ISL6556ACB ISL6556ACBZ ISL6556ACR ISL6556ACRZ PWM Controller Datasheet
    Optimized Multi-Phase PWM Controller
    with 6-Bit DAC for VR10.X Application
    The ISL6556A controls microprocessor core voltage
    regulation by driving up to 4 synchronous-rectified buck
    channels in parallel. Multi-phase buck converter architecture
    uses interleaved timing to multiply channel ripple frequency
    and reduce input and output ripple currents. Lower ripple
    results in fewer components, lower component cost, reduced
    power dissipation, and smaller implementation area.
    The ISL6556A utilizes rDS(ON) current sensing in each
    phase for adaptive voltage positioning (droop), channel
    current balancing, and overcurrent protection. To ensure
    droop accuracy, an external NTC compensation circuit can
    be used to completely nullify the effect of temperature
    related variation in rDS(ON).
    A unity gain, differential amplifier is provided for remote
    voltage sensing. Any potential difference between remote
    and local grounds can be eliminated using the remote-sense
    amplifier. The precision threshold-sensitive enable input is
    available to accurately coordinate the start up of the
    ISL6556A with Intersil MOSFET driver IC. Dynamic-VID™
    technology allows seamless on-the-fly VID changes. The
    offset pin allows accurate voltage offset settings that are
    independent of VID setting. The ISL6556A uses 5V bias and
    has a built-in shunt regulator to allow 12V bias using only a
    small external limiting resistor.
    Features
    • Precision Multi-Phase Core Voltage Regulation
    - Differential Remote Voltage Sensing
    - ±0.5% System Accuracy Over Temperature and Life
    - Adjustable Reference-Voltage Offset
    • Precision rDS(ON) Current Sensing
    - Accurate Load-Line Programming
    - Accurate Channel-Current Balancing
    - Low-Cost, Lossless Current Sensing
    • Internal Shunt Regulator for 5V or 12V Biasing
    • Microprocessor Voltage Identification Input
    - Dynamic VID™ Technology
    - 6-Bit VID Input
    - 0.8375V to 1.600V in 12.5mV Steps
    • Threshold Enable Function for Precision Sequencing
    • Overcurrent Protection
    • Overvoltage Protection
    - No Additional External Components Needed
    - OVP Pin to drive optional Crowbar Device
    • 2, 3, or 4 Phase Operation up to 1.5MHz per Phase
    • QFN Package Option
    - QFN Compliant to JEDEC PUB95 MO-220 QFN - Quad Flat No Leads - Product Outline
    - QFN Near Chip Scale Package Footprint; Improves PCB Efficiency, Thinner in Profile
    • Pb-free Available (RoHS Compliant)
