Asus P5N-T Deluxe : Help testing & understanding vrm.
  • Gabriel
    • Jan 2010
    • 620
    • Norway
    Ok, got this mb - it does power up but does not post.
    I thought this was the perfect time for me to measure and understanding the vrm circuit.
    I did read the guide for vrm testing written by AK0R but did not understand everything.
    There are two rows of voltage regulators, the inner row is 5525L and the outer row is 9025L.
    Here are my voltages with mb on, I used gnd in the p8 plug on all of these.
    Outer row towards back of mb.
    Drain - 12.01V (mounting base)
    Source - 1.27 V (pin 1,2 and 3)
    Gate - 2.31 V
    Inner row towards back of mb.
    Drain - 1.27V (mounting base)
    Source - 0V (pin 1,2 and 3)
    Gate - 10.47V
    Outer row top of mb
    Source - 1.26 V (pin 1,2 and 3)
    Gate - fluctuate between 1.289 to 1.296V
    Inner row top of mb
    Drain - 1.26 V (mounting base)
    Gate - fluctuate between 0.255 to 0.231V
    Does this seem right or should I be worried ?
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Asus P5N-T Deluxe : Help testing & understanding vrm.
    You aren't going to get any useful readings from the gate unless you have an oscilloscope or a meter with frequency reading. Also when you read the gate you always read between gate and source, not between gate and ground, because what you have there is a synchronous buck converter where the high side MOSFET is some volts above ground.
    Measure voltage at the CPU caps. If you get 1.something volts then Vcore is okay. If Vcore is okay, it's most likely failed BIOS.
    A working TV? How boring!
    • seanc
      • Nov 2008
      • 1319
      Or if it's gone the same as a P5N-E SLI I had - could be a failed northbridge.
      • Gabriel
        • Jan 2010
        • 620
        • Norway
        Ahh did not know the right steps for measuring gate, I updated my measurements.
        Gate - 1.041 V
        Gate - 10.47V
        Outer row top of mb
        Gate - fluctuate between 0.023 - 0.030
        Inner row top of mb
        Gate - fluctuate between 0.255 to 0.31
        I have 1.265 over the cpu caps.
        Bios is ok, I know for sure.
        • Gabriel
          • Jan 2010
          • 620
          • Norway
          Took the heatpipes off, tried to press down on the nb,sb and the 200 chip incase of bad bga.
          Hope the main chips is ok.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            1.265v means the CPU VRM is likely operating in spec. How can you be sure it's not a bad BIOS chip. They can go bad by themselves.
            • Gabriel
              • Jan 2010
              • 620
              • Norway
              Bios chip both reads,programs and verifies ok, I also tried to program another chip - still no post.
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                • Romania
                Then check the other power supplies for the northbridge and southbridge. There should be one 3.3v and one that depends on the chipset, 1.something volts.
                • seanc
                  • Nov 2008
                  • 1319
                  Take the heatsink off and look at the northbridge chip & heatsink. There were visible scorch marks on mine.
                  • Gabriel
                    • Jan 2010
                    • 620
                    • Norway
                    No scorch marks on heatsinks or chips, northbridge,southbrige and cpu get warm so they get power.
                    • Scenic
                      o.O
                      • Sep 2007
                      • 2642
                      reflow northbridge.
                      nvidia chipset (nForce 780i SLI). dead giveaway there are gonna be problems with it..
                      • brethin
                        • Dec 2008
                        • 1907
                        Try a post card and see where its hanging on boot, guessing at shit will get you nothing and jumping right into the board with a scope or meter is pointless if you don't know where the problem lies.
                        • Gabriel
                          • Jan 2010
                          • 620
                          • Norway
                          Are these post cards any good ? have you tried them ?
                          I see lots of them on ebay, are there a type that works better then others ?
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            It's not a complicated thing for them to build.
                            Most of them [even the more expensive ones] are the same Chinese junk builds,, ,, but most of them do at least work.
                            The difference between a good or bad one is the documentation you get with it.
                            The code it comes up with needs to be de-coded to mean anything and it's not the same codes for all mobos.
