Samsung Syncmaster 2333 No image, power OK
  • kuzyatech
    • Sep 2012
    • 13
    Hello all, I am new to this forum though not to electronics.
    Samsung Syncmaster 2333 made in September 2009. If it sits by itself, with no input signal, I get alternating Digital and Analog input decals on the screen. As soon as I connect a known good signal, I see a white line for a second and screen goes gray. Backlight is alive, power on LED is on.
    Caps on the power supply are SAMXON in the inverter section and Lelon or the like in the Secondary side. No signs of bulging or venting. All power rails look happy and clean with a meter and scope. I see no ripple, pulsing or the likes. The digital board gets clean 5V and makes normal looking 3.3 and 1.8V. I see clock (14.3Mhz) on the main controller. I see data and clock wiggling on the SPI flash and EEPROM next to the controller, so I assume its booting alright. I also see VGA and SYNC signals on its pins. I just don't get any output. It appears capable of at least drawing the searching for input decal on the screen, so the LVDS section seems fine. If I disconnect inputs and hold menu button I get Test Passed message. Other menu buttons do not seem to do much. Power button works fine. I did test both DVI and VGA inputs with the same result
    The chip does run a bit warm- I'd say 50C. Not finding anything else wrong with the system, I've swapped the controller. The soldering job is less than stellar- chips pins were a bit bent when I got it, but I am pretty sure everything is connected and there are no shorts. Or at least that's what a look under a microscope indicated. End result is the same, so that was obviously not an issue. Any pointers?
    www.kuzyatech.com My blog about things I make, break and fix
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Samsung Syncmaster 2333 No image, power OK
    Can we get a shot of the panel board (follow CN105 cable from the main board)? It is the board that sits right at the top of the lcd and may be underneath a metal shield.
    PS. Those are excellent photos and I visit your blog and see your posts on eevblog.
    --- begin sig file ---
    --- end sig file ---
    • kuzyatech
      • Sep 2012
      • 13
      The panel board? Here you go. I did not bother with whole board, just the main section. The rest is just driver flex connections
      Thanks for the kind words- I started the blog when I realized I've been fixing and tearing apart lots of things that other may find useful. Pictures are taken with an odd camera- Olympus TG-1. Its' a rugged/water and drop resistant thing to go swimming/hiking etc with, but image stabilization and high sensitivity get me better results than a DSLR
      • retiredcaps
        • Apr 2010
        • 9271
        Originally posted by kuzyatech
        The panel board?
        1) I circled a number of test points.
        2) Can you post the voltages for those and check to see if U101 is regulating properly?
        3) What is part number U201 on the panel board?
        • kuzyatech
          • Sep 2012
          • 13
          VCCF1 is 4.78V
          The other points you've circled are GND and I2C CLK and DATA
          GND is around 0v. CLK and DATA are idle at 3.3v and I did not catch any traffic. U101 is fine 4.78V In 3.3V out.
          The switcher to the right (U201). is generating +27, +5.6 and 9V and+12V as far as I can tell. There is a lot of audible noise from it with the cover removed. U201 is AAT1168B1
          U102 Novatek NT71208 runs a bit warm.
          • retiredcaps
            • Apr 2010
            • 9271
            The service manual for a Samsung 2333HD and 2333SW is
            If you can get into the service menu, that may give you a clue. Otherwise, the pdf file does show some other hints for you to try.
            I have noticed the main board in the pdf looks nothing like yours, but again you may get other ideas just be reading the service manual and looking at the schematics?
            • Vew
              • Sep 2012
              • 2
              I seem to be having a very similar problem. The only difference is that because I'm using it as a 2nd monitor, the blackout only occurs when I bring a certain menu or window up in that monitor. As soon as I close the menu or bring the window back, it reverts to normal almost immediately.
              I have the exact monitor hardware with the exact manufacture date. Caps and other hardware look fine. I found this thread on here with also the same problem but seemed to be a dead end.
              https://www.badcaps.net/forum/showth...samsung+2333sw
              Please try this for me. If at all possible, get into the monitor's menu and change your Color Tone or Color Effect to anything else other than the default. You only have to change one. Default is "Normal" (avoid "Cool also - "Warm" is the only working option) and "Off" respectively. For some reason, this prevents the problem from occurring.
              • kuzyatech
                • Sep 2012
                • 13
                I can't seem to get into the menu in the first place. if I hold menu on boot I get "Test Pass" message. No actual menu is ever shown- how is it supposed to behave?
                Also, found an Acer service manual (on their own servers oddly enough) created by Innolux that seems to include a universal schematic- most parts match. It even has comments like "Dell -install Rxxx, Benq, Samsung only etc"
                http://support.acer.com/acerpanam/Ma...L_20090714.pdf
                • jetadm123
                  • 2169
                  I don't know if this will work with your model, but from the service manual, you can enter the "service mode" by pressing these keys in sequence:
                  power off-->info-->menu-->mute-->power on
                  I don't what you can do in the service mode, but it's worth a try.
                  • Vew
                    • Sep 2012
                    • 2
                    Let me play around with it a bit when I get home. Maybe I can just give you the sequence. Hopefully, that might work.
                    When you mention you see a white line, then black, does like fade the pixels? What mine did was as soon as it happened, the screen began to white out, then followed by blacking of the edges until it moved to the center of the screen. At some point in the middle, it would look like a negative of whatever was on the screen. All this was over the course of about 10 seconds.
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                    • mrtek
                      Samsung UN43NU6950FXZA No power
                      by mrtek
                      Hi
                      Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                      Main fuse = OK
                      Back light LED = OK. Power them with aux power source
                      LED output = OK 156V
                      I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                      Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                      07-20-2025, 08:06 PM
                    • Journey11
                      Samsung TV won't turn on ... keeps cycling the power relay on & off
                      by Journey11
                      Hi All,
                      First time posting here ... my name is Kevin but my friends call me Journey.
                      I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
                      After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
                      It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
                      07-04-2024, 02:44 PM
                      by sam_sam_sam
                      03-31-2024, 02:12 PM
                    • nh2
                      Samsung SyncMaster 215TW buzzing / lightning in power board socket
                      by nh2
                      This is my first post here. I just fixed my first 2 broken displays by replacing broken capacitors (Samsung SyncMaster 226BW, and Samsung SyncMaster 213T). But I have a third one I'm unable to fix, and am eager to fix as well:
                      My Samsung SyncMaster 215TW makes a buzzing / hissing sound when turned on.
                      The sound is louder the brighter the monitor is, e.g. in the "Game" preset is is even louder than in a softer preset.
                      Opening up the monitor and unplugging the small socket cables that run from the power board to the LCD, I can see a small blue...
                      08-31-2021, 02:23 AM
