#1 |
When I push the power button the board powered up but no display, POST or even beep. It has the so called "solid capacitor" but underneath the processor's heatsink was very hot and I could see the brownish discoloration of the PCB. Is the "solid capacitor" prone to badcap or an exemption?
#2 |
Unknown
My Country: Australia
Line Voltage: 240V 50Hz
The solid capacitors aren't prone to failure and are not the cause of your problem. It sounds like a partially shorted VRM may be the cause fo the problem. Since its an ASUS board, it wouldn't surprise me at all.
I love putting bad caps and flat batteries in fire and watching them explode!! Main PC: Core i5 660 3.33GHz, Gigabyte GA-P55-UD3R, 4GB Kingston DDR3 1333, 750GB WD HDD, Sony Optiarc DVD RW, nVidia GTX295 1760MB, Antec 1200 Case, Delta DPS-750CB 750W PSU, Hauppauge TV Tuner, Windows XP Pro. Main Laptop: Lenovo Thinkpad T60: Core 2 T2500 2GHz, 2GB DDR2, 80GB HDD, DVD RW, Intel Graphics, Windows XP Pro. 2nd Laptop: Toshiba Satellite A200: Core Duo 1.73GHz, 2GB DDR2, 60GB HDD, DVD RW, nVidia GF Go 7300 Graphics, OpenSUSE 12.2, Fan Mod |
#3 |
This model commonly has failed NIKOS MOSFETS near the coin-cell battery.
...Their plight, in fact is even worse, they don't realize that they're cantonists, they think they're free men. What a slavery that is - to confuse slavery for light, and bitter darkness for bright light. -Rabbi Menachem Mendel Schneersohn |
#4 |
Thanks c_hegge & mockingbird for the info. I will test the component involved and replaced it. Thanks
#5 |
The Adventurist
City & State: Bassien
My Country: India
Line Voltage: 220VAC 60Hz
ME too have the same problem with the same motherboard. Do you know what replacements should i use for those mosfets?
#6 |
Grumpy Old Fart
City & State: Phoenix, AZ
Line Voltage: 120V 60Hz
Not without a part number.
Mann-Made Global Warming. - We should be more concerned about the Intellectual Climate. - Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind. - Dr Seuss - You can teach a man to fish and feed him for life, but if he can't handle sushi you must also teach him to cook. - |
#7 |
You will need either a really hot iron with a flat-tipped bit or a reflow gun with a really narrow nozzle to take the old MOSFET off. This is the only time when my 30W iron is not able to do the job. Like PCBONEZ says, post the part number.
#8 |
The Adventurist
My Country: India
Thank for replying.
Ok, This is what I found. Nikos P09036BDG VN38J1M12 |
#9 |
![]() I think these will work fine, but please ask PCBONEZ to confirm: http://search.digikey.com/ca/en/prod...8CT-ND/1154651 http://search.digikey.com/ca/en/prod...PBF-ND/1300684 http://search.digikey.com/ca/en/prod...0CT-ND/1305821 http://search.digikey.com/ca/en/prod...8-1-ND/2170236 There are more available on Digikey. |
#10 |
The Adventurist
My Country: India
Thanks a lot for this info. CHEERS
#11 |
Grumpy Old Fart
I'm not proficient in transistor swapping. [Hardly ever do it..]
Better to ask Toasty if you need confirmation. . |
#12 |
City & State: Manila
My Country: Philippines
i have the same board, it work fine with pentium 4, 2.66GHz but on other higher processor, it freezes and sometimes it won't POST...any idea will be highly appreciated...thanks
| Thread Tools | |
| Display Modes | |
