Go Back   Badcaps Forums > General Topics > General Computer Discussion
Old 03-19-2012, 04:06 PM   #1
NxB
NxB's Avatar
Default AMD AM2 motherboards Ram Shorted
I have 2 AMD AM2 motherboards that have been confusing the heck out of me. In both something is shorted in the ram section. I checked out the mosfets and the caps but short remains.
One is a TA790GXB... capacitor went out near the ram and I replaced it. Worked fine for a little bit and then poof. Cap appears fine, I changed a few others but no dice. Also changed 2 mosfets but issue remains.
The other is a M2RS485-BTX.. no obvious caps but short throughout 5v. Caps in almost the same spot as the TA790 are shorted as are mosfets in the same section but the component thats actually out is somewhere else. I've pulled most of them off the board and they tested good.
Anyone else have ram issues on AMD AM2 stuff? What did it end up being?
NxB is offline   Reply With Quote
Old 03-19-2012, 06:13 PM   #2
NxB
NxB's Avatar
Default Re: AMD AM2 motherboards Ram Shorted
I got the second board working... I changed 2 caps near the 5v to 3.3v regulator. It still looks shorted tho... but system works. I don't get it.
Old 03-19-2012, 06:29 PM   #3
mockingbird
mockingbird's Avatar
Send a message via AIM to mockingbird
The Biostar board has a bunch of OST caps near the RAM slots... Did you change ALL of them?
...Their plight, in fact is even worse, they don't realize that they're cantonists, they think they're free men. What a slavery that is - to confuse slavery for light, and bitter darkness for bright light.
-Rabbi Menachem Mendel Schneersohn
mockingbird is offline   Reply With Quote
Old 03-21-2012, 09:16 AM   #4
NxB
NxB's Avatar
Not ALL of them. I should hit that board next when I find the CPU. But why would caps appear shorted and have 0 ESR and then be fine out of circuit?
I fixed the HP board because another suspect cap appeared open in circuit then puffed up during testing.
Old 03-21-2012, 09:49 AM   #5
Uranium-235
Radioactive
Uranium-235's Avatar
City & State: tehas
My Country: US
Line Voltage: 120VAC 60Hz
cause unless you trace the other components to that cap, you never know what the total resistance is going to be 'in circut'. Theres tons of components put together that can create a reading like that
Uranium-235 is offline   Reply With Quote
Old 03-25-2012, 09:04 PM   #6
severach
City & State: Michigan
I'm a: Hobbyist Tech
Caps supplying a northbridge or CPU or other high power chip often look shorted when the component is in place.
severach is offline   Reply With Quote
Old 03-25-2012, 09:58 PM   #7
b700029
Banned
I second this. All chips have protection diodes too, which can cause the readings to be different if you reverse the multimeter probes.
Modern CPUs draw over 100A peak at 1.x volts; that is an effective resistance of ~10mOhm. This is when they're actually operating since CMOS circuits ideally only draw power on clock transitions, but in CPUs the leakage current through the MOSFETs even when idle with the clock stopped is not small - quoting Intel on the "8-9W" idle power consumption of the recent i7s, that's 5-6A at the 1.x volt supply, meaning the CPU has a static resistance of < 1 ohm.
b700029 is offline   Reply With Quote
