#21 |
Grumpy Old Fart
City & State: Phoenix, AZ
Line Voltage: 120V 60Hz
Too bad.
So sad.
Mann-Made Global Warming. - We should be more concerned about the Intellectual Climate. - Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind. - Dr Seuss - You can teach a man to fish and feed him for life, but if he can't handle sushi you must also teach him to cook. - |
#22 |
City & State: Alberta
My Country: Canada
Line Voltage: 120VAC 61Hz
I'm a: Hobbyist Tech
Where I work, 32 bit at the desktop 64 bit on the servers.
Some servers need it, not all, but no matter 64 bit OSes run just fine. Hell, most modern hypervisors (ESXi, XenServer etc.) won't run on 32 bit hardware. I had one app that was a pain to get working on 64 bit Linux, but worked around it. 4GB is fine for almost any desktop, even high-end photoshop work doesn't need more than 4. Maybe some engineering apps might but those aren't the norm. Even my test box that runs VMWare workstation only has 4gb. and I can run XP Vista and7 on it at the same time.
36 Monitors, 3 TVs, 4 Laptops, 1 motherboard, 1 Printer, 1 iMac, 2 hard drive docks and one IP Phone repaired so far.... |
#23 |
Grumpy Old Fart
eBay, Google, Yahoo, MySpace...
All these things ran just fine on 32-bit for YEARS. [Including their data bases.] - And it would still work the same today... . This perceived 'need' is primarily based on the 'want' to use newer software. [Which often is the desire of the clueless 'suits' calling the shots.] . |
#24 | |
Okok, I admit, it was not actually reading comprehension fail
I was just too lazy to reply to all of your points I'll cherry pick just one, the 20000 users forum, I still don't see where you mentioned if it was active users or dormant accounts. I mean it's a bit different with a 20000 users forum where we have 10 active users and the rest have not logged on in the past 6 months... Quote:
"The one who says it cannot be done should never interrupt the one who is doing it." |
#25 |
Radioactive
City & State: tehas
My Country: US
Line Voltage: 120VAC 60Hz
thats just mysql hard drive data, but when someone logs in, the caches login data in a mysql table that gets read and then kept in active ram for performance reasons. this also depends on what forum you're using. I think VB does this, not sure about PHPBB, its been suuuch a long time since i've dealt with those, or even modified them, which I did years ago
#26 | |
City & State: Norway
4GB is also mostly a Microsoft limit on the desktop OS. Intel processors has since long ago supported PAE, making 4GB available for each application. Microsoft claims this limitation to be due to some "driver instabilities". If that was the case, the solution would be to fix the drivers, not cripple the OS. And, wouldn't the same driver issues be present in their 32-bit server OS', that support up to 64GB? Obviously, who would buy their 64-bit versions, if one could get almost the same with the 32-bit version? |
#27 | |
Actually if you buy retail you get both DVD's in the package Only OEM is locked to a specific branch (x86 or x64) And PAE is a piece of crap, trust me, I have tried to use it. So many vendors write crappy drivers it is just sad, and PAE has larger overhead than true x86-64, it also only goes up to 36bit addressing or something like that so it would only put off the inevitable by a few years (well, unless you want to keep using your old apps, but then there would be no need to upgrade at all would there?) Last edited by Per Hansson; 07-01-2011 at 09:08 AM.. |
#28 | |
As for pricing, the reality is that most PC's up till recently (and many still do) came pre-installed with some kind of 32-bit OEM, forcing owners to buy a new license for access to more than 4GB. The same on the server side; how many small businesses has not bought a Small Business-server, only to discover they need a new license to upgrade their RAM? Obviously, there are no financial motivation here... |
#29 | |
Grumpy Old Fart
PAE basically creates a system where TWO maps need to be referenced to find a memory location. The second map is located in Virtual Memory. Both maps must be accessed to find a memory location. - It allows more RAM but slows RAM access times down. Microsoft recommended NOT using it except for servers up until XP. Since XP they only suggest it for very specific situations. http://msdn.microsoft.com/en-us/wind...dware/gg487503 http://msdn.microsoft.com/en-us/wind...e/gg487512#EVG And as to being beneficial for applications MS says a small number will benefit but as a general rule they won't. [In one of the links.] IOW: PAE is not a performance enhancement, it's band aid for some very specific problems. BTW: "Fast RAM" in servers isn't the case. ECC and/or Registered RAM is slower than run of the mill Unbuffered RAM at the same advertised clock speed. IOW: The idea that 'if I build my desktop like a server it will be faster' is bunk. You can do -more- at the same time but you won't be doing it faster. - That also applies to using PAE. ~~ That said; The fact that 32-bit Servers can use PAE to get use of more RAM supports that fact that 64-bit hardware isn't really needed to get the job done. . Last edited by PCBONEZ; 07-01-2011 at 10:08 PM.. |
#30 |
City & State: Rockhampton, Queensland, Australia
My Country: Australia
Line Voltage: 240VAC 50Hz
I'm a: Hobbyist
I once thought that the original Pentium onwards was 64-bit, but only the data bus was actually 64-bit and the core was actually 32-bit.
