Old 08-06-2012, 12:34 PM   #41
Senatov
City & State: Boston, MA
Default Re: Toshiba TV not powering on?
There are 4 connections coming from the PSU. I am going to try individually disconnecting and reconnecting them and see what happens.
UPDATE: I tried disconnecting the black plug on the bottom of the green board, a few inches away from the one you recommended, I disconnect, the fans started up for a second, when I tested it, but then it shut off again.
Senatov is offline   Reply With Quote
Old 08-06-2012, 02:03 PM   #42
Senatov
Now I am really confused as to what the problem is.
Old 08-06-2012, 02:06 PM   #43
ben7
City & State: Trenton, NJ
Line Voltage: 240v-120v 60Hz 200A service drop
Can you take some of the covers off so we can see more of the boards? I am not sure of what connector you said you un-plugged.
Try to find the backlight inverter boards, I think they are under the shielded metal casings.
Hi-pot test: FAIL
ben7 is offline   Reply With Quote
Old 08-06-2012, 02:12 PM   #44
killian6pk
killian6pk's Avatar
City & State: Kentucky
Line Voltage: 120VAC 60HZ
It must have taken a NASA engineer weeks to come up with a way to pack that much stuff into that small a space. Heck there is probably enough boards in there to run the space shuttle.
To find your problem you are going to have to get some room to work by taking off as many of the metal covers as possible. The primary way to determine the solution to your problem is to check to see if you have several different power levels going to different parts of the set. On each of the boards in your set there are from 1 to x number of connectors (plastic plugs w/ wires) going from one board to another. Each of the connectors have written on the board a legend that tells what each wire is for. One wire may be for ground and one for 5volts and one for PSon or BLon etc. Please take really clear pictures of all of those connectors so that we may see the legends printed on the circuit boards.
Have you ever stopped to think and then forget to start thinking again?
killian6pk is offline   Reply With Quote
Old 08-06-2012, 02:14 PM   #45
killian6pk
killian6pk's Avatar
Sorry Ben7 you beat me to it.
Old 08-06-2012, 02:16 PM   #46
ben7
Hehe.
I agree, that thing is a goldmine, if it can't be fixed then all the parts should get salvaged from it
//electronic parts hoarder
Old 08-06-2012, 02:17 PM   #47
Senatov
The problem is that you almost need a microscope to see the half Japanese/English/Numeral/Symbols on the parts.
Old 08-06-2012, 02:22 PM   #48
ben7
pft lol
Did you get to the inverter board yet?
Old 08-06-2012, 02:23 PM   #49
Senatov
Almost. I am trying to finish something else before I do that.
Old 08-06-2012, 04:02 PM   #50
Senatov
Okay, here are some pictures with the metal thing off. Sorry if it is not zoomed in enough. It is hard to capture the whole thing and get the details.
Here is that plug you asked about: http://www.badcaps.net/forum/attachm...1&d=1344290489
Here is it with the metal thing off: http://www.badcaps.net/forum/attachm...1&d=1344290489
Old 08-06-2012, 04:04 PM   #51
ben7
It says "Invalid attachment specified"
Old 08-06-2012, 04:07 PM   #52
Senatov
That's weird. It opens on my computer.
Old 08-06-2012, 04:11 PM   #53
ben7
Attach them to your post using the manage attachments option.
Old 08-06-2012, 04:14 PM   #54
Senatov
Let me try again...
Here is it with the metal thing off: http://badcaps.net/forum/attachment....1&d=1344291224
Here is that plug you asked about: http://badcaps.net/forum/attachment....1&d=1344291224
UPDATE: For some reason my computer was shortening the link and adding "..."
Old 08-06-2012, 04:25 PM   #55
ben7
Let me try again...
Ok, so, did you try un-plugging the connectors in the blue circle below?
And, what is under the red question mark? I think its the inverter, and we should try to un-plug it to see if it is at fault.
Old 08-06-2012, 04:33 PM   #56
Senatov
Did you attach an image? I do not see it. Sorry.
Old 08-06-2012, 04:34 PM   #57
ben7
LOL!
I didn't
Thats like the third time today xD
here it is:
Old 08-06-2012, 04:40 PM   #58
Senatov
LOL!
I didn't
here it is:
Unfortunately, I cannot get to what is under the question mark since the metal panel is all 1 piece and is welded to the wrest of the frame. Also the blue circle connector does not come off.
Old 08-06-2012, 04:41 PM   #59
ben7
Waa?! Theres gotta be a way to get under there!
Old 08-06-2012, 04:42 PM   #60
Senatov
You can't. I tried. The metal is all 1 piece and it runs under all the boards, and is welded to the frame of the TV. No can do.
