Thread Tools | Display Modes |
#21 | |
City & State: Kildare
My Country: Ireland
I'm a: Knowledge Seeker
Okay, I hooked up the power board and the video board, verified that the voltages coming out of the power board were the same as previous ... i.e. 11.78, 11.78, 5.15, 4.85, and took the voltage measurements of the LM1117L voltage regulator on the video board... Here are the numbers:
black to pin 1, red to pin 2 : 1.25v black to pin 1, red to pin 3 : 2.44v black to pin 2, red to pin 3 : 1.18v Quote:
#22 |
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
What do you read on Pin 1 and Ground, Pin 3 and ground? Ground = metal chassis (board must be mounted in place)
__________________
Never stop learning or per Greek Pro "when you will update your ID from Knowledge Seeker to a Pro (in 10 years) , then I will take you more seriously, for now you are just a kid playing with it keyboard" Baisc LCD TV and Monitor troubleshooting guides. http://www.badcaps.net/forum/showthr...956#post305956 Voltage Regulator (LDO) testing: http://www.badcaps.net/forum/showthr...999#post300999 Inverter testing using old CFL: http://www.badcaps.net/forum/showthr...er+testing+cfl Tear down pictures : Hit the ">" Show Albums and stories" on the left side http://s807.photobucket.com/user/budm/library/ TV Factory reset codes listing: http://www.badcaps.net/forum/showthread.php?t=24809 |
#23 | |
My Country: Ireland
Quote:
http://omg.wthax.org/17072012826_copy.jpg |
#24 | |
Slow Learner
City & State: Lancashire UK
Quote:
You just have to translate it into where they are on your board I think they are the 4 in an oblong covered in glue on the back of the board. It is just an ohms test - no power post results as S1>S2= xxx ohms S3>S4= XXXohms |
#25 | |
My Country: Ireland
Quote:
With the power off and MM set to 2K ohms, I took the following measurements.. S1 - S2 reads 1.014 S3 - S4 reads 1.010 |
#26 | |
City & State: Curitiba
My Country: Brazil
Line Voltage: 127VAC 60Hz
Quote:
#27 |
My Country: Ireland
Okay voltages between LM1117L and cold ground H1.
PIN1 - GND : 2.09V PIN2 - GND : 3.35V PIN3 - GND : 4.55V While I had the video board hooked up to the PS for this test, I measured the voltage across the power supply's 12V DC output which feeds the video board and it read 12.15V.. It reads as 11.78V without load. Maybe it is working and I just need a new video board.. If I could get the BL_ON signal and test the backlight it would confirm it. |
#28 |
My Country: Brazil
The 1117 voltages seem to be ok. It is converting 5V to 3.3V. I agree with the idea of testing with a known good video board. Didnīt you say that you had another display of the same model ?
#29 | |
Slow Learner
Quote:
Budm did ask some posts back if you had it connected up to a working PC - cant see an answer Sometimes if it is not connected the mainboard wont start the inverter. @Budm - you did say you had a BLon trick? Last edited by selldoor; 07-19-2012 at 10:59 AM.. Reason: trick |
#30 |
My Country: Ireland
okay managed to put the LCD monitor fully back together and nothing happens.. no light, nothing.. Just to reiterate, I've tried the video board with a known FULL WORKING power supply from a similar monitor, so I'm assuming that after the power supply caps blew, too much power went to the video board and some component on it then blew also.
I have another LCD screen displaying the same characteristics after also having the caps replaced, so I assume it's the same fault. I cant justify spending 30 dollars on a new DAOL9FMB031 video board to test the PS fully, which is annoying, but I'll keep a lookout for a second hand one. |
#31 |
Slow Learner
Hi - can you disconnect the cable that goes from the main board to the
panel, then try and switch on and report what happens. |
#32 |
City & State: Trenton, NJ
My Country: USA
Line Voltage: 240v-120v 60Hz 200A service drop
And if what selldoor mentioned didn't work, You might want to start checking caps on the video board, sometimes if a cap goes bad in the psu, it can take out others on different boards.
You also could hook up the 5v to the BL_ON pin via a resistor (use one somewhere around 1k ohms), and see if the backlights turn on.
__________________
Hi-pot test: FAIL |
#33 | |
My Country: Ireland
Checked all the caps and they look fine on the video board. But I'll whip off the cover again and try all the above suggestions..
Quote:
I wasnt gonna troubleshoot the Video board, but I've found the service manual for the DAOL9FMB031, so I'll give it a shot .. This is the board layouthttp://omg.wthax.org/DAOL9FMB031_Schematic.jpg And this is the flowchart of troubleshooting the board. ![]() http://omg.wthax.org/DAOL9FMB031_Troubleshooting.jpg |
#34 | |
My Country: USA
Quote:
And be careful, the high voltage for the ccfls will hurt if you touch it! Last edited by ben7; 07-23-2012 at 03:57 PM.. |
#35 | |
My Country: Ireland
Quote:
http://www.badcaps.net/forum/attachm...9&d=1300019903 |
#36 | |
My Country: USA
Quote:
#37 |
My Country: Ireland
I thought those 8 pins were just for providing power to the VGA board, I didnt realise the backlight on signal was sent through here..
This is a capture of the pins from above http://omg.wthax.org/powerconnections.jpg And the voltages I measured across those pins earlier with the MM. http://omg.wthax.org/measured_voltages.jpg I see the words ADJ and ON/OFF beside the 5v rails, I'm assuming that it's the ON/OFF which seems to be the bottom pins. |
#38 | |
My Country: USA
Quote:
When you do it, keep the video board disconnected from the psu, but keep the ccfls connected. See if the ccfls will light up. |
#39 |
My Country: Ireland
Okay ben (and thanks for your help so far, really learning a lot) I've created a 1k circuit on my breadboard and connected two jump wires from it to the two pins mentioned above. The backlight flicks on for a fraction of a second (while the pins touch) and then goes off.
I'm unsure as to whether you meant to connect them or to just jump the pins give a 1 to switch on? (trying to be careful) Last edited by JonathanAnon; 07-23-2012 at 08:21 PM.. |
#40 | |
My Country: USA
Quote:
Does the power supply turn off too(measure its output voltage(s) if your not sure)? Or, does the backlight not work until you disconnect and reconnect the resistor to the BL_ON pin? Yes, we are sending it a '1', to tell it to turn on the backlight. The resistor will limit the current when [if] you touch the wrong pin. Last edited by ben7; 07-23-2012 at 08:25 PM.. |
| Thread Tools | |
| Display Modes | |
