Office Depot Ativa Wireless G Router AWGR54 by Belkin
  • severach
    • Aug 2007
    • 1055
    FCCID: RAXWG4005G
    P75233 AWGR54 WG4005G-LF-AK 141400520017J REV:01
    U1: Atheros AR2317-AC1A with stick on or solder on heat sink
    U8: IC+ IP175C LF 5 Port 10/100 Ethernet Integrated Switch with integrated linear regulator driver
    Q4: UTC 2SB1412 B1412 PNP HIGH VOLTAGE SWITCHING TRANSISTOR C259:3.3v -> EC180:1.88v->L79->EC179 regulated by the IP175C
    U10: Anpec APM9435 P-Channel Enhancement Mode MOSFET
    U12: Matrix Microtech MT34063M Universal DC to DC Converter C289:12v -> C291,C169:3.3v
    D11: SK24 SMD 3.3v freewheel diode
    U11: ISSI IS42S16400B-7T 64 MBit SDRAM 1Mb x 16 x 4
    iESR=in circuit ESR
    ESR=out of circuit ESR
    WV=Working voltage of a functional unit
    C289: Taicon VT 100uf 25v 6.5x12 iESR=0.75 ESR=0.85 WV=12v transformer voltage
    EC179: Elcon 47uf 25v EYA 5x11 iESR=0.03 ESR=0.12 WV=1.88v
    EC180: Elcon 47uf 25v EYA 5x11 iESR=0.03 ESR=0.12 WV=1.88v
    EC182: Elcon 47uf 25v EYA 5x11 iESR=0.03 ESR=0.12 WV=3.3v
    C291: Elcon 470uf 10v 6.5x12 iESR=0.05 ESR=0.55 WV=3.3v parallel with C169
    C169: Taicon 100uf 25v 6.5x12 VT iESR=0.05 ESR=0.85 WV=3.3v parallel with C291
    6 units, all unreliable. All fail, some run for days, some fail within minutes. The wireless and web configuration may work for a short time after the router dies and cuts off the Internet. A power cycle and they are working again. No obvious bad caps. C169 and C291 are in parallel and are very different. Maybe the circuit was designed for two 470uf 10v caps and the smaller cap got substituted by mistake or to save a penny. The Taicon datasheet does not list ESR for C169. 1 ohm ESR is appropriate for a 100uf low ESR capacitor. The Elcon EYA data sheet shows 0.13 ohms impedance for a 470uf 10v. The series of C291 is not labeled but if it were an EYA, 0.55 ohms would be 5 times the proper value.
    With the router becoming unreliable when the Elcon 470uf reaches 0.55 ohms the perfectly good 1 ohm Taicon 100uf is completely useless in position C169. In C169 I put a Panasonic or Rubycon 820uf 6.3v which have an ESR of 0.02. At 1/5th the ESR of the best original, my cap takes the entire load so C291 is no longer important. EC179-182 have way better ESR than anything I can supply. The ESR of C289 does not need to be very low.
    One cap done!
    It appears that many low cost networking products have the same flaw and the same fix works for most of them. The engineers design a reliable circuit. Bean counters cut costs until the design is marginal but still works for most of the warranty period. Semiconductors aren't easy to cut because they don't substitute well. Capacitors can be cut right to the edge of reliability. The capacitors slowly degrade which stresses the marginal circuitry to the breaking point. Soon the product is unreliable but can be coaxed into functioning. Eventually the product fails completely. The capacitors look and test good so the problem is assumed to be in unfixable circuitry and the product is discarded.
    Caps more reliable, larger, and with better ESR than the originals in the right places makes the circuit no longer marginal allowing the product to be as reliable and long lasting as the engineers originally intended.
    So far all indications are that this fix is perfect. All test runs have passed and the deployments I've done are working flawlessly. Fortunately I ran across another unmodified unit so I can provide scope pics.
    3191-Top: 12v at C289
    3191-Bottom: 3.3v at C291
    Cap testing at C289 shows that the 12v waveform can be smoothed out but it does not improve the 3.3v waveform. Cap testing at C291 shows the wave can be smoothed out substantially. Unfortunately a 1500uf cap test on C291 surprised the MT34063 and burned it and the IP175C and AR2317 and IS42S16400B out. APM9435 was still good. Fortunately I can get scope pics from another already serviced unit.
    C169: Rubycon MBZ 470uf 16v
    3192-Top: 12v at C289
    3192-Bottom: 3.3v at C169 with Rubycon MBZ
    3193-Top: 3.3v at C169 with Rubycon MBZ
    3193-Bottom: 1.8v at EC179
    Reducing the ripple from 40mv to 10mv on the 3.3v rail would be why this fix works so well. A better cap could reduce it even more.
    sig files are for morons
  • Brian10962001
    • Dec 2010
    • 6
    Re: Office Depot Ativa Wireless G Router AWGR54 by Belkin
    Very well done!
