Bad Caps affect on time / clock functions
  • Use2bavolvo
    • Jan 2023
    • 11
    can someone please help elaborate if a bad cap will affect time / clock functions. My fancy coffee machine has a preset pour for espressos's all of the presets are way out of wack what use to be 25 seconds is now 12.
    I am about to replace the psu caps but need some guidance if a bad cap would slow down or speed up clock functions?
  • petehall347
    • Jan 2015
    • 4429
    Re: Bad Caps affect on time / clock functions
    maybe more of a firmware issue if the actual readout is wrong .
    • redwire
      • Dec 2010
      • 3912
      If the filter caps are failing, the MCU gets dirty power cutting in and out which can corrupt EEPROM saved values or prevent the MCU from timing properly.
      With no model number, no pictures of the coffee machine, it's hard to give details.
      • flat-earther
        Adding a clock battery to action camera to retain date&time when changing batteries Campark X25
        by flat-earther
        I have a cheap action camera with an annoying trait, every time I change batteries the date & time gets reset and I have to set it again.
        To solve this problem I want to add a small internal battery inside it which will keep supplying power to the camera for a while while I change batteries so the date & time is retained.
        I have opened the camera and I think there is enough room to add something inside to accomplish this:
        The camera is powered by a 3.7V nominal single cell lithium ion battery.
        So I need to connect another battery in...
        06-08-2025, 02:00 AM
      • Paxman_Swede
        by Paxman_Swede
        Hello!
        01-14-2025, 09:51 AM
        by momaka
        03-15-2023, 10:17 PM
      • KYBOSH
        Leviton SmartlockPro Programmable Electronic Timer Switch With Astronomical Clock Wont Keep Time After Power Outage
        by KYBOSH
        Model number VPT24-16Z.
        https://leviton.com/products/vpt24-16z
        I have 3 of these in my home for over 10 years now and Im planning on replacing them as I lean towards a Philips Hue home setup.
        They are great units but they lost the ability to keep/store the time and settings after power outages and brown outs.
        I knew it was a battery in there somewhere but never got around to looking into it.
        Well an opportunity came for me to remove this from its home in my wall so I disassembled it to see what was going on.
        I found a 3.6V LIR1632 battery spot...
        07-31-2024, 09:37 PM
      • captain150
        by captain150
        03-16-2025, 07:34 PM
