#21 | |
How off are we talking about? You said in the other thread that you were "not fully satisfied". Was it at least within spec? I imagine that the final 5V and 12V output also changed a bit when you swap the stock caps. I thought PFC was supposed to take care of all of this?
Did you ever trace which caps were for which rails (Pi filters on the secndary)? Would be nice to know what's 3.3, 5, 12 so that I can have more flexibility when choosing replacements and fiddling with pi filter pairs. I've done this with my FSPs. Thanks for all your help.
...Their plight, in fact is even worse, they don't realize that they're cantonists, they think they're free men. What a slavery that is - to confuse slavery for light, and bitter darkness for bright light. -Rabbi Menachem Mendel Schneersohn |
#22 |
City & State: Romania
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
You could easily do a 5vsb fan with a pic microcontroller or an attiny or any 0.5$ microcontroller.
A basic voltage doubler circuit would take care of starting fan at 10v ... to protect the input pins of the IC use maybe an optocoupler to detect when the 12v is gone (power supply turns off), use a npn transistor or darlington to connect the power to the fan... Some other thing I thought about would be just using the 12v to keep a relay open blocking 5vsb power from going to the fan. When 12v goes off, relay closes, connecting the fan to 5vsb provided a npn transistor is conducting... which can be made using the charge in a capacitor that filled while the 12v was working. As you only need a few mA to make the transistor work, this should work like a timer... when the capacitors depletes its energy the fan stops. Problem with this is default closed relays are expensive. Last edited by mariushm; 08-03-2012 at 12:01 AM.. |
#23 | |
City & State: VA
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Student Tech
1) It wears the fan more than needed. If you have a ball bearing fan, it wouldn't matter that much. However if you have a sleeve bearing fan you'll put considerably more wear on it. 2) It makes the PSU and its fan(s) clog faster with dust. (So even if you do have a ball bearing fan, what good would it do to you if can't push any air due to dust). 3) Draws extra power for no reason - seriously, most electronics like that don't need to be that cool. Take for example laptop chargers - they run just as hot (if not hotter) that these 5VSB circuits and even they survive for many many years. Unless crappy caps were used, I actually haven't seen a well-made one die of old age. 4) Adds noise in the room when the PC is OFF - this probably isn't an issue for most people. For me it is, though, because I have all of my PCs in my room and I don't like noise when I sleep. (I turn ALL of my PCs OFF overnight). |
#24 |
Unknown
My Country: Australia
Line Voltage: 240V 50Hz
I'm still not totally convinced about the heat theory as to why C36 fails. On all the Bestec PSUs I've recapped, there was never any heat discolouration around C36, or anywhere else on the PCB, and bestec always use low quality caps, (usually OST or CapXon), or under-spec'd Jamicon general purpose caps, so of course they're gonna fail. Unless I see them killing pannies and rubys, I'm gonna stick with the junk cap theory.
I probably should add that I've only ever seen two where C36 failed. I run into heaps of bestecs and very few have bad caps
I love putting bad caps and flat batteries in fire and watching them explode!! Main PC: Core i5 660 3.33GHz, Gigabyte GA-P55-UD3R, 4GB Kingston DDR3 1333, 750GB WD HDD, Sony Optiarc DVD RW, nVidia GTX295 1760MB, Antec 1200 Case, Delta DPS-750CB 750W PSU, Hauppauge TV Tuner, Windows XP Pro. Main Laptop: Lenovo Thinkpad T60: Core 2 T2500 2GHz, 2GB DDR2, 80GB HDD, DVD RW, Intel Graphics, Windows XP Pro. 2nd Laptop: Toshiba Satellite A200: Core Duo 1.73GHz, 2GB DDR2, 60GB HDD, DVD RW, nVidia GF Go 7300 Graphics, OpenSUSE 12.2, Fan Mod Last edited by c_hegge; 08-03-2012 at 05:40 PM.. |
#25 | |
You've seen very few Bestec PSUs fail from bad caps, even with the C36 capacitor in that very spot, with that very heatsink? If that's the case, then perhaps the placement isn't the reason. EDIT: It must be the hot diode then as mockingbird and everell brought up. And it runs hot enough to cook a bad capacitor. ![]() Last edited by Wester547; 08-03-2012 at 06:18 PM.. |
#26 | ||
Unknown
#27 |
Everell has mentioned before that the large diode next to C36 gets very hot and causes that.
#28 |
Unknown
I know what supposedly cooks C36, but I don't find that the diode gets hot enough to cook a cap. |
#29 | |
City & State: VA
My Country: U.S.A.
I'm a: Student Tech
The 5VSB diode may run hot, but how hot are we talking about really? 75C? 85C? 95C? Under full 2A load, I would say all of that reasonable. Under a small load it should run cool, though. |
#30 |
Unknown
Another mod would be to replace the diode with a TO-220 one, and mount it to the heat sink, using wires to connect it to the PCB. If you don't happen to have an appropriately sized drill bit, or have shaky hands like me, then that might me the better option.
#31 |
City & State: Thessalonik
My Country: Greece
I'm a: Hobbyist
Or just turn off completely the psu when the PC is off.
#32 |
There's a difference between heat that is convected through air and that which is convected through contact. The diode is practically touching the capacitor... I don't like that. Having said that, my cap wasn't bulged... Mind you, out of all the 21 capacitors (Minus the two primaries) on this 300Z revision , ALL of the capacitors are Jamicon "TK" Series (Some of which have bulged) besides this cap we are talking about which is a single OST "RLS" series. This is a highly rated cap at 0.022 ESR and 2150 ripple even if it is a substandard brand. It's not bulged, but I didn't test it otherwise. Would be interesting to note which series of caps in this position have bulged.
#33 |
Unknown
You may be on to something. On all of my bestecs, the diode doesn't touch C36. It's close, but it's usually bent outwards enough not to touch it. In any case, the bulged C36 on the two I've had to fix was CapXon IIRC. |
#34 | |
City & State: Williamsburg, Virginia
Line Voltage: 120VAC 60Hz
| Thread Tools | |
| Display Modes | |
