Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > Power Supply Design and Troubleshooting
Old 08-14-2012, 05:21 AM   #1
milesy
City & State: Melbourne
My Country: Australia
Default Codegen 350XA supply
HI Guys
hoping to get a bit of guidence here...i have the above PSU which stopped working a while back.
Purple Wire has 5v
Green Wire sits at 4.3 volts before startup
With only the 24way ATX plug connected i can press the start button and the PS starts giving 5.38v on the red and 3.3V on the orange, however on the yellow wire i only get 11.0V
If i plug in the 4 way (yellow + black) to the MB the yellow wire drops to 5.27v and the red wire INCREASES to 6.72V......its not the MB as another supply works fine.....any ideas where i start ??
Adrian
milesy is offline   Reply With Quote
Old 08-14-2012, 05:27 AM   #2
c_hegge
Unknown
c_hegge's Avatar
Line Voltage: 240V 50Hz
Default Re: Codegen 350XA supply
Junk the PSU. Codegen are junk, and should NEVER be purchased, sold or used in PCs.
EDIT: and this is why - http://www.youtube.com/watch?v=xYB9WkiZ9SQ
Main PC: Core i5 660 3.33GHz, Gigabyte GA-P55-UD3R, 4GB Kingston DDR3 1333, 750GB WD HDD, Sony Optiarc DVD RW, nVidia GTX295 1760MB, Antec 1200 Case, Delta DPS-750CB 750W PSU, Hauppauge TV Tuner, Windows XP Pro.
Main Laptop: Lenovo Thinkpad T60: Core 2 T2500 2GHz, 2GB DDR2, 80GB HDD, DVD RW, Intel Graphics, Windows XP Pro.
2nd Laptop: Toshiba Satellite A200: Core Duo 1.73GHz, 2GB DDR2, 60GB HDD, DVD RW, nVidia GF Go 7300 Graphics, OpenSUSE 12.2, Fan Mod
c_hegge is offline   Reply With Quote
Old 08-14-2012, 05:32 AM   #3
milesy
fair enough but im sort of curious as to what would cause the fault im seeing....just the 12v wrong?
Old 08-14-2012, 05:51 AM   #4
c_hegge
Unknown
c_hegge's Avatar
Could be bad caps. When they go bad, it can cause problems with the feedback circuit, which can cause all kinds of unusual behavior, as well as the obvious high ripple.
Old 08-14-2012, 06:39 AM   #5
milesy
ok thanks.....so any idea which particular caps i would be looking at.....im pretty sure the large 470u input caps are ok and one of the others look expanded at all?
Old 08-14-2012, 06:51 AM   #6
rogfanther
City & State: Curitiba
My Country: Brazil
Line Voltage: 127VAC 60Hz
Well, you really should replace all of the caps of the secondary . But as c_hegge said, the psu is not worth it. It is ok if you are doing it to learn, but do not trust some piece of hardware you like to it.
rogfanther is offline   Reply With Quote
Old 08-16-2012, 03:59 AM   #7
milesy
hope you guys can bare with me here.....i have had a really good look at all the caps (visually) and i cannot see any that even look suspect - no expanded etc et......given that myonly problem with this supply is the 12v rail would i be just looking at any caps that are connected to the 12v rail or is likely to be something to do with the switching controller???
i realise its a bit hit and miss without being able to see the supply but if you can offer me any help please do
Old 08-16-2012, 04:44 AM   #8
c_hegge
Unknown
c_hegge's Avatar
Knowing Explodegen (Codegen), the caps are probably HEC brand (which stands for Horrible Electrolytic Capacitor). Like any junk cap, they can go bad without visibly showing it, but yes, it is also possible that the problem is elsewhere.
Old 08-16-2012, 04:49 AM   #9
selldoor
Slow Learner
City & State: Lancashire UK
How about some clear well focussed no flash pictures then?
selldoor is offline   Reply With Quote
Old 08-16-2012, 06:20 AM   #10
milesy
yep photos i can do..........
IMGP9561.jpg by Adrian Miles Photography, on Flickr
IMGP9562.jpg by Adrian Miles Photography, on Flickr
IMGP9563.jpg by Adrian Miles Photography, on Flickr
plus i think i found the schematic of the supply........
codegen_atx_300w_m by Adrian Miles Photography, on Flickr
Old 08-16-2012, 03:41 PM   #11
milesy
anyone?
Old 08-16-2012, 04:02 PM   #12
c_hegge
Unknown
c_hegge's Avatar
As I suspected, it has HEC Caps. Try replacing them
Old 08-17-2012, 04:01 AM   #13
rievax_60
City & State: mackay
My Country: australia
Line Voltage: 240
I'm a: Hobbyist Tech
HI Guys
Purple Wire has 5v
Adrian
There might be one phase missing at the 12v rectifier.
Check for any bad solder connections from the transformer secondary to the 12v diodes, like solder cracks at the diode pins.
Also check for any open diodes
rievax_60 is offline   Reply With Quote
Old 08-17-2012, 04:26 PM   #14
milesy
thanks guys..........well as i didnt have any replacement caps i thought i would investigate the open diode caper.......it made sense given that the 12v under load was only reading 6v - and if one of the diodes was open the 12v output cap would only get half the amount of power rather than both +ve and -ve pules.....
so i removed the heatsink that contains two diode packs (S20C40C) and 3 discreet diodes (photo below) unfortunatley all seems to be ok with this lot of components...removing this does allow me to see a little better though and there is still no obviously bad caps.
if there are bad caps - am i likely to be able to test them somehow???
IMGP9564.jpg by Adrian Miles Photography, on Flickr
Old 08-17-2012, 09:47 PM   #15
c_hegge
Unknown
c_hegge's Avatar
Diodes on a bracket!!
Replace the two diode-bracket with a proper rectifier. one of them could be toast
Old 08-17-2012, 11:44 PM   #16
milesy
You think the diodes could be faulty under load even though they test ok with a DMM??
Old 08-18-2012, 02:12 AM   #17
rievax_60
Line Voltage: 240
I have seen axial diodes go intermittent open, very rare though. You might pick it by a fluctuating meter reading while the diode is being gently flexed.
Cracked solder joints can be difficult to spot. Maybe you should check some more like at the transformer pins and the bracket the diodes are soldered to and just try the power supply again.
There should be continuity between the pads that the diode anodes solder to. The path is through the secondary winding.
Old 08-18-2012, 02:31 AM   #18
milesy
Thanks I will recheck..am I right in saying the symptoms definitely seem to be only getting half of the cycle through to the 12v line?
Old 08-18-2012, 02:38 AM   #19
rievax_60
Line Voltage: 240
Yes, I can't think of any other possible reason.
Old 08-18-2012, 02:59 AM   #20
c_hegge
Unknown
c_hegge's Avatar
Sounds about right to me too.
