Dying PSU - guess which brand? Corsair.
  • Lyricist
    • Nov 2012
    • 4
    • Latvia
    So, to cut the story short. Bought a brand new Corsair GS 700 (Gaming Series, yes) since i am a sucker for using all those power consuming parts, like dual HD 4890.
    So, the best part - the PSU dies within 6 months of being bought new.
    It starts getting hick-ups and turns off within 5 minutes, it did so twice when i understood the problem is with PSU and left it be turned off.
    Next day - aint turning on at all, the fan spins twice before turning off.
    Ive given it to two experienced people since now and they all have handed it back to me with the same response: ''dont see the problem, seems to be running perfectly''. I was handed it back, decided to give it a try - heh, really does work.... for about half a day before the same old trick.
    Gave it to someone else to check the PSU out, and here come the conclussions:
    1) The damn power cables are faulty - you move them and the power disappears.
    2) The PSU has a tendency of turning off whenever it is put to test or task, as i shall say.
    3) Some chips could or condensators could be fried, which causes the PSU to turn off randomly.
    Truth be told, ive lost my Confidence or interest in Corsair as a brand at all.
    I dont see why i should pay top dollar for computer parts that die out within a few months.
    So, any suggestions on how to fix this, if it is fixable at all?
    Custom built PC - AMD Phenom II x4 965 Black Edition with Cooler Master Hyper 101, 8 Gigs of AMD Entertainment Ram @ 1600 Mhz DDR3, Club 3D HD 4890 1GB 256 bit GDDR5 with Arctic Cooling Accelero Twin Turbo, Gigabyte GA-MA790XT-UD4P (CrossfireX)
    Next build - i7
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: Dying PSU - guess which brand? Corsair.
    I've tried to avoid Corsair PSU's. Doesn't that model use Teapo caps? I'd check them. Clear pics of the inside would be great
    • mockingbird
      • Dec 2008
      • 5484
      No. The GS800 model uses a mix of UCC and Teapo but mostly Teapo.
      The GS700 model uses all Samxon GF series for the secondary:
      http://www.hardwaresecrets.com/artic...-Review/1617/5
      The electrolytic capacitors used in the secondary are from Samxon and labeled at 105ΒΊ C, as usual. See Figure 20.
      If they were Teapo SC, like in the GS800, it would have lasted a lot longer. Teapo SC is probably one of the best non-reliable series out there.
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        Ouch, Samxon GF?
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          I would create a new thread on the Jonnyguru forums about this.
          Corsair do have really good warranty and they have some company reps over there that glance over posts and they might be able to help you out...
          Coincidentally I do have a similar issue with my Corsair TX650 PSU but I have not actually tried to RMA it over this issue (Works fine as long as I don't hotplug any harddrives)
          http://www.jonnyguru.com/forums/showthread.php?p=66964
          • mariushm
            • May 2011
            • 3799
            Corsair is still supposed to have RMA for the power supplies, so go on their website and see what can be done.
            You can check the jonnyguru.com forums (link above), there's a Corsair representative there who may be able to help you but try to do the rma process on the website yourself first.
            Jonnyguru owner himself works at Corsair now.
            Yeah, don't bother complaining about capacitors to Corsair. They said they select just a few companies and analyze their quality and spew a lot of marketing talk, but they still mix capacitors between production batches even on their high end board. Seems like they just don't care, whatever is that day at the OEM manufacturer, that's what they use.
            Ex see AX860i ones... some have fpcap polymers, some have capxon polymers... some have rubycon electrolytics on the modular interface, some have taicon.. see the explanations in the thread:
            http://www.jonnyguru.com/forums/showthread.php?t=9530
            They use Samxon on their budget psu pcbs all the time.
            Seasonic so far is the only one I see they consistently use the same quality Japanese capacitors in their high end power supplies.
            If it was up to me, today I'd only buy the Seasonic G series designs
            • mockingbird
              • Dec 2008
              • 5484
              Why can't they use Samxon RS instead of Samxon GF?!
              • Lyricist
                • Nov 2012
                • 4
                • Latvia
                Cant be done taken in mind that i dont have the original check, so i cant verify my purchasal of this PSU, neither can it be done taken in mind that the warranty seal has been broken.
