Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > General Electronics
Old 05-25-2012, 12:32 AM   #1
Rangwan
City & State: Bang Yai/ nonthaburi
My Country: Thailand
Line Voltage: 220V 50Hz
I'm a: Hobbyist Tech
Default capacitor balance charging???
The electronic theory says "connecting capacitor in series will give the higher voltage tolerance, but lower capacitance in the same fashion of connecting resistor in the parallel will give higher power tolerance but lower resistance".
However, I've got some idea of "balance charging". Giving 3 capacitors of 1F @4.3V each connected in series with 4 pins like
G|____c1_____|______c2______|______c3_____|+ and charge them like li-po battery. I'm wondered if that will result in 1F capacitor @ 12.6V with no capacitor boomed?
Rangwan is offline   Reply With Quote
Old 05-26-2012, 11:19 AM   #2
999999999
City & State: Near Cincinnati, OH
Line Voltage: 120VAC 60Hz
Default Re: capacitor balance charging???
First of all, LiPo batteries should not be charged past 4.2V. If you were to connect 3 x Li-Po batteries in series then yes you can charge the 3 capacitor series to 12.6V but you will not have 1F @ 12.6V, it will be 333mF ( 333,33uF ) at 12.6V.
Unless you use a (large) high current battery, you should use something like a resistor in series to limit current from the battery while charging the capacitors.
999999999 is offline   Reply With Quote
Old 05-26-2012, 01:12 PM   #3
Tube_Dude
Tube_Dude's Avatar
City & State: Portugal
The resulting capacity of the 3 capacitors will be 333mF or 333.333,33 uF...
Tube_Dude is offline   Reply With Quote
Old 05-26-2012, 03:09 PM   #4
999999999
^ Huh, yeah I mistyped that or something.
