Go Back   Badcaps Forums > Motherboards with Bad Capacitors > Abit - Asus - Aopen
Old 02-26-2012, 02:23 PM   #1
badguyswant
Post Asus A8N-SLI Deluxe
Hello to everybody on this forum. i received this board from a buddy who said he couldn't get it to post. Iv got it to post but when i load all 4 ram slots up with ram it does not post. but a single stick it will post just fine. also when trying to install windows it is extremely slow and it will eventually just freeze up. These are the caps on the board. None appear to be bulging though.
5 1500uf 6.3v KZG
6 1000uf 16v Rubycon MBZ
22 820uf 6.3v OST RLX(not sure what series this is)
2 470uf 16v KZG
Will replacing these caps mabye make the board stable? Thanks for any help. If you need a picture i will try to post one.
badguyswant is offline   Reply With Quote
Old 02-26-2012, 02:41 PM   #2
shovenose
404 Not Found
shovenose's Avatar
City & State: Fairfax, California
Line Voltage: 120VAC 60Hz
I'm a: Forum Junkie
Default Re: Asus A8N-SLI Deluxe
KZG capacitors are known to failwithout bloating.
The OST are crap too. (RLX is the series, OST is the manufacturer).
The Rubycon caps are high quality; do not bother replacing them.
Keep in mind this motherboard has a "faulty" nVidia chipset... that may or may not be causing any of your issues.
Firefox is named after a fox - WRONG! That orange thing is a Red Panda, not a fox!!
http://www.youtube.com/watch?v=y6GaPkkGZGw
PSU Pr0n
http://www.psudatabase.com/
shovenose is offline   Reply With Quote
Old 02-26-2012, 02:59 PM   #3
badguyswant
Thanks for you reply shovenose. i really appreciate it. i have found some replacements for the KZG and OST. for the 1500uf 6.3v can i use 1500uf 6.3 caps they say 105C FJ on the side. same as for the 820 6.3v they same FJ on the side. Thanks!
Old 02-26-2012, 03:07 PM   #4
c_hegge
Unknown
c_hegge's Avatar
My Country: Australia
Line Voltage: 240V 50Hz
No it doesn't. The nForce 4 was the last good chipset. Remember, this board is a s939. It's only sAM2, 775 and possibly some AM3 chipstes that were affected. What usually goes wrong with these boards is that the chipset fan quits which cooks the chipset (or they just get the ASDS/ Asus Sudden Death Syndrome).
Main PC: Core i5 660 3.33GHz, Gigabyte GA-P55-UD3R, 4GB Kingston DDR3 1333, 750GB WD HDD, Sony Optiarc DVD RW, nVidia GTX295 1760MB, Antec 1200 Case, Delta DPS-750CB 750W PSU, Hauppauge TV Tuner, Windows XP Pro.
Main Laptop: Lenovo Thinkpad T60: Core 2 T2500 2GHz, 2GB DDR2, 80GB HDD, DVD RW, Intel Graphics, Windows XP Pro.
2nd Laptop: Toshiba Satellite A200: Core Duo 1.73GHz, 2GB DDR2, 60GB HDD, DVD RW, nVidia GF Go 7300 Graphics, OpenSUSE 12.2, Fan Mod
c_hegge is offline   Reply With Quote
Old 02-26-2012, 04:00 PM   #5
selldoor
Slow Learner
City & State: Lancashire UK
How much Ram? 4 sticks of what? matched pairs?
What Bios is it running?
selldoor is offline   Reply With Quote
Old 02-26-2012, 04:21 PM   #6
mockingbird
mockingbird's Avatar
Send a message via AIM to mockingbird
5 1500uf 6.3v KZG
2 470uf 16v KZG
Leave the 16V 1000uF Rubycon MBZ. Replace everything else.
The 6.3V 1500 KZG, 6.3V 820uF RLX and 16V 470 KZG are all 8mm and should be replaced with equivalents. Rubycon MBZ/MCZ, Sanyo WG, Nichicon HM/HN and Samxon GD/GC are all good replacements and these boards work great once they're re-capped. Again, make sure to get 8mm caps.
You better be proficient at soldering. The lead holes are very small so there's always a risk of ripping off the pads if you don't have the proper technique/equipment (It can be done with cheap equipment if you have good technique).
...Their plight, in fact is even worse, they don't realize that they're cantonists, they think they're free men. What a slavery that is - to confuse slavery for light, and bitter darkness for bright light.
-Rabbi Menachem Mendel Schneersohn
mockingbird is offline   Reply With Quote
Old 03-01-2012, 08:50 PM   #7
badguyswant
Replaced All KZG and OSt with Panasonic FJ. board works fine now went under prime 95 blend for a full 24 hours without error. All ram slots are working properly now. Thanks For the help shovenose, C_hegge and mockingbird. now to find out what i should do with this board. Might build a server out of it or something. Thanks again!
Old 03-01-2012, 09:01 PM   #8
badguyswant
Also having trouble updating bios
Old 03-01-2012, 10:31 PM   #9
mockingbird
What's the problem? You do so from DOS. I beieve asus uses aflash or something like that. Hook up an old floppy drive and make a boot disk from Windows. Get rid of some of the unecessary stuff on the boot disk so that you'll have rom for aflash and the bios file. Flash away.
IF you want, I can look up an SLIC 2.0 Bios for you. I'm almost certain there's one floating around.
Old 03-02-2012, 10:33 AM   #10
mariushm
City & State: Romania
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
If you don't have a floppy, get the ISO image of FreeDOS from here: http://www.freedos.org/freedos/files/
Add the bios image plus the dos aplication to the ISO image using PowerISO or any other freeware/shareware.
Then, burn a CD/DVD image, boot from computer from CD/DVD and flash the bios.
mariushm is offline   Reply With Quote
