Antec using JunFu/Fuhjyyu again
  • c_hegge
    • Sep 2009
    • 5219
    The PSU included with the VSK3500 case uses Jun Fu caps, which are re-sleeved fuhjyyus. Seriously, Antec... This may be a bundled PSU with a case, but there's no reason to risk a repeat of the SmartPower series! The case itself is one of the flimsiest I've picked up in a long time, and I can get the In Win Z583 (which is much more solid and includes a better PSU) for $10 cheaper!!
  • lti
    • May 2011
    • 2557
    Re: Antec using JunFu/Fuhjyyu again
    How did you find out that Jun Fu caps are relabeled Fuhjyuus? I remember a thread where someone mentioned that their datasheets are similar, but did someone confirm that they're the same company?
    That power supply does look lame. At least there's a Chemi-Con cap in there (probably for +5VSB).
    • c_hegge
      • Sep 2009
      • 5219
      I'm going by what I've heard here (and on JonnyGuru). It seems to be pretty common knowledge that Fuhjyyu, AsiaX and Jun Fu are all the same caps.
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        Agreed. If you look at Fuhjyyu TM, they have that ugly purple with the three prong vent. Then you look at Asia X TMX, they look identical, guessing they just added the X to the series because it's "Asia X" And I noticed that the datasheets for Fuhjyyu and Jun Fu have the same exact style and layout:
        Jun FU HK: https://cdn.badcaps-static.com/pdfs/...ac98dddb1a.pdf
        Fuhjyyu TM: https://cdn.badcaps-static.com/pdfs/...2b0feefebd.pdf (Thanks Uranium)
        That's sad that they're using them again, and CapXon as well. Shame on you Antec...
        Now that I think about it, I wonder if they dropped the Fuhjyyu brand name, I haven't seem them in anything made recently at all but Jun Fu and especially Asia X seem to be popping up in a lot of low end chinese PSU's
        • lti
          • May 2011
          • 2557
          I think you're right. The Jun Fu WG and Fuhjyyu TM datasheets look identical, aside from the company name. Either they use the same template and decided to make a bunch of equivalent series or they're the same company.
          • Pentium4
            CapXon Be Gone
            • Sep 2011
            • 3741
            ^ Yeah, probably. Maybe they're doing the same thing as GSC. Changing their name around, especially after the SmartPower era
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              I have a PowMax PSU from 2001 that has Jun Fu WG and Fuhjyyu caps inside, but the Jun Fu's have "X" style vents, while the Fuhjyyu's have their regular "Y" vents. So they may not be related after all, or at least it seems like they weren't in the past. Perhaps Fuhjyyu bought out Jun Fu, or the other way around?
              Either way, shame on Antec. I actually don't mind Fuhjyyu caps that much. I have a handful of used-pulls from PSUs (including that PowMax), and they still show good ESR and capacitance. The only ones that didn't were overheated ones (from nearby heat sinks, resistors, etc.).
              CapXon, on the other hand is a big NO-NO on my list. Guaranteed to fail quickly.
              • shovenose
                Send Doge Memes
                • Aug 2010
                • 6575
                Got a BFG 650W PSU today I bought online second hand - turns out it has a bunch of popped Jenpo (i think it was?) caps which was sad it's really well built otherwise.
                • c_hegge
                  • Sep 2009
                  • 5219
                  Odd. I find quite the opposite. It's Fuhjyuu that fail all the time left right and centre, while CapXon only fail if they're put next to hot parts (or in monitors) for me. I usually knock two points off in reviews for capxon and 3 for Fuhjyyu/JunFu/AsiaX (although in this case, I gave one point back for using an NCC KY as the 5vsb input cap, which is usually the first to fail)
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    Well you do live in the Southern hemisphere, so no wonder everything is the other way around
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      Same here, and I'm not down under... Kill them with fire! (and Nichicon HE )!
                      sigpic
                      (Insert witty quote here)
                      • c_hegge
                        • Sep 2009
                        • 5219
                        You must have read my mind. HE was exactly what I used to replace most of them (other than a few smaller ones which got replaced by pannies)
                        • Pentium4
                          CapXon Be Gone
                          • Sep 2011
                          • 3741
                          Yeah I actually think Fuhjyyu/Jun Fu/Asia X may be better than CapXon. A couple times I've been impressed with how well some of them have held up. Recently I saw a 3300uF 16V Jun Fu (Date code Feb. 2008) cap filtering the 12V in a CWT PSU, right next to a hot resistor, the resistor had gotten so hot that it charred a decent amount of the color/paint off the cap. It still read 3267uF and 0.03 ESR. Still replaced it though CapXon on the other hand....failing even with the most low stress roles
                          • sirpsychol
                            Antec Earthwatts EA-380 smd element type/value
                            by sirpsychol
                            While recaping Antec Earthwatts EA-380 I've broke one side of unknown smd element, it have no print, it's flatter and darker than smd capacitors on this board, shaped more like resistor but it's not resistor ofc. Unfortunetly the printed description was under it and element was glued to the board so I cant read/tell the letter before element number too. Have anyone any idea what it is? Maybe is there any diagram of this PSU?
                            09-03-2023, 07:58 PM
                          • ajdrenter
                            Picking caps for Antec SU-380
                            by ajdrenter
                            In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
                            https://www.badcaps.net/forum/showthread.php?t=14159
                            It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
                            05-13-2023, 10:40 AM
                          • s_henya
                            Antec VP-600P and NE550M dead
                            by s_henya
                            Got in these 2 nice PSUs, both died after power surge.
                            Both seems to be suffering from the same fault.
                            Blown main fuse
                            Shorted N mosfet 550v
                            VP-600P: 5R280CE short between GDS
                            NE550M: MDF18N50 short between GDS
                            In terns of board layout these seems pretty identical.
                            From past knowledge, once gate get shorted, most likely the for the driver to go bad as well.
                            I never tried to salvage blown fuse PSU with shorted Mosfet due to that.
                            Is it worth to try and replace the mosfets? is there a chance that the...
                            12-03-2024, 10:00 PM
                          • CWEastwood
                            Antec Smart Power SL300S capacitor replacement.
                            by CWEastwood
                            I'm currentlly in the process of trying my first power supply repair (really my first soldering project) and have some questions with regard to which capacitors to replace the bad ones.
                            The power supply is an Antec Smart Power SL300S ATX12V 300 watt.
                            I have successfully desoldered every capacitor from the board without destroying anything (I think) and I am currently in the process of choosing which caps to order. This is where I'd like a little community wisdom.
                            Now the capacitors inside are mostly Fuhjyyus (a forum favorite) with 1...
                            03-25-2023, 12:18 PM
                          • RUllER
                            chemicon produced by fuhjyyu
                            by RUllER
                            This is not a fake Chemicon, it is genuine
                            Many companies are outsourcing to Chinese factories....
                            01-29-2024, 12:22 AM
