Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > Troubleshooting Computer Displays
Old 04-26-2012, 12:49 PM   #1
gman
Default Acer AL1912 lines on left l half of screen
I have a n Acer 1912 monitor with half a screen of lines
could this be bad caps
view attachment
gman is offline   Reply With Quote
Old 04-26-2012, 01:01 PM   #2
Jasgriff
City & State: England
My Country: UK
Default Re: Acer AL1912 lines on left l half of screen
That looks more like it might have something to do with the T-con board. Other members might has a different view though.
Is it bright because you used the flash on your camera or is that how the monitor is?
Fixed so far : 1 Home cinema system, 16 LCD Monitors, 4 LCD TV's
How to resize your pictures guide click HERE
Retiredcaps Ideal post example click HERE
Jasgriff is offline   Reply With Quote
Old 04-26-2012, 01:16 PM   #3
selldoor
Slow Learner
City & State: Lancashire UK
Try cleaning and reseating the cable that goes beween the panel and the main board.
May be a flat ribbon type.
selldoor is offline   Reply With Quote
Old 04-27-2012, 01:18 PM   #4
gman
I cleaning and reseated the cable & the picture cleared up
while turned on its side ,but when I assembled it the lines returned
The picture is bright because of the flash
What is the T con Board?
Old 04-27-2012, 01:34 PM   #5
selldoor
Slow Learner
The TCon is the board on the panel where the cable you have just cleaned connects to. As it did work briefly may be worth trying again - did you reseat both ends.
If not, we can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
Examples of what is needed
http://www.badcaps.net/forum/attachm...1&d=1290283049
http://www.badcaps.net/forum/attachm...7&d=1280167246
Old 05-19-2012, 10:32 AM   #6
gman
I am trying this pic thing here goes
Old 05-26-2012, 11:20 AM   #7
gman
Problem solved I cleaned and reset the cable both ends ,and its working now
Thanks jasgriff & selldoor for your help
