Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > General Electronics
Old 09-12-2007, 09:40 PM   #1
wan901
Default Mobo cannot power on...
Hello guys... i like to ask you guys about motherboard..i had a Asus A8N-SLI the problem is cannot powered on .....but the light indicator was on ....is it the crystal or mosfet or caps problem ?? hope u guys help me out :P
wan901 is offline   Reply With Quote
Old 09-12-2007, 10:26 PM   #2
starfury1
starfury1's Avatar
City & State: land of OZ
Default Re: Mobo cannot power on...
humm more info would be helpful.....
By light indicator do you meant the one that possibly exists on the MB?
Have you tried another PSU?
I dont know the board but from a quick search it appears to be a newish one so caps would be far less likely.
What were the conditions of failure...was it working and just died or is this a new build (re build)
is it being overclocked or did you do some upgrade and now it don't work.
you may be real unlucky and the Mb has died, hope not
more info would help narrow the field a bit as to a possible cause
Also whats in the box with the dots
You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
starfury1 is offline   Reply With Quote
Old 09-13-2007, 12:08 AM   #3
wan901
Well ,yeah the mobo was working before this happen....nope im not overclocked it....yup its suddenly died when i open at the morning....yeah i tried with the other PSU already ....and i didn't see any caps failure.... =_=
Old 09-13-2007, 01:44 AM   #4
stevo1210
FD Civic Driver
stevo1210's Avatar
City & State: Eastern coast
My Country: Australia
Line Voltage: 240V 50Hz
I'm a: Student Tech
Send a message via AIM to stevo1210 Send a message via MSN to stevo1210 Send a message via Yahoo to stevo1210 Send a message via Skype™ to stevo1210
What brand was the original PSU? What colour is the light on the motherboard? Red or green? I have an Asus P4 series motherboard here killed by a faulty PSU and now displays a red lgiht instead of the usual green light.
stevo1210 is offline   Reply With Quote
Old 09-13-2007, 09:26 PM   #5
wan901
Well idicator light showing Green Light
Old 09-20-2007, 02:49 PM   #6
999999999
City & State: Near Cincinnati, OH
Line Voltage: 120VAC 60Hz
A few random suggestions (meant to be tried in this order?).
1) Disconnect AC power for a few minutes.
2) While you're waiting, clear CMOS or remove battery for this period then reinstall battery.
3) Try to power up system.
4) Check PSU voltages while attempting to power system.
5) Check function with a PCI video card instead of AGP or PCI Express
6) Does it have a floppy drive? If so, is it trying to access it as if it's wanting to be fed an emergency bios flash disk?
7) Are you certain the replacement PSU has suitable capacity and is in proper working order (not a very old, generic brand, or low wattage rating?)
8) Strip system down to bare minimum parts required to POST. 1 memory module, CPU, heatsink/fan, least power hungry video card you have (If PCI, even better). Disconnect drives, everything else - the goal is only to get it to POST and proceed from there adding back parts one at a time.
What do you mean by "it suddenly died"? Was it running and it shut itself off, or did it fail to turn on from having been previously shut off (manually)? When you try to turn it on, what exactly happens? Does the PSU fan run, does that fan even move a slight bit (looking at it while pressing power button)? Do all the fans and LEDs, drives spinning, etc, but it just doesn't POST, or ???
A crystal problem is very unlikely. A mosfet problem is also unlikely, and if the caps don't look vented that is also unlikely. They might not be impossible but playing odds, it would be better to look elsewhere instead of focusing on these things at present.
999999999 is offline   Reply With Quote
