Lenovo IdeaPad 330S-15ARR - 330S_ARR_V06
  • ibrahim03
    • Oct 2015
    • 143
    • egypt
    hi everyone
    i Need bios working for this model
    the Lenovo IdeaPad 330S-15ARR
    code the motherboard - 330S_ARR_V06
    thanks advance
  • mahmoodjavan
    Banned
    • Mar 2018
    • 584
    • iran
    Re: Lenovo IdeaPad 330S-15ARR - 330S_ARR_V06
    Originally posted by ibrahim03
    hi everyone
    thanks advance
    BIOS
    7wcn30ww.bin
    330S_ARR_V06
    • alesul
      • Oct 2019
      • 1
      • Romania
      Hello I have the same modell Lenovo 330s 15arr with cpu amd ryzen5 2500u and graphic integrated VEGA8 4gb ram 15inch full Hd,there is more variants of motherboard if I flash this file?
      • santuli
        • Jul 2015
        • 2
        • Ecuador
        Hi, please maybe someone have the kbc bios for this board??? Thank you
        • Claudiomfa
          • Nov 2015
          • 455
          • Portugal
          Try and report. Extracted from original file
          • throwasd
            • Aug 2020
            • 1
            • Argentina
            Originally posted by mahmoodjavan
            BIOS
            7wcn30ww.bin
            330S_ARR_V06
            Thank you, worked fine.
            • aprilbg087
              • Feb 2018
              • 30
              • Philippines
              hi every one
              i had thesame Lenovo IdeaPad 330S-15ARR
              it was no power
              found out it has short on main power rail
              ive tried to find the schematic for the board but failed.
              so i tried to check what is heating up,, found the mosfet frying itself,,
              ive removed the mosfet and injected 19v to the source( not sure yet if what type it is)
              ive done this because there are so much short caps around that area,
              then I found a bad cap very far from where i expected,
              its a filter capacitor,
              when removed, finaly i had charging light but no display, i suspected that i may had a currupted bios
              I did used the posted bios from this thread but didnt work, i looked for another bios chip that is work for 1.8v then I rewrite my old bios file, the the thing came back to life
              note: the mosfet is q5901
              the bad cap has no label, i can send a photo
              I will upload my bios file for the future errors related on bios. this is working bios file
              • M4n0l0307
                • Nov 2020
                • 167
                • Colombia
                Many thanks
                • smartfixtop
                  • Mar 2020
                  • 10
                  • eygpt
                  Try this one
                  Bios file + EC 👍
                  • tlough75
                    • Apr 2017
                    • 33
                    • US
                    I have same laptop. I push power button, fan spins then slows down, then speeds up, then slows down, etc... power light is not steady.
                    • Rhadu23
                      • Mar 2021
                      • 74
                      • United Kingdom
                      Attached is the old (corrupted) BIOS save.
                      I have found one by browsing the net but it does not read the nvme and crashes when trying to install on sata ssd.
                      Please help.
                      Laptop details:
                      S/N: YD04WDFH
                      AMD Ryzen 3 2200U
                      4Gb DDR4 RAM soldered
                      • fire1234
                        • Dec 2017
                        • 77
                        • Poland
                        Bios extract from exe, DMI entries copied
                        • Rhadu23
                          • Mar 2021
                          • 74
                          • United Kingdom
                          Still the same. Nvme is not detected. Sata crashes...
                          • fire1234
                            • Dec 2017
                            • 77
                            • Poland
                            See if this works, it is a clean bios without any entries, if the next thing happens, you need to look for a bug on the pcb
                            • Rhadu23
                              • Mar 2021
                              • 74
                              • United Kingdom
                              Works, but m.2 slot is dead...
                              • lukasrz
                                • Dec 2014
                                • 7
                                • polska
                                I fixed exactly the same problem.
                                Oirginal is BIOS chip 25q64fw - it's 1.8V chip, You need to reprogramm original chip with 1.8V. It will not work on 25Q64FV 3.3V chip, it will spins and slow down fans.
                                BIOS from post #2 works!
                                • REpairAT
                                  • Nov 2020
                                  • 143
                                  • Austria
                                  Thanks aprilbg087!
                                  Tried it out works well.
                                  Cheers!
                                  • edwinacero
                                    • May 2021
                                    • 1
                                    • Colombia
                                    Thanks for the file, I have not tested it yet but I thank you in advance for the collaboration.
                                    • jdemaria
                                      • Sep 2018
                                      • 1
                                      • Argentina
                                      Hi! Can you sendme a photo of the damaged caps?
                                      Thank you so much!
                                      • jarle
                                        • Jun 2021
                                        • 3
                                        • Santo Domingo
                                        I'm having the same issue. I can't update the BIOS pressing FN + R. the charging led start blinking 3 times then stop and do the same. it never end to update the BIOS. Did Im did something wrong?
                                          Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IGL05 boardview and IdeaPad 3 15IGL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 05:20 AM
                                          Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook 3 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15IHU6 boardview and IdeaPad Gaming 3 15IHU6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                          09-07-2024, 05:00 AM
                                          Lenovo IdeaPad IdeaPad Gaming 3 15ACH6 Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15ACH6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15ACH6 boardview and IdeaPad Gaming 3 15ACH6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
