Got a little stereo in for repair today. It's a pretty nice one, it has DVD playback with Dolby Digital, a digital TV tuner, and a built-in 7" screen.
Trouble: No power. Owner said he replaced the controller IC (FAN7554) and the mosfet because they were visibly cracked. But still no go.
I found a bunch of bad parts including the current sense resistor, the opto, a SMD 1N4148, some resistors, and i eventually ended up blowing both the FAN7554 and the FET. Oops. A quick look around showed that the FAN7554 isn't easy to come by, so i adapted a UC3842 (they are pretty much the same anyway, the only thing i had to do was to lift pin 2 from the PCB and wire it to primary ground, the other pins line up), and put in another FET for testing.
I got voltages to come up on the secondary but only in bursts, and not up to spec. The supply didn't even come into regulation. I looked for secondary shorts: clean. Removed all rails but the regulated 5v one: still doing the same thing. I have a 60W bulb in the primary, it lights up, goes out, lights up, goes out, in sync with the Vcc on the UC3842. If i ensure a steady supply to the 3842 the bulb lights up fully and remains lit.
Watching the scope, i noticed that as soon as the duty cycle goes past 10% or so, bam, bulb lights up, power goes out, rinse and repeat. I think the transformer saturates. It gets a bit warm too... I pulled the transformer and it shows very low inductances on all windings: The primary is 27uH, the aux is 9uH, and secondary windings are so low inductance that they can't even be measured with the LC function of my DMM. I've never seen such a thing before - the primary should have been a couple mH at the very least. This is a flyback transformer and likely has an air gap, but still, to have only 27uH primary inductance at 100kHz switching frequency seems questionable at the very least. It doesn't appear shorted tho - could the core have demagnetized?
Your guess is as good as mine.
So i think it should be 9v.
At least i can be "cheer"ful that it's still alive.
