The screen for this is CMO V260B1-L11, problem is bright white screen only, otherwise working ok. T-con is I believe integrated with the lcd driver board (?) that's bonded to the screen itself. Fuse FP1 bad, gives infinite readings, when cable connected to the T-Con/driver board I get no voltage readings, if I disconnect the cable I get the 12v etc... so I guess mainboard is ok. I think this indicates a short on the T-Con? Uses littelfuse 1206 1,5A which I don't have yet.
Where to start the troubleshooting? There were some ceramic caps thet were next to each other and showed 0 ohm rating in-circuit, but when desoldered couple of those (CP3 and CP4) they measured fine. That's why those ones might look bit different from others.
Some pictures attached...
