Identification Problem?
  • Neotheone
    • Mar 2012
    • 38
    • England
    Hi, can anyone give any assistance with this item - having problems finding out what it is as one is burnt out on board.
    looks like id WG9J or W89J ?
    Picture not the best but should be ok for id process.
    this is from an unbranded 32" lcd tv but matches Technika type and it off the main board L2M08 2008.12.26.
    any assistance would be great.
  • Neotheone
    • Mar 2012
    • 38
    • England
    Re: Identification Problem?
    Sorry it is not the best description but just trying to identify and replace one of these parts that has burnt.
    Thanks in advance
    • Nikochan
      • Sep 2013
      • 17
      • Turkey
      If you search for the SMD code "G9" in here instead of WG9J, you'll get 9 different products but only one of them has 3 pins, which is of type BF 767, manufacturer is either Siemens or Philips.
      Then if you go and search for BF767 in this page, you will indeed find Siemens and Philips datasheets for BF767.
      This Philips one for example, which is a PNP Silicon Planar Transistor BTW, is indeed used in TV tuners:
      • Duncanbest
        • Jul 2012
        • 81
        • Taiwan
        FYI
        https://www.google.com/search?client...hannel=suggest
        • theOracle
          • Nov 2012
          • 163
          it is definitely WG9J and definitely some kind of planar surface-mount transistor
          if it was me, I would replace every electrolytic cap in this TV, those transistors don't burn for no reason!
          __________________
          the BIG 4
          ~~~ the top tier of low-ESR electrolytic capacitors ~~~
          • Neotheone
            • Mar 2012
            • 38
            • England
            Thanks for the information on this - top job keep it up
            thanks again!
            • Neotheone
              • Mar 2012
              • 38
              • England
              Well I am slightly confused, when trying to locate to order some of these the identification is not showing up, can find some types but unsure of the values needed any pointers from the technically minded at badcaps?
              • theOracle
                • Nov 2012
                • 163
                search on KTC3876
                __________________
                the BIG 4
                • theOracle
                  • Nov 2012
                  • 163
                  I think this is a suitable crossover to your part -
                  www.vetco.net/catalog/product_info.php?products_id=2935
                  __________________
                  the BIG 4
                  • Nikochan
                    • Sep 2013
                    • 17
                    • Turkey
                    http://www.ebay.co.uk/itm/BF767-SMD-...-/400360932457
                    • Neotheone
                      • Mar 2012
                      • 38
                      • England
                      Thanks again, lost there for a while - not had to a fix for someone for a while lost the way abit thanks again
                      • futurespec
                        • Oct 2013
                        • 24
                        • United Kingdom
                        unbranded 32" lcd tv L2M08 MAIN AV BOARD
                        I HAVE A PROBLEM WITH SOUND
                        THE SOUND WORKS WHEN TURNED ON AND AFTER 20MINS THE SOUND GOES
                        NEED DIAGRAM OF THE BOARD AND ANY INFO SO I CAN REPAIR
                        • theOracle
                          • Nov 2012
                          • 163
                          post high resolution photos of the board, often times problems like bad capacitors will be obvious
                          __________________
                          the BIG 4
                          • futurespec
                            • Oct 2013
                            • 24
                            • United Kingdom
                            Ive checked some capacitors and tried the black resister on the back but no luck yet
                            • theOracle
                              • Nov 2012
                              • 163
                              you need to post these questions to the badcaps TV subforum - that is where the TV gurus are on here!
                              __________________
                              the BIG 4
                              • janos6662000
                                Philips 47PFS7509/12 LCD TV problem
                                by janos6662000
                                Hi
                                I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                                When i applied cable signal to check image, i had normal picture, but TV was restarting.
                                I downloaded original firmware and applied the update, but the problem remained.
                                From a colleague i received a "factory package software" which is a lot bigger.
                                I made another firmware update, but still did not solve the problem.
                                Somewhere on the way the error got worse, because at the moment the...
                                08-12-2025, 12:54 PM
                              • courtcircuit
                                Philips HTS8000 home cinema noise problem
                                by courtcircuit
                                Hello
                                I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                                Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                                Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                                I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                                Removed each of tyhe boards
                                02-08-2025, 08:22 AM
                              • theone111
                                by theone111
                                3. Problem: TV shuts down
                                07-22-2024, 10:36 AM
                              • bohaboha
                                PHILIPS 32pfl3403d Flat-panel TV Upgrade Assistant problem
                                by bohaboha
                                Hi trying to update my Philips cause in retail mode not possible to get out from it i get this message in update site : Error message: no data exception. Your reference: Request ID (server_1930105)
                                how to fix it thanks
                                02-05-2025, 09:23 PM
                              • atkallu
                                Philips 58PUS8545 t-con problem or something else ?
                                by atkallu
                                Hello
                                I have a Philips 58PUS8545 which have a vertical moving lines on screen and it is flashing white vertical lines like a every 3-4 seconds.
                                See the attached image.
                                I removed left side flex-cable from the t-con and then there was half screen sharp and correct image and other half was white.
                                But when I removed the right side flex-cable then half of the screen was white but other half was white and above the white there was vertical lines on half of the screen.
                                T-con two flex-cables have been changed to cross but nothing changed, so it is not due those...
                                01-13-2025, 11:23 AM
