#1 |
tinkertech
City & State: Michigan,U.S.A.
Hello All,
I'm almost finished restoring a Sansui R-303 Receiver. But I'm not having any luck sourcing a replacement bulb for the back-lit tuning dial. The old bulb had a blue sheath around it to change the light color to blue. I tried measuring the connection point for the old bulb to get the voltage info. I got 18.50VAC. Does anyone know where to locate such a bulb? Or perhaps a circuit to drive a regular blue LED in its place? Any help at all would be greatly appreciated! Have A Great Holiday Weekend lcdman Last edited by lcdman; 05-26-2012 at 05:11 PM.. Reason: Picture Of Bulb For Reference |
#2 |
City & State: dayton ohio
nothing there for scale but it looks like a common grain of wheat like the ham rigs use.
are there several in series?i suspect that is a 24v or a more common 12v and a series resistor. and i often replace with led's.unless its a marantz blue may look tacky. the tinted boot whitens it. maybe white led's? you will need a diode too. or run em from another regulated source. |
#3 |
tinkertech
Hello kc8adu,
Thanks for the reply. There is just one bulb lighting the entire dial. So I should be looking for a 24v bulb instead? You mentioned a diode or resistor. There is one resistor on the circuit board that the blown bulb came off of. What about a circuit diagram to replace the bulb all together? I haven't had any luck sourcing a free schematic for this receiver either. Thanks Again lcdman |
#4 |
Slow Learner
City & State: Lancashire UK
How about one of these - Doesnt seem to say if its ac or dc
http://www.bulbtown.com/2102_MINIATU...ASE_p/2102.htm |
#5 |
tinkertech
Hello selldoor,
I seen that site as well. And it doesn't say AC or DC? It looks like what I have now that don't light up. I did look into those grains of rice bulbs that were mentioned in a earlier post. Those might work as well. No one has replied about a schematic for this receiver as of yet either. Thanks lcdman |
#6 |
incandecents dont care about ac or dc.
just had a yaesu g800 rotor control in here with a dead bulb.it ran from the 14v ac winding on the transformer.a 1n4007,white led,and a 470 ohm resistor and it should be good forever. if the slight flicker bugs you a small lytic across the led will reduce that. since it edge lights the scale i used a diffused led. your sansui probably does too. |
#7 |
tinkertech
Hello Again kc8adu,
Thank you again for your quick reply. I would rather use an LED than a regular miniature bulb. Would you be so kind to put all those parts you mentioned in your last post into a labeled schematic? I'd like to return this receiver to its owner soon. I'd be very grateful if you would! Thanks As Always lcdman |
#8 |
City & State: italo
My Country: italic
Hi LCDman, I've the same Sansui R303, with the same bulb problem, do you found a solution?
Other than this, I've a bigger problem, audio it's all distorted and can't regulate Volume..... here: http://www.badcaps.net/forum/showthr...542#post339542 |
| Thread Tools | |
| Display Modes | |