My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics. |
#31 | |||
Grumpy Old Fart
- But I did NOT say a forum. Forums aren't that demanding. Quote:
What would the bandwidth be for 20000 people simultaneously using chat & IM & with photo heavy profiles [some with videos] be? [The model 'social media' site was an adult personals site in aid of using a heavily loaded model.] - The 20000 accounts was for ONE server in a data center that supported something in the millions of users. Looking back at my emails they actually said 20,000 to 30,000 accounts per server. My own survey [done over 3 months] found % logged in varied between 1% and 7% depending on time of day and day of week. [I was finding how much monthly bandwidth I would need to pay for in order to support X-many users. Needed that to determine the absolute lowest price I could charge for the service without going into the red. Also needed to know peak bandwidth for x-many users so I didn't overload my hosts machines at 'prime-time'. - And to know when I'd need multiple servers and load balancers.] ~~ I actually did this analysis on 3 or 4 different sites. Anyway, you don't need x64 for a heavily loaded server. Servers with dual Tualies were on the way out but still fairly common when I did all that. X64 wasn't even around. . Last edited by PCBONEZ; 07-01-2011 at 11:19 PM.. |
#32 | |
The Boss Stooge
There are a lot of applications that love 64-bit and high amounts of memory, but for most web servers, the demand isn't worth upgrading JUST for 64 bit. If you're in need of a new server, you're silly to build on 32 bit, just because you'll be locked in at the 4gb barrier, and 64 bit hardware isn't anymore expensive these days....and its all backward compatible with 32 bit stuff. FWIW, my home system is a dual quadcore xeon E5520 w/ 24gb RAM, running XP x64 (it screams).... Pretty useless for what I do unless premiere gets crazy rendering something (rendering HD video is a massive resource hog, RAM and CPU)....then it'll start gobbling up the memory. Most home users who check email and web browse, a P4 3GHz with 1gb of RAM is fine....but overkill be thy name, and I built this beast because I wanted to......well, and I wanted to climb the F@H ranks amongst our members....HAHAHA *waits for Mikey*As far as software and driver incompatibilities between 32 and 64 bit, I haven't encountered any with the hardware I have....but then again, its high-end workstation/server grade stuff... x64 didn't scream about any of the drivers....
<--- Badcaps.net Owner & Forum Administrator!! Badcaps.net Services: Premade Capacitor Kits Badcaps.net Capacitor Master List Motherboard Repair Services If you've come here in search of replacement capacitors or repair services, please use the links above. ![]() ---------------------------------------------- Badcaps.net Forum Members Folding Team http://folding.stanford.edu/ Team : 49813 Join in!! Team Stats |
#33 |
City & State: Canterbury
My Country: New Zealand
Line Voltage: 230VAC 50Hz
I'm a: Forum Junkie
As for driver issues just get new hardware I need to get a new printer my printer is from before win xp. my x64 machine is cheaper to build than a x32 and hay if it is still alive in 10 years x64 may be the norm.
My pc CPU : AMD PHENOM II x4 @ 3.5Ghz MB : ASUS M4A89TD PRO USB3 RAM : Kingston ValueRAM 16gb DDR3 PSU : Cooler Master 850W Silent Pro GPU : ATI Radeon HD 6850 |
| Thread Tools | |
| Display Modes | |
