#101 | |
#102 |
You are correct. I misread that. Did you test with it in place or out of circuit?
Thanks |
#103 | |
Would this be the correct part to order: http://search.digikey.com/scripts/Dk...16794095449691 |
#104 |
Tested in and out of circuit, result the same.
#105 |
You can try this transistor, but maybe your controler is burned again. I first changed this br and then changed f9222L.
#106 | |
#107 |
I dont know this.
#108 | |
City & State: North Andover, MA. USA
I finally got my F9222L parts in and replacing it did not help with the unstable 24V when all six inverters are connected to the backlights. There is something else that is the root cause and I will need to dig in deeper to find it. The "BR" transistor you mentioned on your mail is actually "BQ" on mine and I believe someone else mentioned that. I was able to find a partial schematic for this power supply so it should make things a little bit easier in trying to troubleshoot this. In the schematic this "BQ" transistor is marked as a 2SC2412 NPN transistor. It does indeed come up with this transistor when searching for "BQ sot-23" on the net. Unfortunately the one on this board measures ok as a transistor. I was going to use a resistive load to load one of the inverter outputs such that it will the power supply will stay on. Do you know how much current a typical 19 or 20 inch length backlight consumes ? The 24V output is rated for 2.5A per the silkscreen on the power supply board. I'm estimating each of the backlights is drawing about 300-350mA. Using 3X 1K ohm in series should get me in the ballpark. I'm expecting the 24V output to be stable and continue to run. We will see. |
#109 |
How did you manage to find a schematic of the power supply? I'm pretty sure samsung wouldn't have just emailed you a PDF if you contacted them. Or maybe they did?
Could you post a link? |
#110 | |
#111 |
Or maybe Aruba your board is not the same like mine, and have somme other diferences. And for flickering, maybe is somme zener become a little bit weak and releasing on lower voltage then is normal to release. And check all caps with esr tester for hi esr, and with dmm for shorts.
#112 |
I have 2 of these 245bw's 1 has the blue light only problem, the other is a flickerer, just found this forum, I will try to test them out
#113 | |
the flickering goes away and the 24V is stable. Once it sits like this and all warmed up I can lower this current lower to about 0.2A before it will start to flicker again. Some components are much more sensitive than others to the freeze spray I apply to them but the area of where the 5.6V zener diode (DZM803) is the most sensitive. I have tested this zener and it does test out as a 5.6V zener. I do have some other 5.6V zener I can try to replace with but don't have a good feeling that it will fix the problem. I measure a slightly fluctuating voltage on CP803 82uF, 450V bulk cap of between 356-375V and the power factor measured is only 0.65. What do you measure for voltage on the bulk cap and have you measured the power factor ? |
#114 | |
#115 | |
which when working properly should be a solid voltage. I was expecting somewhere between 370-400V. Today using a scope I measured this voltage again and I got something totally unexpected. You can see the waveform on the included picture. As you may know this monitor has a PFC (power factor corrected) front end that boost the line voltage up to around 370-400VDC. A TDA4863 IC from Infineon is used to accomplish this feature which when working properly should present a power factor that is close to 1. Practically though the achievable power factor is between 0.90 - 0.99. As when I measure the power factor using a power analyzer I measured only a power factor of 0.65 which tells me that the power factor correction is not happening. I was not able to find anything wrong with any of the components surrounding the IC so maybe the controller is at fault. Again I don't have any of these IC so need to make another order. For those that want to check their flickering monitors if they have the same symptoms I have they can: - measure the voltage across the 82uF, 450V cap and see if they also have a fluctuating voltage between 356-375V. - measure the 24V output and see if that fluctuates between 20-24V. - use a hair dryer and heat up the area of pin7-14 of the F9222L IC and see if the flickering goes away and when it cools down that the flickering returns. |
#116 | |
#117 | |
better when it is "cold" meaning the components within the product has not warmed up to their usual working temperature. The time to failure could be hours before the product starts to show the failing symptom(s). A heat gun or a hair dryer will do in a pinch to warm up the area you think has a temperature sensitivity. This method is just to accelerate the heating process where otherwise you may have to wait for many hours before the symptoms appear before you can narrow the problem area. Products that works correctly do not or should I say should not have a temperature sensitivity in the typical operating range of 0-40 deg C. On the other hand for a product that has a problem only when it is "cold" you can do the opposite and try cooling the area down that has a temp sensitivity with freeze spray. These usually come in a can form and you can attach a tiny tube to it so you can direct the cold spray only to the area of concern. Using both heat gun and freeze spray in conjuction with each other you can sometimes see the symptom come and go and therfor hopefully narrow the problem down to the component(s) that is no longer operating correctly within the typical 0-40 C temp range. |
#118 | |
I wait for you to solve this flickering problem. |
#119 |
Aruba??
Flickering solved or you gived up on this? |
#120 |
I see you have an oscilloscope.
This days me to bouth my first scope, is a cheap one, and second hand to, and have only one probe 10x for now. Starting to make some measurment with scope, but must buy a 100x probe, because my scope is only 20v. Picoscope adc200/50. 25mhz. For starting and investigating on 100khz smps power supply i think will be good anough. Can you give me somme advice on this? |
| Thread Tools | |
| Display Modes | |
