Samsung SyncMaster 275T power supply
  • sdv
    • Nov 2011
    • 4
    Power supply (BN44-00163A) don't work.
    CN802
    18V - no
    5.3V - no
    ST5.2 - yes
    CN803
    24V- no
    F9223L
    Pin 4 - 0
    Pin 7 - 19.2V
    Pin 10 - 4.90V
    Pin 11 - 4.54V
    Pin 12 - 4.90V
    Pin 13 - 3.01V
    Pin 14 - 0.72V
    Pin 15 - 4.90V
    Pin 16 - 0V
    Pin 23 - 384V
    I don't have circuit BN44-00163A, but I see BN44-00173A from topic Samsung Syncmaster 245BW
  • PlainBill
    • Feb 2009
    • 7034
    Re: Samsung SyncMaster 275T power supply
    CN802
    18V - no
    5.3V - no
    ST5.2 - yes
    CN803
    24V- no
    F9223L
    Pin 4 - 0
    Pin 7 - 19.2V
    Pin 10 - 4.90V
    Pin 11 - 4.54V
    Pin 12 - 4.90V
    Pin 13 - 3.01V
    Pin 14 - 0.72V
    Pin 15 - 4.90V
    Pin 16 - 0V
    Pin 23 - 384V
    Pictures of the power supply would be helpful. It is likely the circuit is similar to the BN44-00173A. A schematic is attached to this post.
    By the voltage, it appears the F9223L is working. That leaves three possibilities.
    1. A short on the load - either the main board or the inverter. Try disconnecting the inverter. With a picture of the power supply I could suggest a way to turn on the main supply.
    2. A short of one of the output rectifiers would also cause the same symptoms.
    3. There probably is an 18 nF 630 volt poly cap tied to pin 23 of the F9223L. This provides the return for the primary of the main SMPS. If that is bad, there will be no output from the main SMPS.
    PlainBill
    • sdv
      • Nov 2011
      • 4
      PlainBill
      I have replaced capacitor CM802 and now pоwer supply is good.
      But the image is not present, also the screen poorly flickers
      The inverter bad?
      http://www.shopjimmy.com/samsung-gh1...t-inverter.htm
      • alexanna
        • Mar 2010
        • 1346
        The inverter bad?
        I don't think I fully understand the problem you are having at the moment?
        On the 24” power supply there has, been and I have also experienced severe flickering of the backlights when the large capacitor that never fails, WELL fails.
        • sdv
          • Nov 2011
          • 4
          The pleasure was premature. Power supply is not good.
          I have put a power supply from other monitor and the monitor has work.
          On a bad power supply voltage 24V changes under loading on 1v downwards, at this time the voltage 392V goes down approximately on 10V
          • sdv
            • Nov 2011
            • 4
            Thanks, has really helped. I have replaced large capacitor CP803 and power supply have earned.
            • goodcapsbadcaps
              • Apr 2015
              • 2
              hello anyone know where to find the logic board for the 275T samsung monitor
              thanks
              • skelband
                • Feb 2020
                • 6
                Just an update on this issue.
                I too had the exact same issue as the poster with this monitor supply.
                Replacing CM802 also did the trick for me. Seems to be a failure point for this PSU.
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                  09-07-2024, 05:50 AM
                • cheeky2
                  Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                  by cheeky2
                  This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                  I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                  Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                  06-15-2025, 05:12 AM
                  by sam_sam_sam
                  03-31-2024, 02:12 PM
                • soopacrucial
                  Samsung Syncmaster 740BF repair
                  by soopacrucial
                  Hi folks,
                  I'm new here and was wondering whether you might be kind enough to give me some advice on troubleshooting the following problem:
                  Quite a few years ago now, a couple of years from new, my Samsung Syncmaster 740BF LCD monitor starting playing up by making a buzzing noise and then the display would go blank. I seem to remember the blue power led would also go off when this happened but that I'm not 100% sure of. By pressing the power button I do remember I could at first get it working again but eventually the problem would come back. At the time I had read about...
                  10-29-2024, 02:40 PM
