Go Back   Badcaps Forums > General Topics > General Computer Discussion
Old 04-10-2012, 10:04 PM   #21
Uranium-235
Radioactive
Uranium-235's Avatar
City & State: tehas
My Country: US
Line Voltage: 120VAC 60Hz
Default Re: My Latest 8-core Project
Originally Posted by mariushm View Post
Even ECC RAM is not that special, as some AMD chipsets support it on regular motherboards.
its the am2/3 processors themselfs that support ECC, but only asus boards have the option to enable it
One of the main things that server boards i've seen that gives advantages over regular boards is the onboard management software. Turn one off/on flash bios and some will let you even kvm it remotely.
aside from that, I put the hardware quality up there for some of them with gigabyte, some, like supermicro are even better
Uranium-235 is offline   Reply With Quote
Old 04-10-2012, 11:33 PM   #22
shovenose
404 Not Found
shovenose's Avatar
City & State: Fairfax, California
I'm a: Forum Junkie
My $0.02:
Quality servers are an investment. A good one.
Junky "servers" are a big pain in a @$$...
That said, I don't need 100% uptime for a Minecraft server or whatever else I choose to stick in my closet. I only have one "server" that needs to be up 100% of the time, and that's a gutted HP case with a re-capped ancient 250W SPI/FSP power supply that I probably recapped the bulged Cheapo Teapo with a Fuhjyuu... running an old 40GB seagate IDE hard drive I think came from the "bad sector" pile at work... LOL! Total price? Less than $50... Are you wondering what that server does? it runs my entire network, firewall, router, dhcp server, port forwarder, ad blocker, content filter, etc... if that thing goes down I'm screwed. But it's better than spending thousands of dollars on premium server equipment to run a silly little home network...
However, I wouldn't run my business on that thing. If I had something like BCN it would be spread across 4 of these http://www.newegg.com/Product/Produc...82E16859102487 in different datacenters across the US... why? Because in the end of the day, uptime and reliability and speed DO matter.
THE SHORT VERSION: personally I'm glad to hear Topcat is putting server-grade hardware to good use rather than using entry-level ECS motherboards and Deer power supplies in Badcaps.net servers!
Firefox is named after a fox - WRONG! That orange thing is a Red Panda, not a fox!!
http://www.youtube.com/watch?v=y6GaPkkGZGw
shovenose is online now   Reply With Quote
Old 04-12-2012, 08:46 PM   #23
Topcat
The Boss Stooge
Topcat's Avatar
City & State: Salem, MO
My Country: United States
Send a message via ICQ to Topcat Send a message via AIM to Topcat
woohoo....processors should be here tomorrow!
<--- Badcaps.net Owner & Forum Administrator!!
Badcaps.net Services:
Premade Capacitor Kits
Badcaps.net Capacitor Master List
Motherboard Repair Services
If you've come here in search of replacement capacitors or repair services, please use the links above.
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats
Topcat is offline   Reply With Quote
Old 04-14-2012, 11:32 AM   #24
Topcat
The Boss Stooge
Topcat's Avatar
Just a few teasers while I wait for the RAM to get here....
yea, thats a big board!!
The money shot!!
Other crap...
Old 04-14-2012, 11:39 AM   #25
ratdude747
ratdude747's Avatar
City & State: New Albany, IN
I'm a: Student Tech
Send a message via Yahoo to ratdude747 Send a message via Skype™ to ratdude747
What about the coolers?
didn't you have a bunch of gx280 coolers that you could zip tie fans to? or are those screwy?
(Insert signature here)
ratdude747 is offline   Reply With Quote
Old 04-14-2012, 12:52 PM   #26
Topcat
The Boss Stooge
Topcat's Avatar
I have a couple of choices for permanent ones...but for testing purposes, I just use the bench coolers.
New thing I learned, FB DDR2 is keyed different than ECC DDR2.... I have some ECC DDR2 667MHz that I figured would be ok to test the board...nope. Won't even fit the slot. Fully buffered DDR2 uses a slot of its own apparently.....I never knew that. I did fire it with no RAM in it...and it beeped memory codes at me.....obviously...but it is a good sign. That tells me the board is alive...
