Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > Power Supply Design and Troubleshooting
Old 05-24-2012, 08:28 AM   #1
rogfanther
City & State: Curitiba
My Country: Brazil
Line Voltage: 127VAC 60Hz
Default BlueCase DT500 KN1009P31154 Hissing and shutting down
Another one in the realm of the not-so-true real watts. I asked an importer if for "nominal power" he meant that the number appeared in the name of the psu.
Well, this came with a bunch of others to try fixing.
It hisses a lot, without load. 5VSB is ok, also the other voltages when jumpered on. No caps bulged ( those in the picture are the original ones ) .
When jumpered on with load ( just one hard disk ) it shuts down and won´t start. Tried changing the rectifiers, same thing.
Tried changing the caps one at a time, to try in identifying the culprit, also no go. Even after changing all of them, it still hisses and shutdown.
With the paper tube trick, it seems the sound comes from the big transformer.
As I´m already out of good caps to use, ( need to decide which brand/series/values to buy even from Badcaps or from other places ) and cannot spend too much money in this psu, I need to decide what to do.
What more could be causing this, other than the transformer ? The supervisor chip is a HS8109.
The original caps are all from that brand with a big "C" inside a "S".
Thanks.
rogfanther is offline   Reply With Quote
Old 05-24-2012, 09:25 AM   #2
selldoor
Slow Learner
City & State: Lancashire UK
Default Re: BlueCase DT500 KN1009P31154 Hissing and shutting down
Hi - have you now replaced ALL the caps Including the BIG Yalecon ones
I doubt if they are good caps.
Are these the Caps you refer to
http://capacitor.web.fc2.com/image2/cs01.jpg
What brand/series did you use for replacements
Picture of the bottom of the board might help - have you tried resoldering the transformer connections
EDIT - did the green cap bottom left leak onto the board - did you clean it up properly.
selldoor is offline   Reply With Quote
Old 05-24-2012, 12:30 PM   #3
rogfanther
My Country: Brazil
No, not replaced the yalecon ones. I only have those cheap 330uF ones from gutless wonders.
I used a bunch of Nichicon PM and HE, also Panasonic FM that I had lying around.
Here are the pictures of the bottom.
No cap leaked, the smudges are remains from glue that was between the caps and the toroid.
Will try resoldering the big transformer.
Edit : transformer resoldered, same thing. Hiss without load, won´t start ( but stops hissing ) with load.
Old 05-24-2012, 02:11 PM   #4
Th3_uN1Qu3
On my level
Th3_uN1Qu3's Avatar
City & State: Bucharest
My Country: Romania
Line Voltage: 230VAC 50Hz
I'm a: Student Tech
Send a message via Yahoo to Th3_uN1Qu3
Hissing means oscillation, irregular operation of the control circuit. Sounds like something is gone in the driver circuit since it stops under load. Check the driver transistors (they will be somewhere near the base drive transformer, in the secondary side, usually C945 in TO-92, but depending on the controller and its supply voltage they might be 1A ones, in a fatter package) and the drive circuit in the primary, on the other side of that transformer. Here you have a schematic, values may not be exact but the basic circuit will be the same.
http://www.smpspowersupply.com/ATX_p..._schematic.pdf
By the sound of it, i'm fairly certain that one of the driver transistors is gone, everything else is probably okay. Replace both of them and give it a try.
Originally Posted by PeteS in CA View Post
A working TV? How boring!
Th3_uN1Qu3 is offline   Reply With Quote
Old 05-25-2012, 11:37 AM   #5
rogfanther
My Country: Brazil
They are D1616A. Replaced them with BD139, that was the most similar we could find in the store. Will need to check in the junk pile at home if I found the exact same part.
But the behaviour remains the same. Voltages ok without load, shutdowns with load.
I also measured the diodes around the transistors ( Q1 and Q2 in your drawing ) , but all of them measure ok. The cap in a position C8 is a 10uF x 50V, also measures ok (10.5uf ) .
Old 05-25-2012, 04:15 PM   #6
Th3_uN1Qu3
On my level
Th3_uN1Qu3's Avatar
My Country: Romania
I'm a: Student Tech
Not sure BD139 is good for switching, i've only seen them in audio. Try a closer replacement. Once you're sure those are okay but still no go, check D8/D9 (most likely those will be 1N4148) and C9/C10.
Old 06-02-2012, 02:49 PM   #7
everell
everell's Avatar
City & State: Williamsburg, Virginia
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
The schematic is very interesting. The PWM IC is not labeled, but the pinout matches the "chip of the year" 2008. Perhaps this schematic is for a "economy" Solytec psu?
everell is online now   Reply With Quote
Old 06-02-2012, 04:48 PM   #8
Th3_uN1Qu3
On my level
Th3_uN1Qu3's Avatar
My Country: Romania
I'm a: Student Tech
It is labeled on the right. It's a SG6105.
Old 06-04-2012, 06:35 AM   #9
rogfanther
My Country: Brazil
Still searching for suitable replacements for those transistors, and waiting for some caps to arrive in the mail. While I don´t see why, could it also be the primary caps that cause this fail ?
