Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > Troubleshooting Laptops & Notebooks
Old 07-23-2011, 08:48 PM   #61
redw00d
Default Re: Toshiba Satellite - Locks up when plugged in
sorry master to my previous post.
I've just open my toshiba m200 laptop and under the CPU is the NEC/TOKIN 0E128 (1200UF). Just wanna ask what type of capacitor could I subtitute? how many capacitors? and the rating of each capacitor.. thanks in advance.
redw00d is offline   Reply With Quote
Old 07-25-2011, 12:38 AM   #62
incradibles
City & State: UAE
this technique worked for me thanks
Silence Like Dreams
incradibles is offline   Reply With Quote
Old 08-04-2011, 11:23 PM   #63
benmah
Talking Re: Toshiba Satellite - Locks up when plugged in
I have nec tokin Oe128 replaced with 4x 330e75 tantalum cap (i believe it a 330uf 2.5V cap). It works perfectly without fail after one yrs but I think it has cause my build-in multi card not to work any more from the beginning. Then I replace it with the orignal nec tokin 0e128. It still works but 2 month till now it starts to show sign of failing. It happen few days ago 3 times cut off suddenly. Now I plan to put back the 4 x 330e75 cap. Don't waste time on the 0e128 cap as it is not durable. I believe it has a 5000hrs life span on a ideal condition from the datasheet. Take a look at the pic. I use only a normal soldering gun. I just break the 0e128 with a test pen and small long nose pliers carefully. Clean up the contacts. Then carefully solder. Hope this helps U guys out there.
benmah is offline   Reply With Quote
Old 08-05-2011, 01:26 AM   #64
seraniko
thanks to this forum i finally fixed my toshiba l300. for raplacement caps here is one of my reference.
http://www.nec-tokin.com/english/pro...capacitors.pdf
seraniko is offline   Reply With Quote
Old 08-05-2011, 11:03 PM   #65
Volkymaniac
City & State: PR
Hi benmah; I'm trying to take out that 0e128 supercap, but it's very hard. How do you take out that??? I have the 330uf caps ready.
Volkymaniac is offline   Reply With Quote
Old 08-12-2011, 03:07 AM   #66
redw00d
thanks for the information bro. All i want to do now is to remove the supercap and find a tantalum capacitor.
Old 08-23-2011, 11:45 AM   #67
fabiog
So will it work with caps higher than 2.5 eg 6v.
fabiog is offline   Reply With Quote
Old 08-27-2011, 08:22 AM   #68
PVH
E ai irmao, ablacon64?
Where can I find these caps (the four replacement you used) in Brasil? Can you send me an address or phone where I can buy/order those? Valeu...
PVH is offline   Reply With Quote
Old 08-29-2011, 12:19 PM   #69
fabiog
I just made my satellite work with 4x 330 4v caps and a 60w soldering iron lol.
Thanks for all the help
Old 09-12-2011, 10:01 AM   #70
Thedead
I fixed one toshiba satelite using 4x 330e71 it working fine now. One more to go.
Thedead is offline   Reply With Quote
Old 09-13-2011, 06:05 AM   #71
zmec
Hello everybody, nice forum!
Has anybody tested NEC/Tokin OE128 in circuit?
What readings did you get?
I tested it and got C = 1770uF ESR = 0.00 ohm
I am confused.
Is it faulty or not?
(A200 Restarts and will not boot successfully when connected to AC, on battery it works ok)
zmec is offline   Reply With Quote
Old 09-17-2011, 11:07 AM   #72
wmbuddhi
Originally Posted by ablacon64 View Post
I had the opportunity to solve another one with that same problem, this time I took some pictures. Hope it helps.
The notebook is a Toshiba Satellite A305-S6872.
The first image shows the capacitor removed, board cleaned.
The second, new solder added to the pads.
And finally, the finished job.
Can i use higher voltage tantalum capacitors for the above solution? (like 10 v) ?
wmbuddhi is offline   Reply With Quote
Old 09-18-2011, 07:39 AM   #73
ablacon64
No problem.
ablacon64 is offline   Reply With Quote
Old 09-18-2011, 02:33 PM   #74
riget
City & State: Leicester
My Country: UK
I had a Tosiba with the same fault, I removed the nec/tokin oe128, fitted 4x330 e51's removed from a scrap board and it's working fine.
Thanks.
riget is offline   Reply With Quote
Old 09-23-2011, 10:51 PM   #75
manuel76
Hi sir/s, is there any other replacement value for 330uf with 2.5v? can I use a higher value instead? TIA
manuel76 is offline   Reply With Quote
Old 09-30-2011, 05:12 AM   #76
benmah
Hi redwood,
Sorry I was not following the thread. If it's not too late. As I have said I just use a test pen or screw driver and pry it off the motherboard carefully and clean the contact with the solder iron(prefer a higher wattage solder iron). It sound crude but you have no way of removing it with a standard solder iron. This is my only way.
Old 09-30-2011, 05:18 AM   #77
benmah
I am confused.
Don't waste your time on this useless and not durable capacitor. Your problem is definetely the 0e128 stupid cap. After replacing it only lasted 3 month and back comes the same thing. Just replace it with the 330e71 tantalum cap 4 pcs.
Old 09-30-2011, 05:25 AM   #78
benmah
The 0E128 is 1200uF. So 330uF x 4 =1320uF. I would not risk going any higher value. You can use a higher voltage cap though but not too high..Keep the value within range of +-1200uF
Old 10-01-2011, 10:18 AM   #79
ablacon64
Make it a little higher, never a little lower.
Old 10-04-2011, 08:05 AM   #80
wmbuddhi
Was this having nec/tokin OE128 OR 907 previously? Is it ok to solder 4x 330u s for a board having a OE907 originally because its capacitance is 900u right?
please help
