Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > Power Supply Design and Troubleshooting
Old 11-06-2010, 10:54 PM   #1
everell
everell's Avatar
City & State: Williamsburg, Virginia
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
Default Rosewill RP550-2-S
Here is a newly acquired Rosewill RP550-2-S. Everything looks as cramped as an Antec Smartpower. Powered it up.....5vsb is dead. Uses one of those #@$%&* two transistor circuits. Fuse checks good, and DC voltage at main capacitors looks good. So here are some pictures. The case has a shiny chrome mirror like finish. Too bad it looks better than it works!
Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
everell is offline   Reply With Quote
Old 11-06-2010, 11:11 PM   #2
shovenose
404 Not Found
shovenose's Avatar
City & State: Fairfax, California
I'm a: Forum Junkie
Default Re: Rosewill RP550-2-S
Are you gonna do a dm311 mod?
Firefox is named after a fox - WRONG! That orange thing is a Red Panda, not a fox!!
http://www.youtube.com/watch?v=y6GaPkkGZGw
PSU Pr0n
http://www.psudatabase.com/
shovenose is offline   Reply With Quote
Old 11-06-2010, 11:16 PM   #3
ratdude747
ratdude747's Avatar
City & State: New Albany, IN
I'm a: Student Tech
Send a message via Yahoo to ratdude747 Send a message via Skype™ to ratdude747
i hope you will complete the primary filter as well.... jumper wire bad! components good!
(Insert signature here)
ratdude747 is offline   Reply With Quote
Old 11-07-2010, 12:30 AM   #4
c_hegge
Unknown
c_hegge's Avatar
My Country: Australia
Line Voltage: 240V 50Hz
I wouldn't worry too much about the input filter. It looks good enough as it is.
Main PC: Core i5 660 3.33GHz, Gigabyte GA-P55-UD3R, 4GB Kingston DDR3 1333, 750GB WD HDD, Sony Optiarc DVD RW, nVidia GTX295 1760MB, Antec 1200 Case, Delta DPS-750CB 750W PSU, Hauppauge TV Tuner, Windows XP Pro.
Main Laptop: Lenovo Thinkpad T60: Core 2 T2500 2GHz, 2GB DDR2, 80GB HDD, DVD RW, Intel Graphics, Windows XP Pro.
2nd Laptop: Toshiba Satellite A200: Core Duo 1.73GHz, 2GB DDR2, 60GB HDD, DVD RW, nVidia GF Go 7300 Graphics, OpenSUSE 12.2, Fan Mod
c_hegge is offline   Reply With Quote
Old 11-07-2010, 05:34 AM   #5
370forlife
Large Marge
370forlife's Avatar
City & State: Kalamazoo, MI
My Country: United States
Line Voltage: 0-120VAC 60Hz
Send a message via AIM to 370forlife
The input filter is complete, that jumper wire is for the optional APFC components.
By they way, this is a very good performing, but aging, ATNG unit.
Review for the 500W version:
http://www.jonnyguru.com/modules.php...Story2&reid=32
Originally Posted by JFK
The American, by nature, is optimistic. He is experimental, an inventor and a builder who builds best when called upon to build greatly
370forlife is offline   Reply With Quote
Old 11-07-2010, 05:36 AM   #6
everell
everell's Avatar
The jumper wires on the input side are NOT for line filter.....they are for a PFC circuit which is not installed. The red jumper wire I added to take the place of the 115/230 volt switch.
Have not decided whether or not to do the DM311 mod........there just is not the usual amount of room for the add-on board which would go between the two heat sinks. Mounting the add-on board on the other side of the heat sink would cause BIG problems in how to route the wires.
My conclusion: they should have built it right in the first place. No surface mount components, two transistor 5vsb circuit, so this is probably some more Solytech crap.
Old 11-07-2010, 05:38 AM   #7
everell
everell's Avatar
Good morning 370forlife. You posted while I was writing! No.....this is not a good ATNG unit. It does not work.
Old 11-07-2010, 05:41 AM   #8
370forlife
Large Marge
370forlife's Avatar
I've got an identical ATNG branded unit (circa 2002, still works) if you need any part numbers or measurements.
Old 11-07-2010, 08:40 AM   #9
Per Hansson
Per Hansson's Avatar
City & State: ----
My Country: Sweden
Line Voltage: 230v 50Hz
Send a message via ICQ to Per Hansson Send a message via MSN to Per Hansson
Quite impressive input filter for a Rosewill, guess I will need to adjust my opinion on them.
