#441 |
I was reading this and thought it might be relevant to the thread: http://reviews.cnet.com/8301-33199_7...ty-capacitors/
#442 |
Yeah I saw that as well... too bad the monitors aren't included (as it seems they should be!).
Can someone please verify this is the correct mains cap? I saw about two whole pages of 450V 82uF caps on there :/ http://search.digikey.com/us/en/prod...7426-ND/411686 |
#443 | |
City & State: Phoenix, AZ
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist
A quick way to locate a cap is to enter the value and voltage in the search box, hit Go, select Aluminum, then start elimination based on the parameters. Temperature and dimensions are two obvious ones, in stock and lead type are also important. PlainBill
For a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored. Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic. |
#444 |
Ah ok, thanks. Yeah I did enter the value and voltage, and went aluminum. Just couldn't recall what temp the one on the board was (wanted to go ahead and order, and am at work and not in front of the board).
#445 | |
I'm a: Hobbyist
PlainBill |
#446 |
City & State: Burnsville, MN
I just fixed my PSU changing out all of the caps for this model and here are quality caps I used and worked perfectly for mine.
Code:
Samsung SyncMaster 245BW
Power Supply Board assembly Aluminum Electrolytic Capacitors
(1) CP801S 82uF 450WV 105 C Panisonic-ECG EET-ED2W820CA
(cap requires a hot iron with large tip)
(1) CB853 2200uF 10V 105 C Panisonic-ECG EEU-FR1A222L
(1) CM857 1000uF 10V 105 C Panisonic-ECG EEU-FR1A102L
(2) CM851 1000uF 35V 105 C Panisonic-ECG EEU-FR1V102
CM852
(1) CM855 470uF 35V 105 C Panisonic-ECG EEU-FR1V471
(2) CP804 10uF 50V 105 C Panisonic-ECG EEU-EB1H100S
CM814
(1) CB805 2.2uF 50V 105 C Panisonic-ECG EEU-EB1H2R2S
(1) CB804 22uF 50V 105 C Panisonic-ECG EEU-EB1H220S
(3) CB809 47uF 50V 105 C Panisonic-ECG EEU-EB1H470S
CB812
CM806
#447 |
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
Bad resistors due to "bad glue" symptom are very common in this model.
I use Panasonic FM/FC series. |
#448 |
City & State: US
Those Panasonic EB series are general-purpose, not low ESR. The FC series is available in those values.
#449 |
So I got the full replacement kit of caps, as well as the mains cap (separately). Once I got the mains cap in today I noticed in comparing it to the old one the old one was bulging quite a bit. So I just replaced the mains cap for now and that was it! Fixed right up!! Woo hoo!!!! And I still have the full kit for if/when I start losing the other caps. Thanks again everyone!
Oh and just to note, Bill, that cap you recommended was exactly the same specs but for some weird reason it was actually a bit smaller (pics below, the arrow is the before shot). Not sure why it was smaller, but it's working great so far, the monitor looks great! |
#450 |
That large cap in the primary side, you can tell if it is filtering properly or not when it has heavy load by check the DC reading on the cap, if the 120VAC is the input voltage, you should see about 120 x 1.414 = 169VDC, when cap dries out and drop its value, the DC voltage will drop by 20VDC or more, and if you set your DMM in AC mode, you will see large AC voltage reading on the meter since there will be large AC ripple riding on top of the DC. This is just a basic test if you do not have an Oscilloscope to look at the amount of AC ripple on the cap.
#451 |
The second of my three 245BW monitors went dead today. Same symptoms as before, blue light and no display. It will be interesting to see if it is the same resistor problem as before or something else. Will post results or ask for help if I get stuck.
#452 |
The second failed monitor has been repaired and is running again. One of the 68 ohm resistors was open. I replaced all three. I inspected the caps and they all looked good. It was six months between the first monitor failing and this one. I wonder how long it will be before monitor number three fails.
#453 |
City & State: St. Paul,MN/usa
FYI!
I have a Samsung XL20 Model #LS20EDBEB/XAA . LCD 20" LED Backlight with a samsung Power supply # BN96-04024A. Looks like the same supply as syncmaster 245B supply # bn44-00173. found that most of the components and reference designators are the same, good stuff. And I was about to shell out $87 on a new supply. I don't think so. Thanks!! |
#454 |
@dbinokc, I fixed three of this model, with one open 68 Ohms resistor in all the the three I fixed, make sure to remove the bad brown glue from components and the boar traces.
#455 |
City & State: Sweden
My Country: Sweden
I just finished repaired my 245B with the help of reading this thread.
Love to all in this thread ! |
#456 |
Repaired the Power supply # BN96-04024A on a Samsung XL20 Model #LS20EDBEB/XAA . LCD 20" LED Backlight.
The problem was KIA431 ref ZDM851 on syncmaster 245B schematic (ZDS851 ref on the BN96-04024A ) , thanks goes to whoever drew that up. |
#457 |
City & State: California
Interesting...first time I've heard of the BN96-04024A used on a 245B. Also, good work on troubleshooting. It's not often a shunt regulator fails.
#458 |
City & State: Los Angeles, California
Hi Guys,
I've got the issue on my 245BW where my power button lights up, but no picture on the screen (totally black). I am going to attempt the 14 cap replacement on my 245BW power board, but was wondering: - Is there any kind of soldering iron that would be good for this job? (wattage, other specs?) - Any particular brand or model of soldering iron? Thinking of a Weller analog, but wondering if that is overkill for this job? (I have a 20 year old Radio Shack soldering iron, and think its high time for a new one). - What kind of solder should I be using, specifically for this job? Many thanks for the great info and insights! N~ |
#459 |
City & State: Buenos Aires
My Country: Argentina
Line Voltage: 220VAC 50Hz
Weller 40w should be just fine. A ceramic heating element is vital.
Remember to use a sponge to clean your ceramic heater. |
#460 | |
City & State: Canada
If you want to buy a new one, the Hakko FX-888 is very popular and I think it was on sale at Frys for $65.
--- begin sig file --- If you are new to this forum, we can help a lot more if you please post clear focused pictures (max resolution 2000x2000 and 2MB) of your boards using the manage attachments button so they are hosted here. Information and picture clarity compositions should look like this post. We respectfully ask that you make some time and effort to read some of the guides available for basic troubleshooting. After you have read through them, then ask clarification questions or report your findings. Please do not post inline and offsite as they slow down the loading of pages. --- end sig file --- |
| Thread Tools | |
| Display Modes | |
