Rexpower PL-400 rebuild
  • c_hegge
    • Sep 2009
    • 5219
    I pulled this PSU out of a customer's machine. It wouldn't POST with this PSU, but worked fine with another. I decided to rebuild this PSU and turn it from a gutless wonder into a PC P&C (OK, maybe not quite that good). Here's what it's getting (all parts except for secondary caps scavenged from other PSUs) :
    A new case (from a dead Antec SP-350)
    Two fans (Delta)
    New heatsinks
    New Primary switchers
    New secondary silicon (30A for the 3.3 & 12V. 2x 30A for the 5v)
    New transformers
    An extra set of input filtering coils
    Two 0.47uF X Caps
    A 4A Rectifier in place of the 4 diodes
    560uF Nichicon LU Primary caps
    New secondary caps:
    4x 2200uF 6.3 Canicon - 3300uF Samxon RS from Topcat
    1x 2200uF 16v Canicon - 3300uF Samxon RS
    2x 470uF 16v Canicon - Panny FM
    1x 680uF canicon for 5vsb - 1000uF 6.3 Nichicon HE
    Pics coming soon
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Rexpower PL-400 rebuild
    Delta fans? You must really like noise then. Everything else looks good, but if you use adequate transistors and rectifiers... you shouldn't need noisy fans.
    A working TV? How boring!
    • c_hegge
      • Sep 2009
      • 5219
      The fans are temp controlled. I used them as they are good quality ball bearing fans and not HongKongFlyApart company made sleeve bearing fans.
      • 370forlife
        Large Marge
        • Aug 2008
        • 3112
        Rexpower...any idea who the OEM is?
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          Erm... Beer? Sorry, i meant Deer.
          • 370forlife
            Large Marge
            • Aug 2008
            • 3112
            Must be a old deer. They haven't use canicon in a while.
            • c_hegge
              • Sep 2009
              • 5219
              This PSU has some similarities (most notably, Ever-power printed on the transformers).
              Here's the label in case that helps.
              • c_hegge
                • Sep 2009
                • 5219
                Glad I changed the heatsinks. The original ones were so thin I can bend them into a U shape with my bare hands!
                PS. Did someone delete my post with the internal pictures? or did I just not post it in the first place?
                • Toasty
                  • Jul 2007
                  • 4171
                  AHEM!
                  Use of the HongKongFlyApart name is a Toasty registered trademark and requires an ® after it.
                  veritas odium parit
                  • c_hegge
                    • Sep 2009
                    • 5219
                    One question about it. How much wattage do you think it could manage after doing all this to it?
                    The two primary switching transistors are now 2SC3320 and, for the secondary, I used an STPS3045CW on each rail and two of them on the 5v.
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      • Romania
                      With those parts, it'll depend on the frequency that it's operating at. You could get a full 400W, but it'll probably require rewinding the transformer too. I say you're gonna get about 300.
                      • c_hegge
                        • Sep 2009
                        • 5219
                        Only 300? It's going to be running on 240v and the transformer will be replaced with a bigger one.
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          • Romania
                          If you replace the transformer you should get more. Good silicon with an EC-35 transformer will get you close to 500W.
                          I've seen a X-Tech "500W" supply fail on a system that barely drew 100W, because the primary transistors were crap. Everything else was actually spec'd correctly, and that supply would have done 500W if given the right silicon.
                          • goodpsusearch
                            • Oct 2009
                            • 2850
                            • Greece
                            Please post some photos
                            • c_hegge
                              • Sep 2009
                              • 5219
                              Here
                              • goodpsusearch
                                • Oct 2009
                                • 2850
                                • Greece
                                You can add metal oxide varistors for protection from power surges.
                                The switching transistors you used are capable of 450W.
                                The transformer looks to be El-35, good for 350 watt, maybe more. It depends of the switching frequency used.
                                Personally, I like to beef up the input capacity, so I would put 680uF or 820uF on a 350-400 watt psu.
                                You say you used STPS3045CW for the 12V line. VRRM is 45V, maybe too low for the 12V line. Some psus require fast recovery rectifiers for 12V or schottky rectifiers with 60VRRM or better. Look what happened when I tried to replace a 10A fast recovery rectifier with a schottky in a Maxpower PL-300 (same oem): https://www.badcaps.net/forum/showth...?t=8171&page=7
                                Last one, if it uses the same design with my maxpower, then there are 2 caps for the 5vsb (pic)
                                • c_hegge
                                  • Sep 2009
                                  • 5219
                                  The original 12v was one of these, so Ill look at getting a better replacment.