Old 04-14-2012, 05:00 PM   #27
Uranium-235
Radioactive
City & State: tehas
My Country: US
unless the traces to the memory/memory slots themselfs are bad. then you wasted $$$ on some cpus
Old 04-14-2012, 05:31 PM   #28
Topcat
The Boss Stooge
Topcat's Avatar
How do you figure>? Umm, did you read the above post at all?
Old 04-14-2012, 09:26 PM   #29
ratdude747
ratdude747's Avatar
I'm a: Student Tech
Let me guess, the RAM you need is pricey?
Old 04-15-2012, 12:42 AM   #30
Uranium-235
Radioactive
City & State: tehas
My Country: US
you fired it up with no ram. if the traces are bad it will still get memory beeps with ram in it.
Old 04-15-2012, 10:09 AM   #31
Topcat
The Boss Stooge
Topcat's Avatar
I'm confused, it did exactly what it was supposed to do.....beeped at me telling me there's a memory problem....lol... No RAM is a memory problem!
It wasn't that bad. I tracked some down, got 16gb of it for 130 bucks.
Old 04-15-2012, 04:18 PM   #32
Uranium-235
Radioactive
City & State: tehas
My Country: US
yes and if the traces or memory slots are bad. you'll get your memory, put it in, and it will still beep, and you'd spend 130+cpus for nothing
sorry, i'm a pessimist. as a habit I never spend that much money on anything till I know it works. I've also had computers boot fine but had wierd stability issues later. but then again, I doubt that thing can take just one cpu, so you would have to buy both to see if it works.
Old 04-15-2012, 04:33 PM   #33
shovenose
404 Not Found
shovenose's Avatar
I'm a: Forum Junkie
If the thing doesn't work he can sell the parts
Old 04-15-2012, 04:49 PM   #34
Topcat
The Boss Stooge
Topcat's Avatar
I don't follow you at all... There was no RAM in it......so umm, no...it wasn't going to run...
...but I'll lay a $50 on the table that it works.... When the RAM gets here, I'll post pics of it running. If it were some crap board (an Asus for example), I too would be a pessimist.....but this is the holy grail of motherboards.....SUPERMICRO!!! So, bet??
Old 04-15-2012, 06:17 PM   #35
Uranium-235
Radioactive
City & State: tehas
My Country: US
yes and imagine you get your ram and it still beeps, what could cause that?
but yeah its probably good. I've just seen stranger things happen
Old 04-15-2012, 08:28 PM   #36
c_hegge
Unknown
c_hegge's Avatar
My Country: Australia
Line Voltage: 240V 50Hz
The board is brand new. It's unlikely to be dead.
Main PC: Core i5 660 3.33GHz, Gigabyte GA-P55-UD3R, 4GB Kingston DDR3 1333, 750GB WD HDD, Sony Optiarc DVD RW, nVidia GTX295 1760MB, Antec 1200 Case, Delta DPS-750CB 750W PSU, Hauppauge TV Tuner, Windows XP Pro.
Main Laptop: Lenovo Thinkpad T60: Core 2 T2500 2GHz, 2GB DDR2, 80GB HDD, DVD RW, Intel Graphics, Windows XP Pro.
2nd Laptop: Toshiba Satellite A200: Core Duo 1.73GHz, 2GB DDR2, 60GB HDD, DVD RW, nVidia GF Go 7300 Graphics, OpenSUSE 12.2, Fan Mod
c_hegge is offline   Reply With Quote
Old 04-15-2012, 10:34 PM   #37
Uranium-235
Radioactive
City & State: tehas
My Country: US
^ there is more chance of a board being dead brand new then used (with the exception of certain obvious brands)
Old 04-15-2012, 10:37 PM   #38
Topcat
The Boss Stooge
Topcat's Avatar
I've been building Supermicro systems for over a decade....of the many dozens I've built, I've never pulled a new one out of the box and had it be DOA.
Are you sure you don't want to take this bet?! You just seem dead set (no pun intended) that this board wont work...
Old 04-15-2012, 11:19 PM   #39
Uranium-235
Radioactive
City & State: tehas
My Country: US
no i'm not to the point of betting. I'm just saying 'expect the worst when its least convenient'
Old 04-19-2012, 03:40 PM   #40
Topcat
The Boss Stooge
Topcat's Avatar
I wish ya took the bet!! The memory showed up, and it lit right off.
