#1 |
City & State: LA
Line Voltage: 120vac 60hz
I'm a: Hobbyist Tech
Hi Badcaps folks,
A local individual is selling a 22 inch Samsung with the following output as shown below. There is a blue box in the upper right hand corner. Bad cable perhaps? Bad connection? Available for the princely sum of $20. |
#2 |
Be careful... The model shown in the picture is a Dell, not a Samsung... I smell the old bait and switch.
...Their plight, in fact is even worse, they don't realize that they're cantonists, they think they're free men. What a slavery that is - to confuse slavery for light, and bitter darkness for bright light. -Rabbi Menachem Mendel Schneersohn |
#3 |
City & State: England
My Country: UK
Yep I agree with mocking bird that definitely looks more like a Dell than a Samsung
Not sure if that can be a bad connection because it would be a full strip right down the screen. I might be wrong though. |
#4 |
City & State: LA
My oversight...actually advertised as a Dell.
#5 |
City & State: Alberta
My Country: Canada
Line Voltage: 120VAC 61Hz
I wouldn't pay $20 for it.
Looks like a tricky fault to locate.
36 Monitors, 3 TVs, 4 Laptops, 1 motherboard, 1 Printer, 1 iMac, 2 hard drive docks and one IP Phone repaired so far.... |
#6 |
On my level
Bad panel or bad logic board. I'd suspect the logic board (or tcon if it has that separate), because when the defect is in the tab bonds of the panel the defect will span the entire screen, either horizontally or vertically - the display is driven as rows x columns. You could get several thin colored lines that stay on, half the screen white, or similar things, but i've never seen a panel making a blue box like the pic shows.
I'd pass, unless you have a similar one with a broken screen. Would be an idea to check how much a logic board/tcon costs tho. |
#7 |
City & State: LA
Thanks all for your input on this monitor for sale. At this point it looks like a challenge I don't think I wish to take on. Saturday I will investigate another candidate which looks a bit more straightforward.
#8 |
City & State: wonk ab
My Country: canada
osd setting on monitor maybe? seen a tv with that, an it was an id 10 t error! simple click changen osd settings got rid of it!
#9 |
City & State: LA
Hmmm. Maybe - I see the monitor does have an osd setting on another of the images in the ad.
#10 | |
City & State: LA
The monitor is across town, so I had a local buddy of mine swing by and buy it for me. The actual model number is a 2005FPW, and since it was advertised as a 22", I had him squeeze the owner for a few bucks. Total was $15. Attached is a second photo from the Craigslist ad. If you look closely, the PIP source is 4Composite which I believe to be unplugged. It should say unassigned or something to that effect. I'm betting on an easy adjustment for a fix. |
#11 |
My Country: canada
good score ! hope that all it was!
peace |
#12 |
City & State: University of Leeds (MEng ElecEng undergrad)
My Country: UK
Line Voltage: 230Vac 50Hz
I'm a: Student Tech
Yeah, it has PIP/POP - and it is trying to show the second source in the small window.
** Begin Signature ** I fix TVs and electronics as a hobby and to save nice things from the dump. 40 LCD TVs, 4 monitors, 13 plasma TVs, and a 6.1 system! Free service manuals database: http://www.tgohome.com/ServiceManuals - Have a manual? Need a manual? Please PM me. I have successfully fixed (from best --> worst build quality): 3 Panasonic Plasmas, 1 Yamaha HTS, 1 NEC Plasma, 2 Sharp LCDs, 2 Toshiba LCDs, 5 Philips Plasma/LCD, 1 Hitachi Plasma, 5 LG LCD/Plasma, 10 Samsung LCD/Plasma, 1 Thomson Plasma, 1 Atec LCD, 1 Hanspree LCD, 1 Xerox LCD, 1 Harwa LCD, 2 Proview LCD, 2 Hyundai LCD, 1 "Onn" LCD, 1 Dell LCD, 1 iiyama LCD, 1 Logik LCD, 5 Bush LCD, 10 Vestel LCDs [Please do not PM me for help: I am a busy student, and we prefer input from all sides on this forum.] |
#13 |
City & State: LA
Update on the Dell 2005FPW...there were a couple of issues going on. First was the aforementioned blue box where the PIP should be, and this was rectified in the first few minutes.
The second issue was the often-reported issue in other threads where there is a rolling, not unlike a TV's vertical hold. It went away after a few minutes, which made me think it was a caps problem. I went into my bag of tricks and found replacement caps for most everything on the power card, with the exception of the 1uf 50v. For that, I used an FC 2.2uf 50v. If anyone thinks that was a bad move, please advise. Well, the problem was mitigated somewhat but didn't go away completely. So upon further research, the culprit was previously identified with some bad caps on the logic card. So I did some esr testing, and saw that the 470uf caps were all registering about .50, while new FC caps were more like .03. So I changed the three of them, and I am pleased to report that the issue has not gone away completely. I will test the usb functions most likely tomorrow but I have high hopes for that. Next up: a flickering Samsung 22" being advertised down the street. He wants a lot but my pitch is getting better. LAS. |
#14 | |
City & State: Canada
Good job. Looks like the ESR tester is starting to pay for itself.
--- begin sig file --- If you are new to this forum, we can help a lot more if you please post clear focused pictures (max resolution 2000x2000 and 2MB) of your boards using the manage attachments button so they are hosted here. Information and picture clarity compositions should look like this post. We respectfully ask that you make some time and effort to read some of the guides available for basic troubleshooting. After you have read through them, then ask clarification questions or report your findings. Please do not post inline and offsite as they slow down the loading of pages. --- end sig file --- |
#15 |
City & State: LA
I stand corrected!! And I do like the esr meter. The absolute numbers are not so meaningful to me, but the values relative to the new ones I find to be more useful.
I brought up the service menu, and for the total time, it had a value of 161. Can anyone tell me how this number can be translated into something more like hours or days or ?? |
#16 |
My Country: UK
I'm a: Student Tech
Probably number of turn on/off cycles. So not many at all!
#17 |
o.O
City & State: Duisburg
My Country: Germany
Line Voltage: 230VAC 50Hz
Normally it's POH, Power On Hours. If it's on/off cycles, that should be easy enough to check. Just turn it off and back on again and check the number
As for the numbers (ESR meter readout) not being really meaningful.. If you look up the datasheets for the original caps, that might help (if you can find them that is..). If they're low impedance/ESR types, they should list the ESR/Impedance values for the specific voltage/capacitance/can size. If they're way off of what they should be, the cap is obviously bad. Searching for the datasheets is pretty easy. For example, if the cap in question is a Capxon KF series, just go to google and search for "capxon kf filetype:pdf". The "filetype:pdf" makes google only show PDF files as results, so you usually don't have to dig through crappy websites to get to a download link. The results after the first 3-5 or so are useless most of the time though. Example link https://www.google.com/#hl=en&safe=o...w.r_qf.,cf.osb |
#18 |
My Country: UK
I'm a: Student Tech
But 161 hours... that would even be covered under a 28 day return policy if it went wrong that quickly!
#19 |
o.O
My Country: Germany
![]() Might have gotten reset at some point. When I was working on a Samsung LCD TV, it originally showed around 5900 power on hours.. after a factory reset it was 00000 again (even though a factory reset shouldn't affect the power on hours counter in the service menu if you ask me) |
#20 | |
My Country: UK
I'm a: Student Tech
| Thread Tools | |
| Display Modes | |