                                  • Th3_uN1Qu3
                                    Believe in
                                    • Jul 2010
                                    • 6031
                                    • Romania
                                    My Powerlink works fine with a diode with 40v reverse voltage on 12v. When testing the SMPS i built myself, i actually did 24 volts out with a SBL3040CT... Dunno for how long would it have lasted, but it certainly worked just fine for a few hours.
                                    I think that on some units they are just too lazy to install proper snubbers on the transformer, so they put a higher voltage diode that can eat up the spikes.
                                    • 370forlife
                                      Large Marge
                                      • Aug 2008
                                      • 3112
                                      Ultrafasts and Fast recoveries are cheaper than schottky. When the psu is designed to be lower current and cheap as possible they will use parts as cheap as possible and as close to spec as possible (referencing to the OEM's spec's)
                                      Depending on the design, 2SC3320's can deliver 500W or more. For this key mouse I wouldn't count on it though. Also, the SG6105DZ has OPP, which means it will probably shut down before it blows up.
                                      Ever-power on the transformer means it's a Key mouse (KMEX). Key mouse likes to copy other companies designs, especially ATNG. Consequently they can be ok performers if kept within their designed wattages.
                                      • c_hegge
                                        • Sep 2009
                                        • 5219
                                        It actually had schottkys for the other two rails (Mospec S20C40C). The only fast recovery was the F12C20C on the 12v. As a replacment for the 12v rail, would an 80EPF10 do the job? (80A, 1000v VRRM)
                                        • emil_t
                                          RTX3090 working fine but fans not spinning
                                          by emil_t
                                          Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                                          04-12-2024, 06:54 AM
                                        • JayPoorJay
                                          Hot Water Rad - A Few ECU Fans and a Timer Switch
                                          by JayPoorJay
                                          Good Afternoon, Good People.
                                          I know this will be an elementary little project for most if not all of you, but I thought I would write a post and get put on track, rather than bumbling my way through it with all kinds of trials and errors.
                                          I REALLY would appreciate y'alls help.
                                          This is the problem - My wife and I purchased a big ol Victorian/Colonial House in NYC two years ago. The kitchen is surrounded on 3 sides by exterior walls, there is also a 1/4 of the kitchen floor (ceramic tiles) that has a crawl space underneath, and the kitchen gets FREEZING cold...
                                          10-29-2024, 12:54 PM
                                        • sda sad
                                          my Xiaomi Notebook Pro X laptop fans work like crazy for no reason
                                          by sda sad
                                          Hope this is the right place, someone can help me.
                                          My laptop started having a really strange problem....
                                          When I turn it on the fans start working at a crazy rate and with random breaks...
                                          They can work for say 10 seconds and stop for 2 seconds and then turn on again for 5 etc...
                                          And it's from 0 to 100%. I tried to install AIDA and did the processor chip test and the graphics did not exceed 70 degrees and the fans were not even close to working at the power they work randomly.
                                          The model of the computer:
                                          Xiaomi Notebook Pro X 15 OLED (A30)
                                          04-23-2024, 09:55 AM
                                        • joesmoe91
                                          Dell Precision 5530 15" died to blown chip. Replaced chip and now only get momentary fans, lights, no screen or boot
                                          by joesmoe91
                                          My Dell Precision 5530 turned off suddenly when I was running Matlab and wouldn't turn on, show any lights, fans, and/or any signs of activity at all. I opened the case, removed the battery and looked at the board with a thermal camera while the AC adapter was connected. I saw that PU1252 was >120C so figured the chip had died on me Got the part number off the attached schematic (see Mouser link below) and replaced the chip. After replacing the chip the board (connected to AC adapter) was able to briefly power on, spin the fans a little bit, and turn on the front led lights....
                                          02-22-2024, 07:38 PM
                                        • magneh
                                          Spectre X360 DAX38CMBAG0 - overheating fans not spinning
                                          by magneh
                                          Hello all
                                          Got this Spectre with an overheating problem.
                                          I verified that the fans start briefly during power up, but never turn on again,
                                          even when stress testing the machine and CPU at 100°C fans dont spin
                                          Ive measured and I have 5V, 3.3v and 3rd pin 0.
                                          When fans spin during start up, the signal at 0v is at 1.6v.
                                          Probably its Fan2Sig pin and 3.3V is PWM, not sure
                                          Question is , how to fix?
                                          I think these signals come from ITE controller am I right?
                                          Should I bother replacing it?
                                          Thanks...
                                          10-04-2022, 03:15 AM
