2 SDRAM @450 Mhz eVGA GeForce 9500GT (rthdribl stable) Fortron FSP500-60GLN(80) 500W PSU Windows XP Pro x64 SP2 "There's nothing more unattractive than a chick smoking a cigarette" -Topcat "Don't eat yellow snow!" -Salem "did I see a chair fly? I think I did! Time for popcorn!" -ratdude747 |
#27 |
The Boss Stooge
I do have a kit for this board....
![]() http://www.badcaps.net/store/product...&products_id=8 This all I've ever needed to replace on one of these boards, the tiny ones never fail. As for the non POST issue now, recheck all your solder joints....you probably fubar'd a through hole (this assuming the CPU and RAM are good)....but I have seen bad caps on these boards fry processors, so definitely try another CPU before you pronounce it dead.
__________________
<--- Badcaps.net Owner & Forum Administrator!! Badcaps.net Services: Premade Capacitor Kits Badcaps.net Capacitor Master List Motherboard Repair Services If you've come here in search of replacement capacitors or repair services, please use the links above. ![]() ---------------------------------------------- Badcaps.net Forum Members Folding Team http://folding.stanford.edu/ Team : 49813 Join in!! Team Stats |
#28 |
I think your problem is that the iron has too much power and makes the tip to get too hot, causing oxidation form an insulating layer that prevents good heat flow. This oxidation can be so bad that solder won't immediately melt even when i's pressed directly against the tip. Once a tip oxidizes, it has to be cleaned off (brass wool, steel wool) and retinned to work again. Also high temperatures can prevent the solder from sticking, I think by burning up the flux before it can clean the surfaces.
#29 |
o.O
City & State: Duisburg
My Country: Germany
random: can someone fix the thread title? It's A7N8X, not A78NX (doesn't exist)
#30 |
My Country: USA
No beep codes..... I probably rushed my way through this so I will remove and retry. I will clean the iron as suggested and work on my soldering skills (or lack of) and report back. Luckily, I bought extra caps just in case.
I don't think that I cracked the core or anything like that. Other than the sloppy soldering, I really took my time removing the caps and cleaning the holes. I am confused as to what the flux is for. I don't have any and will have to order if it is necessary. Would the computer POST or begin to POST if some of these caps were properly placed ? Do all 8 of the caps that I replaced need to be perfectly installed or will one bad one prevent POST ? Just curious. Also, I did order the other caps that were suggested but have not considered replacing them yet as I wanted to first replace the obvious bulging ones. I didn't want 30 bad solder joints to have to figure out. Thanks everyone for the help. I am already shopping for my new build but I am not going to give up on this yet !! |
#31 |
Here's an excellent tutorial on how to solder. Flux is used to remove oxidation from pads and joints so solder can form well and adhere to pads and leads.
http://www.youtube.com/watch?v=I_NU2ruzyc4 |
| Thread Tools | |
| Display Modes | |
