0805 SMD question
  • MaineFix
    • Jan 2023
    • 17
    0805 SMD question
    Please correct me if I am wrong.
    I have what I believe is a capacitor. 0805 size.
    I have a full book of 0805 SMD so I'm pretty sure I have the one I need.
    I'm trying to identify what this is:
    HCB2012KF-121T50_0805
    5A 1 20m 25% 120@100MHz 0805 Ferrite Beads ROHS
    Could someone explain to me how to read this?
    Thank you in advanced.
    This community is awesome!
  • MaineFix
    • Jan 2023
    • 17
    Re: 0805 SMD question
    Okay, so I believe this is a ferrite bead which is just a component that reduces interference. So if I test both sides of this component should it be open as if it is a wire straight through?
    • UNITRAX
      • Jan 2023
      • 64
      • POLAND
      Maybe this will help:
      https://www.schukat.com/schukat/schu...1SN1D&wg=D5419
      A ferrite bead is also commonly called a ferrite clamp. It's a passive device that improves your PCB's power quality, designed to suppress high-frequency signals on a power-supply line. They're typically placed around a power supply / ground line pair that's incoming to a specific device.
      Their principle use is as an EMI filter on power inputs, often on the input to a common-mode EMI filter circuit.
      BLM21AG121SN1D
      https://www.schukat.com/schukat/schukat_cms_en.nsf/index/CMSDF15D356B046D53BC1256D550038A9E0?OpenDocument&wg=D5419
        • 30964
        it's an inductor and should have a very low resistance
        • H H
          3090 FE Part Confirm/Identification
          by H H
          I'm hoping someone could help me confirm if I have identified the following parts correctly.
          Apparently the DP cable became stuck inside the graphics card and was yanked out. This caused some sort of short which burned the DP contacts and blew some resistors and ferrite beads.
          The parts needing replacement are on the back of the board behind the HDMI input.
          I have identified the parts as the following:
          C6037: MLCC 0.1uf/16v(0402)x7R W05
          R6016: RES 499 OHM 1/16W (0402) 1%
          LB10911: Ferrite Bead (0402)...
          02-16-2025, 01:09 PM
        • mrkmpn
          Finding comparable ferrite beads on mouser/digikey?
          by mrkmpn
          I have an inspiron with "power rail failure" LED codes flashing, and have found a blown capacitor and ferrite bead (inductor, I guess...)
          I've found the replacement capacitor on mouser, but am unsure how to properly search for the ferrite bead. I have the schematics and boardview, so I have found the original bead part#, but the data sheet doesn't seem to include the information I need for the filters on mouser and digikey.
          For inductance, and a few other values it just says "Refer to standard electrical characteristics list"
          Here's...
          10-12-2022, 01:54 PM
        • swerg
          Part selection for possible blown inductor on ASUS GX531-GW-AB76 laptop mobo
          by swerg
          Hey everyone,
          I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
          I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
          I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components...
          06-06-2024, 03:39 PM
        • 90Ninety
          Repairing RX460 , VRM?
          by 90Ninety
          Hi guys
          In my spare time to upskill myself I buy joblots if stuff to fix , or attempt fixing and get some experience
          I have a r460 that I wanted to fix and give to my nephew
          As shown there is a burned ferrite bead, next to a high/ low side VRM pair on the back side of the card
          I'm gonna try replacing these pair of VRMs. I wondered how hard they are to remove
          I have a decent sequire solder iron and hot air, though may need to get a hot plate.. Seems these VRMs have big contact plates and could be welded
          Also seemingly...
          04-30-2024, 07:54 AM
        • Borges
          Burned ferrite bead RTX 2080 LB617
          by Borges
          have purchased an RTX 2080 which contains a scorched component. I have carefully removed it with a heat station. The card is not short and it works, but it is seen with artifacts.
          The problem is that I cannot find the characteristics of the component anywhere. I am going to attach a photo in case someone has the same graphics card and can measure the component or if someone knows which one I have to buy. I would really appreciate it
          :trashcan:...
          12-14-2021, 03:20 PM