    • jakdedert
      • Jun 2010
      • 19
      Kudos! I have one of these disasters which failed to work right out of the box. In fact, I'm going to open a thread about failed wireless routers in general. The failure mode I experience most often is when the wired ports continue to work, but the wifi does not. Remote machines can 'see' the router, but cannot connect. This is common (for me) across many different models of many different brands. I almost always open them up, but not seeing anything obviously amiss, just set them aside. Your post gives me some hope that something 'could' be done with them.
      • grgz
        • 1
        Hello everybody, first post here.
        Found this thread from google and i'd like to add that exactly the same hardware is an access point from Airties, the AP-400.
        After two years of trouble free operation i'm facing the same problems with you.
        When you plug it on power all the leds are lightning but you can't connect on it either from ethernet or wirelessly, although you find it at the available wireless networks.
        I'm gonna try the solution mentioned above and i'm gonna give some feedback.
        • Lex-
          • May 2011
          • 18
          Hello severach,
          thank you for your interesting work, but please consider the following:
          Ok, but if you check the typical step-down application circuit on the MT34063M datasheet or even the MC34063A one, you can verify that the capacitor values are exactly the recommended by the manufacturer (Vin 100uf, Vout 470uf, Filter 100uf)...
          https://cdn.badcaps-static.com/pdfs/...286d7e48b9.pdf
          About the optional filter shown in datasheet, maybe the problem is that isn't really a filter on router circuit due the missing 1 uH inductor...
          Then maybe the main functional problem of these routers is related to the following note on datasheet:
          Application concerns:
          To get the best regulation performance, Low ESR capacitors at Vout are suggested.
          Then maybe the problem isn't really related to the capacitor value, probably is more related to use the correct or suggested (ESR) type of capacitor...
          Of course an interesting experiment to clarify this issue can be the use of the Rubycon MBZ 470uf 16v in place of C291 (not C169), and check the waveforms with the scope again, let us know what you think.
          Thank you.
          • severach
            • Aug 2007
            • 1055
            The sample with the 470uf and 100uf have a coil in between to make up a PI filter. The 1.8v supply has a coil but the 3.3v supply doesn't. The trace runs from C169 to C291 with no filter coil and the two capacitors are almost equidistant from the buck coil so swapping the position won't have any effect.
            For some units the upgraded capacitor isn't enough. They last longer than the 5 minutes they used to but eventually lock up in a few days. I've had units where only the radio manager process crashes and other units where the entire processor crashes. All the ones I have back have a small puck for a heat sink and not the finned heat sink as shown. Some still crash with oversize heat sinks.
            Turns out there aren't many wireless routers that can be fixed with one cap. This one was because the 1.8v supply was well made. Only the 3.3v supply was a poor design. Most other units more supplies and many supply disasters. Keeping stable power to the processor isn't easy when a transmitter is pounding the supply constantly.
            • shadow666
              Router Xiaomi M4A Gigabit
              by shadow666
              hello
              i need dump backup for wifi router Xiaomi M4A Gigabit M43 R0101
              Mi Router 4A Gigabit Edition
              ROM CHIP is 16 MB
              i attached picture of motherboard​...
              11-30-2024, 03:49 PM
            • EasyGoing1
              UPNP, "Standards" and hardware that implements it
              by EasyGoing1
              I've been writing a program in Java that is really just a robust front end for the use of GitHiub Gists, providing a nice interface for developers to organize, maintain and access code snippets that we tend to need from time to time in our different projects.
              One of the features of the program is the ability for people to share their Gists with others who use the program over a LAN or over the Internet. The program just basically serializes a Java class and encrypts it then wraps it into a UDP datastream and sends it over to another user.
              So I decided to implement UPNP...
              07-16-2022, 07:12 PM
            • MrCreosote
              2 Belkin KVM switches have dim VGA output
              by MrCreosote
              When compared to a direct VGA connection, these 2 switches both output a darker image. The switches are:
              4-port Omniview Pro2 f1dz104t
              8-port Omniview either f1da108t OR f1dz108t (look and function same, OSD may be only difference.)
              The 4 is dimmer, the 8 is massively dimmer - both with same AC adapter and cabling.
              AD ADAPTER:
              There were issues with previous AC adapter, it failed during lightning strike that blew up TV and other stuff and tripped a 15 amp breaker in the main panel which also had a whole house Cutler Hammer surge...
              08-15-2023, 08:26 PM
            • hinisa
              Xiaomi router freezes at boot after re-capping
              by hinisa
              I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
              When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
              After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
              Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
              07-08-2023, 05:58 AM
            • spleenharvester
              Synology MR2200ac mesh router, UART connection - login details?
              by spleenharvester
              This particular unit powers up, LEDs behave normally, but broadcasts no SSID, will not mesh with any other routers. Plugging in an ethernet cable from a Windows laptop results in "unidentified network" with an autoconfigured IP address and no response to pinging 192.168.1.1.
              I was able to log into serial/UART by connecting the 6-pin header to the GPIO on a Raspberry Pi Zero W (GND to GND, TxD to RxD, RxD to TxD, no connection between +3.3V as it is supplied on both sides) using Minicom, command:
              Code:
              sudo minicom --baudrate 115200 --device /dev/ttyS0
              09-02-2024, 01:19 PM
