Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > General Electronics
Old 12-20-2011, 08:53 AM   #1
amelbye
Default Can a capacitor have low ESR and still be bad?
I'm wondering, because I just swapped out a bunch of high ESR caps from a power supply, and the unit went from faulty to dead...
I checked the ESR on all the parts I put in (didn't have enough new parts around, so I took some from a project I've given up on)
Could it be that some of the replacement capacitors have other problems that doesn't affect their ESR readings?
amelbye is offline   Reply With Quote
Old 12-20-2011, 09:25 AM   #2
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
City & State: Phoenix, AZ
Line Voltage: 120V 60Hz
Default Re: Can a capacitor have low ESR and still be bad?
If a cap is shorted it will read low ESR.
The way to tell is to also check DC resistance with a DMM.
If it reads low on both it's a shorted cap.
Most caps won't have to be pulled to check resistance.
Only need to pull the ones that read low to make sure it's not a parallel resistance issue.
If they read high in circuit they will still read high out of circuit.
Also check that you didn't make a solder bridge or a cold joint somewhere.
Mann-Made Global Warming.
- Dr Seuss
PCBONEZ is offline   Reply With Quote
Old 12-20-2011, 06:15 PM   #3
b700029
Banned
The capacitance could also be too low.
b700029 is offline   Reply With Quote
Old 12-21-2011, 07:15 PM   #4
Agent24
Fuhjyyu Killer
Agent24's Avatar
City & State: Behind a soldering iron
My Country: New Zealand
Line Voltage: 230V AC 50Hz
What was the original fault?
Do you know what ESR value the old capacitors _should_ have been? If your new ones had ESR much lower compared to what the originals had when they were brand new that can also cause issues.
(Though I believe that the PSU will still work in such a case, but you will get worse ripple than there should be)
Agent24 is offline   Reply With Quote
Old 01-05-2012, 06:13 PM   #5
999999999
City & State: Near Cincinnati, OH
Line Voltage: 120VAC 60Hz
How do you define "faulty" as it was previously? Were the caps visibly vented? I am wondering if you simply caught a PSU fault in its early stages and the existing damage got worse. Electronics like to do that the *next* time they're cold powered on.
999999999 is offline   Reply With Quote