                Either way, here's some pictures i just took.
                http://i50.tinypic.com/140g6li.jpg
                http://i49.tinypic.com/set37s.jpg
                http://i45.tinypic.com/f087yt.jpg
                http://i49.tinypic.com/335beyp.jpg
                Next build - i7
                • mockingbird
                  • Dec 2008
                  • 5484
                  Very blurry photos, but it looks like yours has Teapo SC and not Samxon GF like Gabe's.
                  Would be interesting to test the Teapo SC caps. I have a bunch of them I took out of Fortron PSU's that are not bulged. If I ever end up buying an ESR meter, I would like to see just how many of them are really out of spec.
                  ...Anyway, if you post a list of the caps, someone can help you find replacements. It's worth re-capping. CWT PSH-II platform. You probably also want to touch up weak lead-free solder joints with an iron and flux.
                  • Lyricist
                    • Nov 2012
                    • 4
                    • Latvia
                    Sorry, couldn't think i coulda made any better screens atm, made it with an iphone 4 (not bragging, since i hate Iphones), the only thing better than that would be a small digital camera.
                    Any tips on how should i make this list? I wouldn't exactly deem myself as a professional when it comes to such things.
                    Edit: Yes, my PSU is using Teapo ones.
                    Also, apparently i have the discontinued version of the Gaming Series 700W Corsair PSU, aka CMPSU-700G.
                    Lucky me.
                    Next build - i7
                    • mockingbird
                      • Dec 2008
                      • 5484
                      Voltage, capacity, Brand, series, dimensions in mm (width x height).
                      • c_hegge
                        • Sep 2009
                        • 5219
                        Because their specs aren't right.
                        • mockingbird
                          • Dec 2008
                          • 5484
                          It's true, they're not as good as KZE, or as highly rated as Teapo SC. But for lower-wattage supplies, they're perfect.
                          • Lyricist
                            • Nov 2012
                            • 4
                            • Latvia
                            Well, if im correct, it uses Teapo 2200 uF capacitors, 16V
                            http://i47.tinypic.com/2d2vc3.jpg
                            http://i49.tinypic.com/1ieuf7.jpg
                            http://i46.tinypic.com/mc3spt.jpg
                            Couldn't find info on web, though.
                            Next build - i7
                            • Pipolups
                              Corsair K70 LUX RGB dying LEDs
                              by Pipolups
                              Hi there !
                              I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...πŸ˜…
                              Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me πŸ™„...
                              10-08-2024, 11:58 AM
                            • h0m3w0rk
                              Random Shutdowns/Startup Failure with Corsair SFX 450
                              by h0m3w0rk
                              I'm encountering a frustrating issue with my Corsair SFX 450 power supply. After an undefined period of operation, my PC will either suddenly restart or, in some cases, it won't start at all until I disconnect the power cable and reconnect it. This erratic behavior occurs intermittently, making it difficult to pinpoint the exact conditions under which it happens.
                              For context, I have tested the PSU using an electronic load at 150W, and under those controlled conditions, it functions flawlessly. This leads me to...
                              02-09-2025, 03:19 AM
                            • iMic
                              IBM NetVista Pentium III - USI Motherboard w/ Teapo SC
                              by iMic
                              Hi folks,
                              I have a couple of IBM NetVista desktop computers from around 2000-2001. They have Universal Scientific Industrial (USI) Pro286i motherboards, 733MHz Pentium III processors, and a whole bunch of bad Teapo capacitors. One board has visibly bad and venting capacitors, while the other doesn't look too bad so far.
                              The board with venting caps works fine, while the good looking board occasionally refuses to power on unless it's left for about 30 seconds after connecting the power - even with a known good power supply. (I am however aware I'll need to check the PSU...
                              11-29-2023, 06:44 AM
                              Corsair CX750M [Model 75-002019] - burned output toroid inductor
                              by momaka
                              Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
                              So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
                              09-19-2021, 08:44 PM
                            • hobostove
                              Corsair RM1000e - Help identify 5VSB Zener diode
                              by hobostove
                              Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
                              Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
                              There's a 22ohm resistor that's melted and open, but it still has the bands.
                              The other part is a zener diode and it's top went to jesus, so I can't read the marking.
                              It looks like the diode connects the source and drain of a TNY284...
                              03-27-2025, 02:25 PM