Also interesting location of the input filter, spanning all the way from what is usually regarded as the "primary" side over to the "secondary"
Because correct me if I'm wrong, but those Y-Caps on the right are part of the input filter right?
http://www.badcaps.net/forum/attachm...5&d=1289105592
Old 11-07-2010, 08:43 AM   #10
370forlife
Large Marge
370forlife's Avatar
Yeah, the Y caps are in the input filter. Rosewill's ATNG units are pretty solid, it's their low end solytech units that are a little more "explosive"
Old 11-07-2010, 12:26 PM   #11
Th3_uN1Qu3
On my level
Th3_uN1Qu3's Avatar
City & State: Bucharest
My Country: Romania
Line Voltage: 230VAC 50Hz
I'm a: Student Tech
Send a message via Yahoo to Th3_uN1Qu3
You mean that thing can actually do 50A on 15v? That's the highest 5v rating i've seen so far. Somehow i doubt that it's true - if it is, i gotta locate one for my dual-PIII.
Originally Posted by PeteS in CA View Post
A working TV? How boring!
Th3_uN1Qu3 is offline   Reply With Quote
Old 11-07-2010, 12:32 PM   #12
370forlife
Large Marge
370forlife's Avatar
I have the 450W ATNG branded version, it has 2x 40A schottky's on the 5v rail, so I think it the 550W version can do 50A on the 5v.
Old 11-07-2010, 06:41 PM   #13
goodpsusearch
City & State: Thessalonik
My Country: Greece
I'm a: Hobbyist
Very nice psu. It looks to have Teapo caps everywhere.
goodpsusearch is offline   Reply With Quote
Old 11-28-2010, 02:35 PM   #14
everell
everell's Avatar
The 5vsb circuit is the trouble maker on this one. I tried doing a repair to the two transistor circuit, but it only blew out again. I installed a DM311 mod, but the output was only .9 volts. The feedback was over 2 volts so looks like the transformer is shot. Checked out components on the output side, and they were all OK. The main switching transformer and the 5vsb transformer both start with "AP". Not too sure who the OEM is. The 5vsb transformer number is AP-500EPS-T2-3, so check your junk box.
Old 11-28-2010, 04:13 PM   #15
370forlife
Large Marge
370forlife's Avatar
AP-XXX is ATNG's in-house numbering system. This power supply is a AP series, 500 is just the mid range of what units that transformer is used in. 400-600W. ATNG is big enough to where they make their own transformers.
I have a ATNG AP-300 here. The 5vsb transformer is decently sized, marked AP-265N-1AT3.
Old 11-29-2010, 04:42 AM   #16
everell
everell's Avatar
Is this something from your junk box? If so send it on and I will see if I can get it to fit and work. This psu is so compact and crowded it reminds me of a Antec SmartPower.
Old 12-04-2010, 06:00 AM   #17
everell
everell's Avatar
To work on the 5vsb on this one required that I remove both heat sinks. So here are a couple of pictures. Both heat sinks are removed. The board does show a little bit of burn damage from the 5vsb blowups. All of the two transistor components have been removed. A DM311 mod board is temporarily installed with long leads to keep it out of the way while working on the circuit. Once I find a suitable 5vsb transformer, I can move this project further along.
Old 12-04-2010, 06:44 AM   #18
370forlife
Large Marge
370forlife's Avatar
Ahh good ol' ATNG, always scratching off part numbers.
Old 12-04-2010, 09:41 AM   #19
Toasty
Toasty's Avatar
City & State: East Coast, USA
Line Voltage: 220-221
Send a message via Yahoo to Toasty
Question Re: Rosewill RP550-2-S
Look again.
Toasty is offline   Reply With Quote
Old 12-30-2010, 07:11 AM   #20
everell
everell's Avatar
I have done more testing on the 5vsb circuit components, and verified that the 5vsb transformer is bad. I removed the transformer from the pc board and put it in a different working circuit using the DM311 chip. Same results as when installed in original power supply. The winding to the switching transistor is OK, and the feedback windings are OK. The 5vsb secondary winding is the culprit, which puts out only 2 volts max with no load. Any added loading reduces the output voltage quickly. That explains why I measured only .8 volts on the 5vsb line in the original power supply.
The pin layout of the transformer is different from any transformer I have in my junkbox. As crowded as everything is in this power supply, I am on the lookout for a matching transformer. So check you junkbox for any 5vsb transformer labeled AP-500EPS or even AP-xxx from a ANTG power supply. Thanks.
