#21 |
City & State: Europe
it will have atleast 1 and probably more than 2 surfacemount fuses.
look for things that look like resistors but are clear or green - that's the usual colours. |
#22 | |
City & State: Canada
#23 |
Badcaps Member
My Country: United Frickin States
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
You are very welcome. Glad I could be of assistance. Good Luck!
#24 |
Fuhjyyu Killer
City & State: Behind a soldering iron
My Country: New Zealand
Line Voltage: 230V AC 50Hz
How did the socket get broken?
#25 |
Hi, I dont know if you have found a solution to your problem yet but i have a shop in Bedford TX and work on them daily.
1. Are you plugging the iPod into a computer via USB? If so thats your first issue. You need an external power supply like the wall or car charger. One that doesn't need drivers installed to power it on. 2. I would try a new flex cable from the docking port to the logic board. Swap them from the other one in the picture. See if that helps. 3. The Cable from the Logic board to the LCD in the first picture is indeed broken but wont cause the iPod to fail on recognition to a PC. Swap the batteries from the other iPod(i'm assuming you have another one) granite they are the same model and voltage. 4. Last I have replaced the charging/docking connections on iPod's and touch's and its a delicate job but can be done. Make sure your pins inside arent damaged or corroded(broken). If you want to try this let me know and ill put a walk through w pics for you. Let me know what you find out. Good Luck! Patrick |
| Thread Tools | |
| Display Modes | |
