#21 |
City & State: Boston, MA
Ok, he said it started around 150, when the power was pressed jumped to around 290, then 140, then 150 again. Still no screen and no light.
#22 |
City & State: Trenton, NJ
Line Voltage: 240v-120v 60Hz 200A service drop
Seems like it shuts down due to overcurrent, I bet one of the sustain boards is shorted. Is there any cables that feed power directly to the sustain boards from the PSU?
Hi-pot test: FAIL |
#23 |
#24 |
City & State: University of Leeds (MEng ElecEng undergrad)
My Country: UK
Line Voltage: 230Vac 50Hz
I'm a: Student Tech
There are no sustain boards in an LCD TV
** Begin Signature ** I fix TVs and electronics as a hobby and to save nice things from the dump. 40 LCD TVs, 4 monitors, 13 plasma TVs, and a 6.1 system! Free service manuals database: http://www.tgohome.com/ServiceManuals - Have a manual? Need a manual? Please PM me. I have successfully fixed (from best --> worst build quality): 3 Panasonic Plasmas, 1 Yamaha HTS, 1 NEC Plasma, 2 Sharp LCDs, 2 Toshiba LCDs, 5 Philips Plasma/LCD, 1 Hitachi Plasma, 5 LG LCD/Plasma, 10 Samsung LCD/Plasma, 1 Thomson Plasma, 1 Atec LCD, 1 Hanspree LCD, 1 Xerox LCD, 1 Harwa LCD, 2 Proview LCD, 2 Hyundai LCD, 1 "Onn" LCD, 1 Dell LCD, 1 iiyama LCD, 1 Logik LCD, 5 Bush LCD, 9 Vestel LCDs [Please do not PM me for help: I am a busy student, and we prefer input from all sides on this forum.] |
#25 | |
![]() Well, nobody ever mentioned if it was a plasma or a LCD, so I just guessed plasma by the age/size of it. |
#26 |
Yes it is an LCD. The output from the PSU appears pretty constant. I don't think that any of the connectors could have become loose, as the TV sat on the cabinet all this time. The one thing that is kind of inconsistent is the clicking noise. When I plug it in, there is a click. When I press power, there are 2 clicks, when I press it again, there is one more click, and when I unplug it, there is a click. This clicking never happened when the TV was working. I would have heard it as the clicking is very loud.
#27 |
I would bet its one of the switching supplies on the board at the top, with the small heatsinks and small yellow transformers.
#28 |
Slow Learner
City & State: Lancashire UK
Are you guys just forgetting the shorted PJ63 problem - mentioned earlier - there are a number of threads regarding this issue- the seine board is quite expensive to replace (if you can find one) and for a 7 year old set may not be economically viable.
#29 | |
It looks like it would be possible to fix, if its the connector itself. |
#30 |
The PJ63 problem from my research was most always accompanied by a blinking red light. For me, the red light does not even come on.
#31 |
#32 |
Perhaps it has shorted out, when you said the light was blinking, then the next time you turned it on, it might have made a voltage regulator blowup or something like that.
#33 |
The light always blinks while the TV is powering up, and then shuts off when it is on. It blinked as it usually does, but then the set went out all of a sudden, now nothing happens other than the clicks.
#34 | |
I think the clicking your hearing is coming from the two relays next to the yellow PFC choke you pointed out. |
#35 |
I have attached a pic of the PSU.
I circled the relays I was talking about. I also circled a connector which I presume is carrying ~300v DC, it probably goes to the backlight inverters. Try unplugging that and see if it turns on. Last edited by ben7; 08-06-2012 at 12:20 PM.. Reason: lol, forgot pic |
#36 |
Ok, I will try in a minute. I am actually working on my irrigation system at the moment. I am having a busy day off. Why do you think that the clicking did not happen when the TV worked?
#37 |
City & State: uk
My Country: uk
Line Voltage: 230v 50hz
I'm a: Hobbyist Tech
op,you said the caps were checked with a multimeter?analog? digital?,the only check you can do with a dmm,of analog meter is a kick test,and capacitance measurement,it wont confirm if the caps are high esr,are all the outputs stable?and at there correct voltages?
fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo! ---------------------------------------------- please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully! |
#38 | |
When our samsung plasma broke, it kept power cycling, and the relays kept clicking every few seconds. Two transistors later and some soldering, it was fixed. I'm not so sure anymore that the connector goes to the backlight inverters. Most likely they are on the sides, under the perforated metal covers. |
#39 | |
#40 | |
After careful looking at the pics, that seems to be the main power input from the filtering board next to/below the PSU. |
| Thread Tools | |
| Display Modes | |
