Hi guys.I have two EV dsp processors and before two years i do full recap to both. The units have before recup thousands hours running.On output input coupling caps (16 pieces) i solder nippon lxz series 100mf 63v (this time i don't have other stock) i know is low esr caps.Last week have found and order nichicon fw standard audio series.Is a good reason to replace the nippons lxz with nichicon fw ? The units get better sound? Or get worse?Thanks for any advice.
EV dsp,replace the nippons lxz with nichicon fw ?
NCC's LXZ series is a low impedance series designed for use as filter capacitors in switching power supplies and DC-DC conversion circuits. Depending on how the capacitors you replaced with "standard audio series" parts are used in the circuit, your replacement parts might not have a long life.
FWIW, NCC's LXZ series, Nichicon's PW series, and Panasonic's FC series are pretty much equivalents.PeteS in CA