                            One that comes with most of the codes in the documentation will save you some time searching codes on the web.
                            Unfortunately few come with complete de-coder tables.
                            Also there are now 2-digit and 4-digit codes.
                            Since you don't know which you will need for any given mobo it's best to get one that displays both 2 and 4 digit codes.
                            Some do that with a switch and others simply have two read-outs.
                            The ones that talk about USB in the ad usually only get POWER through USB.
                            It needs to be connected by the interface it has plus USB to work.
                            Kinda dumb because any interface you would connect it to has power pins available already.
                            Mann-Made Global Warming.
                            - Dr Seuss
                            • Scenic
                              o.O
                              • Sep 2007
                              • 2642
                              i've bought a chinese cheapo card (under 10eur incl. shipping) from ebay seller virtualvillage ages ago. my card seems to be model number LP50A1
                              does what it's supposed to but not more. has a PCI connector and a parallel port connector.
                              the USB port on that card is just for 5V power if you're using the parallel port (on laptops for example). if you're using it in a PCI slot you won't need it.
                              has a little piezo noisemaker on it that you can connect to the board's speaker pins if it doesn't have one and a row of LEDs for -12V, +12V, +5V, IRDY, CLK, +3.3V, RESET, FRAME.
                              manual is (of couse) in finest engrish, but it at least lists all the possible codes and explains the "menu" of that card (self-test, scrolling through previous POST codes, 2 or 4 digit operation, beep codes etc. ...)
                              helped me out countless times on seemingly dead boards so far..
                              http://bambooz.pytalhost.net/badcaps/post1.jpg
                              http://bambooz.pytalhost.net/badcaps/post2.jpg
                              suprisingly, they still exist about 2 or 3 years after i bought this card. their website is slow as hell & pretty cheesy though.
                              http://www.61131568.com
                              • Uranium-235
                                Comrade Glimmer
                                • Aug 2007
                                • 5042
                                • US
                                wow, 2003-2023! this cards from the future guyz!
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  Actually the © for most corporate works is 95 years so 2003-2098 would be more correct.
                                  - Dr Seuss
                                    MSI Gaming Raider GE76 12UHS-690CA Deluxe Edition Notebook GE Specification for Upgrade or Repair
                                    This specification for the MSI Gaming Raider GE76 12UHS-690CA Deluxe Edition Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Raider GE76 12UHS-690CA Deluxe Edition boardview and Raider GE76 12UHS-690CA Deluxe Edition schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                    09-07-2024, 06:40 AM
                                    MSI Gaming GE66 DELUXE EDITION 12UHS-481IT Notebook GE Specification for Upgrade or Repair
                                    This specification for the MSI Gaming GE66 DELUXE EDITION 12UHS-481IT Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GE66 DELUXE EDITION 12UHS-481IT boardview and GE66 DELUXE EDITION 12UHS-481IT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                    09-07-2024, 05:20 AM
                                    MSI Gaming GE76 DELUXE EDITION 12UH-689IT Notebook GE Specification for Upgrade or Repair
                                    This specification for the MSI Gaming GE76 DELUXE EDITION 12UH-689IT Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GE76 DELUXE EDITION 12UH-689IT boardview and GE76 DELUXE EDITION 12UH-689IT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                    HP EliteDesk 800 35W G2 Mini + EliteDisplay E242 + PC Mounting Bracket EliteDesk 800 i5-6500T Specification for Upgrade or Repair
                                    This specification for the HP EliteDesk 800 35W G2 Mini + EliteDisplay E242 + PC Mounting Bracket can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 35W G2 Mini + EliteDisplay E242 + PC Mounting Bracket boardview and EliteDesk 800 35W G2 Mini + EliteDisplay E242 + PC Mounting Bracket schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...
                                    09-12-2024, 03:28 PM
                                    MSI Gaming GE66 12UGS-462AU Raider Deluxe Edition Notebook GE Specification for Upgrade or Repair
                                    This specification for the MSI Gaming GE66 12UGS-462AU Raider Deluxe Edition Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GE66 12UGS-462AU Raider Deluxe Edition boardview and GE66 12UGS-462AU Raider Deluxe Edition schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
