#1 |
City & State: Albany, Western Australia
Line Voltage: 230VAC 50Hz
I have an otherwise decent 12V 3A plugpack let down by craps. (Oh so familiar...)
What's bugging me is not that the caps are crap, but that the primary cap is a custom-sized CapXon KW. It's 68µF 400V and 18mmD x 25mmL. It's bulging on top and leaking around the positive lead. The plugpack wouldn't start up, and I'm pretty sure this is to blame. A longer cap would be blocked by the fuse and inlet. The secondary caps are 2 x CapXon KF 1000µF 16V 10mm and 1 x Teapo SC 680µF 16V 8mm. None of them are bulged, but best to play it safe. There's also a Teapo SEK 100µF 25V 6.3mm near the transformer which I figure should be replaced with a low ESR cap. Anyway, the big cap is the main problem. Curiously, CapXon has the size mentioned in the KM series - yeah, like that's gonna help . I then looked at SamXon's KM series, but that didn't take me anywhere. Guess what the only other manufacturer with a 68µF 400V 18mmD x 25mmL general purpose cap was??? ![]() |
#2 |
Rubycon and Panasonic both show an 18x25mm part:
http://www.newark.com/rubycon/450txw...ial/dp/39T8985 http://www.newark.com/panasonic/eeue...ial/dp/39P9916
...Their plight, in fact is even worse, they don't realize that they're cantonists, they think they're free men. What a slavery that is - to confuse slavery for light, and bitter darkness for bright light. -Rabbi Menachem Mendel Schneersohn |
#3 | |
I'll consider them. But guess who I was thinking of when I wrote:
#4 |
It appears to have provision for a 5V output as well. There is a second output on the transformer and an empty position for a second rectifier. Curiously, the 5V and 12V lines on the PCB are linked for 12V only. Come to think of it, I could probably modify the unit for dual outputs. Only real difficulty would be finding a second pi coil. The 12V rectifier is SB10100FCT.
There is a bit of discolouration of the PCB tracks on the primary side (the secondary looks fine), so maybe it was too hot for the cap. The switcher is a PFF6N60. The dual-outputs feature would of course be used to power a HDD. This unit actually came with a HDD enclosure. When it wouldn't start up I cracked it open and used a different PSU. |
#5 |
City & State: dayton ohio
or if in 120vac area use a 200-250v cap.
had one for my maha c777+2 give up.since i dont care about running from 220v i used 2 33@250 paralell. close enough for gov work. |
#6 |
City & State: North England
My Country: United Kingdom
I'm a: Hobbyist Tech
#7 |
You got it!!!
![]() MH series to be exact. |
| Thread Tools | |
| Display Modes | |
