"Polymer" capacitor ID question
  • etnietering
    • Apr 2009
    • 379
    Hey everybody, long time no post!
    My current project is to build myself a new storage server, since my old one is nearly full. The case I ordered comes with 3 SATA backplanes, each of which can connect to 4 disks. Each backplane has a total of 10 capacitors on it (one for each drive +12v, one for each drive +5v, and one for each voltage at the power connectors). The caps are all sleeveless, ventless cans with blue writing that says:
    728
    330
    16
    I figure they're all 330uF @ 16v, and the lack of a vent leads me to think that they're polymer, or at least pretending to be. The lack of identifying marks makes me a bit suspicious. The size is 10mm dia x 11.5mm h, with a 5mm lead spacing.
    The case is a NORCO RPC-2212 2U rackmount. I got a 400W Seasonic 80 Plus Gold PSU for it, so I'm not too concerned about the power quality, but I'm curious about these caps.
    Here's the backplanes:
    And here's a close up of a few of the caps:
    Any ideas?
    Thanks!
  • mockingbird
    • Dec 2008
    • 5488
    Re: "Polymer" capacitor ID question
    According to this page, they're made by Sungho Electronics.
    • etnietering
      • Apr 2009
      • 379
      You appear to be correct. Thank you very much! I should bookmark that website...
      And I guess they're real polymers, too.
      • MORETTIGIAN
        Capacitor detached from PCB – RTX 2070 Super Founders Edition
        by MORETTIGIAN
        Title:
        Description:
        During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
        I did not notice it detaching, so I am unsure of its original location on the PCB.
        Procedure performed:
        - Removed backplate
        - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
        - Reapplied thermal compound
        - Reassembled card
        Observed behavior after reassembly:
        - GPU powers on and operates normally under...
        09-18-2025, 12:14 PM
      • chth96
        Should I replace polymer capacitor?
        by chth96
        a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
        I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
        Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
        Is this ESR value of polymer capacitor correct?...
        11-18-2022, 04:22 AM
      • eccerr0r
        solid polymer electrolytic capacitor go boom?
        by eccerr0r
        Anyone had a solid polymer capacitor fail for whatever reason?
        How do they fail? Do they explode, go open, short out, ?
        How about for different reasons: forcing excessive ripple current, overheating, voltage too high, reverse voltage?
        Just wondering about the causes for a potential shorted solid polymer capacitor... trying to debug a board that has a ~4Ω "short" on a track... it may or may not be a capacitor but was wondering what if it were...
        07-25-2022, 07:12 AM
      • Prolog
        RTX 3080 FE Identifying capacitor
        by Prolog
        Hi people, I hope this is the correct spot to post this, I'm new to the forum.
        I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
        I hope these photos make it clear which component I am referring to:
        (yes, the soldering is a bit botched from removing the blown one, I know)
        I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
        12-01-2024, 08:27 PM
      • Agent24
        Dick Smith Q-1760 linear power supply filter capacitor question
        by Agent24
        I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
        It has at least one problem.
        The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
        I have already ordered a replacement potentiometer, so that's not an issue.
        Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
        All are CapXon...
        10-21-2025, 05:39 PM
