#1 |
City & State: New Jersey, USA
So I was looking for a cheap CCFL inverter to test CCFLs I can hook up the input to my variable Mastech bench supply. While on my search today I ran across this.
http://www.casemodgod.com/Articles/c...erter_rant.htm The damage a failing CCFL inverter did to some guys case. Of course the guy is an idiot raising alarm where it isn't due and probably has no clue what an inverter really is or why it failed. Or that the monitor he viewed to write that message is backlit by CCFLs yet it still hasn't exploded in a fiery hellstorm .But in any case it got me thinking about these cheap Chinese inverters I'm willing to bet the reason it flared up is because of a lack of protection circuitry. Short circuit protection, over current protection, etc that all good inverters (on LCD monitors for example) have. Looking at these inverter boards they remind me of the gutless wonder power supplies just enough for them to function but nothing to stop them from blowing up in case of a failure on the output. Are there any decent 12V powered CCFL inverters out there that have protection out of the box?
Elements of the past and the future combining to make something not quite as good as either. Last edited by Krankshaft; 09-17-2009 at 11:48 AM.. |
#2 |
City & State: Canada
I kept the guts from a cracked LCD monitor (p/s, main board & buttons) to use for testing lamps.
#3 |
Mac Enthusiast
City & State: Chicago! Run 4 your Life!
Line Voltage: 120VAC 60hz
Hello.
I found stuff like this on eBay while looking for something else.... http://stores.shop.ebay.com/Electron...mrsZ1QQ_fsubZ9 Do you think it might be better than those little blue box things? I didn't see a fuse in the burnt one. Have Fun, Keri
The More You Learn The Less You Know! Last edited by KeriJane; 09-17-2009 at 06:54 PM.. |
#4 |
Great find thanks!!!
Those look just what I'm looking for I'm going to order some and datasheet the ICs. They look to be well designed and should be protected if they're mean't as LCD monitor replacements. Indeed stay away from those "blue and black box jobs". I was buying them to test CCFLs and occasionally (as the word test implies) some bad ones. I'd rather not have the inverter blow up in my face to tell me that the CCFL was bad Last edited by Krankshaft; 09-17-2009 at 07:39 PM.. |
#5 |
City & State: VA
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Student Tech
If you look at the last picture of that article, you can also see that the power supply is a Real PC Power Silence... aka a Leadman unit
Leadman PSU + cheap chinese inverter... A light show guranteed! But as you might expect, that light won't be comming from the CCFLs Last edited by momaka; 09-17-2009 at 07:48 PM.. |
#6 |
City & State: Rockhampton, Queensland, Australia
My Country: Australia
Line Voltage: 240VAC 50Hz
I'm a: Hobbyist
Such a CCFL inverter should have at least three things: low-ESR electrolytics, a fuse (with mention earlier), and a supply separation diode, so that the electrolytics in the CCFL inverter are not being subjected to excessive ripple current.
My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics. |
| Thread Tools | |
| Display Modes | |
