Go Back   Badcaps Forums > General Topics > General Computer Discussion
Old 05-26-2009, 05:18 AM   #1
stevo1210
FD Civic Driver
stevo1210's Avatar
City & State: Eastern coast
My Country: Australia
Line Voltage: 240V 50Hz
I'm a: Student Tech
Question Printer smoke?
Wasn't sure where to put this thread but anyway....
I got a new printer to replace my aging Laserjet 5L which can't even pull paper down the tray properly anymore. The new one I purchased today is a HP Laserjet P1005 for $85 which is very cheap for a laser printer, but I am happy with it.
Um. it works, but there is one problem....
Everytime I print something I see smoke coming out along with the paper it has just printed. The smoke is a grey white and doesn't smell like burning electronics, but a funky shallow smell. It probably isn't a good thing to do in smelling this gas, but hey I'm okay for now.
I don't know if this has anything to do with my mistake of not removing some plastic protector bits over the toner roller and electric connectors to the printer board before stating it up for the first time, then printing only to find nothing came out!.... do you guys think that did any damage?
But still I want to know what that white/grey smoke is.... but one good thing is that it is printing papers really well so that's a start I suppose.
Thanks.
...You're speaking to a Honda enthusiast.
stevo1210 is offline   Reply With Quote
Old 05-26-2009, 08:06 AM   #2
Krankshaft
Krankshaft's Avatar
City & State: New Jersey, USA
Default Re: Printer smoke?
The fuser needs replacement.
An aroma will always be emitted during fusing. Non oem cartridges seem to stink more IMO. Not to mention the toner flaked off the paper when I tried third party once so I stay away from them. There will always be an aroma during fusing if you're close enough. But visible smoke is a no no.
Larger laser printers have fuser modules to make replacement easier. Smaller consumer grade models require disassembly.
Laser printers require maintenance. They're meant to be maintained not just thrown away like inkjets. I just replaced the transfer roller, paper pick up roller, and separator pad on mine.
This printer is used right?
Krankshaft is offline   Reply With Quote
Old 05-26-2009, 08:18 AM   #3
Krankshaft
Krankshaft's Avatar
Ahh I see. This printer is so cheap that it doesn't have a cooling fan for the fuser.
It's probably steam due to no forced air cooling.
Check out this link your printer uses the same engine.
http://forums13.itrc.hp.com/service/...04349+28353475
Either deal with it or buy a good used higher end model.
My two HP 1200s have been chugging since 2001 with over 50k on the clock each just 1 set of the above parts kept them going. Original fuser on both.
Old 05-26-2009, 02:00 PM   #4
dood
Deputy dood
dood's Avatar
City & State: Berwick, PA
Line Voltage: 120VAC 60HZ
I'm a: Hardcore Geek
Probably took some of that plastic in and melted it across the fuser roller. Lucky it didn't smoke you out or just plain catch on fire...
dood is offline   Reply With Quote
Old 05-26-2009, 03:09 PM   #5
willawake
Super Modulator
willawake's Avatar
City & State: Αθήνα
no i think that would affect the print
willawake is offline   Reply With Quote
Old 05-27-2009, 05:38 AM   #6
stevo1210
FD Civic Driver
stevo1210's Avatar
I'm a: Student Tech
I'll probably have to deal with this smoke because I can't afford anything more decent with the monetary supplies I have unfortunately.
Old 05-27-2009, 01:03 PM   #7
NxB
NxB's Avatar
Laser printers go cheap here, you can buy one at the thrift store. I wish I could afford laser color, those aren't cheap yet.
NxB is offline   Reply With Quote
Old 06-10-2009, 01:08 PM   #8
ratdude747
Black Sheep
ratdude747's Avatar
City & State: Madison, IN
Line Voltage: 120VAC 60Hz
with all that smoke, i guess the "easy bake" logo was missing
my family's to cheap to buy a laser
save up for one with a fan or wire a 12v wall wart to an old power supply/case fan or buy a hose fan and use that (zip tie small fans if necessary)
at least its an hp and not a lexmark
(Insert witty quote here)
ratdude747 is offline   Reply With Quote
Old 06-10-2009, 01:31 PM   #9
lucky13
City & State: Canada
Thanks.
stevo1210
Can you take this back to the store and exchange for another one?
Also make sure the paper you are using are dry. How's the humidity there?
lucky13 is offline   Reply With Quote
Old 06-12-2009, 12:28 AM   #10
stevo1210
FD Civic Driver
stevo1210's Avatar
I'm a: Student Tech
Originally Posted by lucky13
stevo1210
Many other people on the internet seem to report the same smoke issue as me so I don't think I'm an isolated case. The paper I use is dry and not moist or wet. The weather here is kinda ick right now.... very cold and cloudy at times but not raining.
Old 06-12-2009, 12:30 AM   #11
stevo1210
FD Civic Driver
stevo1210's Avatar
I'm a: Student Tech
Originally Posted by ratdude747
myths about the eee pc
* eee pcs are slow- this is only true with windows, with linux the thing is unleashed
* eee pcs are children's toys- just because the toy store stocks these doesn't mean its a toy; after all, AAA batteries are stocked, yet they aren't toys
* you cant be a gamer on an eee pc- with linux with wine, you can run a lot of games without frying atoms
* you can't video edit on an eee pc- with linux and Kino, you can
GO linux!!! windows mac as well
Bit off topis... but.... I love your sig. It is so true. I love the eeepc and various other Netbooks which run Linux. Unfortunately I bought a netbook with WIndows XP, but it's ok for me I suppose.
